HS-24 mkIII build - AVS Forum | Home Theater Discussions And Reviews
 127Likes
post #1 of 58 Old 06-08-2019, 04:14 PM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
HS-24 mkIII build
I'm getting ready to build a cabinet for an HS-24 mkIII driver and am looking for input on the design. This will be a living room 2.1 setup. The plan is about 16.5 ft^3 net with two 8" ports about 48" long (one port on each side of the driver). This will go on the front wall under the TV. It will be powered by an NX6000 amp, and a pair of Klipsch KLF 30s will be beside it. I've posted some screenshots from Bass Box of the design.
Name:	Screenshot (133).png
ID:	2577748   Click image for larger version
Name:	Screenshot (135).png
Receiver: Onkyo TX-RZ730 (7.2.4) Crown XLS1000 (Atmos)
Front Wall: DIYSG Fusion10 L&R, Hybrid DIYSG Fusion10 center
Atmos/Surround: 4 Polk TSX 150C(DIY) 4 Yamaha NS-333
Subwoofers: 4 UM18 Full Marties 16Hz tune, 4 SP-1804 NF 31Hz tune, 2 Buttkicker LFE, 3 NU6000, MINIDSP 2x4
tarponater is offline
post #2 of 58 Old 06-08-2019, 06:13 PM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
Where is your first port resonance and where do you plan to crossover?
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
post #3 of 58 Old 06-08-2019, 07:19 PM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
I did some more tweaking to the model. This one is a bit better. I'm thinking I'll cross it over at around 80Hz.
Name:	Screenshot (137).png
ID:	2577832   Click image for larger version
Name:	Screenshot (136).png
filtor1 likes this.
post #4 of 58 Old 06-08-2019, 08:55 PM
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Needs more amp than a NX6000
K9woofer is offline
post #5 of 58 Old 06-08-2019, 10:21 PM
Quoted: 177 Post(s)
Liked: 133
It will be interesting to see how this turns out for you. I bet i could make this work for the space i have. Good luck i can't wait to see this come together.
tarponater likes this.
Randy_J is online now
post #6 of 58 Old 06-09-2019, 05:02 AM
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
This will be a fun a build. It seems like every couple of weeks you've got another subwoofer build going.
How many subs are you up?
chadsmith013 and ian#77 like this.
Craig S King is offline
post #7 of 58 Old 06-09-2019, 05:56 AM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
There's eight 18s in the theater. Four UM full marties and four SP1804s nearfield. There's also four sealed SP1804s in the living room, but those have been sold to help build this, their replacement. That mini marty I did recently was for a friend. That paid for the living room subs. I build subs for a group I'm in to help fund a lot of my own equipment.
post #8 of 58 Old 06-09-2019, 05:58 AM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
I did some more work with winisd and BassBox this morning. I think I'm getting close to a design I like. I tried to capture all the important information in the screenshot.
Name:	Screenshot (141).png
Craig S King likes this.
post #9 of 58 Old 06-09-2019, 05:59 AM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
Hopefully Black Friday will remedy this problem.
K9woofer likes this.
post #10 of 58 Old 06-09-2019, 09:10 AM
BassThatHz's Avatar
Quoted: 3683 Post(s)
Liked: 4182
An inuke will "work" of course, but it probably needs more juice.
I would recommend a SpeakerPower 6k or PowerSoft K10 or FP14k.
If you plan on having more than 2 24's, then the XBS FP20k holds good value.
The only problems with the clone amps are:
a) no (honored) warranty
b) you have to get a working one via luck
c) infringement
If you can look past all that, they do give Crown iTech 12k-like performance for <$1000, which is hard to ignore...
That said: the iTech and PowerSoft have PFC; the non-PLM gruppens, speakerpower, clones, inukes and cheaper crowns don't.
Low PF puts more stress on the upstream grid/breakers, but most/all residential services don't have to pay extra for low PF equipment (and thus: don't really care. )
If my memory is correct NotNyt showed that many of the clones draw bursts of like 1-200a (each), 120 times a second... where as the PFC amps draw a clean-ish 20-30a sinewave. (On that note: I'm surprised I haven't melted the transformers outside my house yet! Time to add more subwoofers! )
tarponater and ian#77 like this.
BassThatHz is offline
post #11 of 58 Old 06-09-2019, 09:51 AM
Quoted: 177 Post(s)
Liked: 133
I agree BTH you need to add more subs. I thought you were going to get a container full of those 24's like you have. Then several more fp20000q ad you may be getting closer to your goal.
post #12 of 58 Old 06-10-2019, 07:18 AM
chadsmith013's Avatar
Quoted: 2116 Post(s)
Liked: 2146
@LTD02 any thoughts on the design.. ??? thanks
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 2 DIYSG Volt 6's
Subwoofers: Dual LaVoce SAN214.50 21's in Cyclops enclosures w/Inuke 6000 DSP
Nearfield: 2 Dayton HO 15's w/Inuke 6000DSP
chadsmith013 is offline
post #13 of 58 Old 06-11-2019, 08:21 AM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
Started working on the cabinet Sunday afternoon. Tonight I should have the ports finished, then I can start on the bracing. I'm using vertical window bracing about 10" on center and one line of horizontal window bracing down the center.
