Building the Perfect Beast - AVS Forum | Home Theater Discussions And Reviews
 34Likes
  • 10 Post By BigSubNut22
  • 3 Post By johnson636
  • 3