Name:	HS 24 1.jpg
ID:	2578812   Click image for larger version
Name:	HS 24 2.jpg
post #14 of 58 Old 06-11-2019, 08:57 AM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
You are making good progress
-John
Red Five is offline
post #15 of 58 Old 06-11-2019, 11:54 AM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
-John
Yeah, I'm hoping to have construction wrapped up this weekend. Communication seems to be very slow with SI right now. I have no idea when the driver will be ordered.
ian#77 likes this.
post #16 of 58 Old 06-11-2019, 01:56 PM
ian#77's Avatar
Quoted: 23 Post(s)
Yes it is a shame, customer service is important.
Sent from my iPhone using Tapatalk Pro
chadsmith013 likes this.
DENON X6500H,
FRONTS SVS ULTRA CENTER,SVS ULTRA BOOKSHELF'S
SUBS SVS PB-3000'S x2 UM18 x2
SURROUNDS YAMAHA NS-333 SIDE KLIPSCH QUINTET REAR
RAPTOR 700 FOR WHEN YOU NEED TO STOP WATCHING MOVIES
ian#77 is offline
post #17 of 58 Old 06-11-2019, 08:28 PM
Quoted: 177 Post(s)
Liked: 133
When exactly did you order your subs? The SI subs are awesome but the build time is a little longer that you may expect. Several of us were in the 3 to 4 month range. I hope you didn't order recently and are now hoping to have a quick turn around. Probably not going to happen.
post #18 of 58 Old 06-12-2019, 04:56 AM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
I haven't ordered yet. I emailed them last week to see if they would be putting them on sale soon, or had any coupon codes I could apply. They said they would send a discounted invoice to my PayPal account. Soon as I get the invoice, I'll be ordering two. I can handle waiting on the build, it's this waiting for the invoice that is bothering me.
ian#77 likes this.
post #19 of 58 Old 06-13-2019, 10:23 AM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
Just an update on the driver order. Everything has been worked out. They misspelled my email address a couple times when they were sending the invoice. Nick fixed it this morning and is building the subs now. Looking forward to hearing these monsters. Construction continues tonight. Still on schedule to have the cabinet finished this weekend.
post #20 of 58 Old 06-13-2019, 10:33 AM
ian#77's Avatar
Quoted: 23 Post(s)
just an update on the driver order. Everything has been worked out. They misspelled my email address a couple times when they were sending the invoice. Nick fixed it this morning and is building the subs now. Looking forward to hearing these monsters. Construction continues tonight. Still on schedule to have the cabinet finished this weekend.
fantastic!!!!
DENON X6500H,
ian#77 is offline
post #21 of 58 Old 06-13-2019, 12:08 PM
Liked: 2146
OH
post #22 of 58 Old 06-13-2019, 06:44 PM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
Everything is cut and dry assembled. Tomorrow I'll cut all the holes in the braces. Looks like I'll have it all glued up Saturday and hopefully painted Sunday.
ID:	2579674   Click image for larger version
ID:	2579676   Click image for larger version
ID:	2579678   Click image for larger version
post #23 of 58 Old 06-13-2019, 07:49 PM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
Anytime there is a 24" or more involved.
bulls, filtor1, tarponater and 1 others like this.
Red Five is offline
post #24 of 58 Old 06-13-2019, 10:24 PM
BassThatHz's Avatar
Liked: 4182
Maybe I'm just drunk but those braces look all wrong.
post #25 of 58 Old 06-14-2019, 05:23 AM
Quoted: 177 Post(s)
Liked: 133
What are you seeing as wrong? He said he still needs to cut the holes in to all the window braces. Or am i missing something.
post #26 of 58 Old 06-14-2019, 12:29 PM
Quoted: 215 Post(s)
Liked: 219
I AM drunk. And I can assure you, those braces are all wrong.
Not really... I think it's a progress pic, final cuts not made.
That box has to be super heavy man! My 14 cu ft box was heavy enough... Lookin good though!
chadsmith013 and tarponater like this.
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva LPA-1 (Currently Fried) | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Dayton Ultimax 15 | Crown XPS1000
Living Room Duty- DIY Swope TMWW LCR
Currently Building- (3) Stereo Integrity HS-24 mkiii's
blister64 is offline
post #27 of 58 Old 06-14-2019, 01:34 PM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
LOL, kinda looks like a shoe rack. The cabinet is just dry fit right now, no glue. I'll take it apart tonight and cut all the holes out of the window bracing. Hopefully it will start to look like a speaker cabinet tomorrow.
corradizo and Purenv like this.
post #28 of 58 Old 06-14-2019, 06:53 PM - Thread Starter
tarponater's Avatar
Quoted: 89 Post(s)
Liked: 417
Hopefully this will clear up any confusion.
ID:	2580044   Click image for larger version
ID:	2580046   Click image for larger version
bulls, filtor1, eng-399 and 5 others like this.
post #29 of 58 Old 06-14-2019, 07:37 PM
Quoted: 141 Post(s)
Liked: 66
You know you have a problem with subs when a gallon jug of Titebond 3 in involved....
I'd tap out now....
cellarnoise is offline
post #30 of 58 Old 06-14-2019, 07:40 PM
filtor1's Avatar
Quoted: 261 Post(s)
Liked: 238
Looks great man! Glad everything worked out with the 24".
chrapladm and ian#77 like this.
filtor1 is offline
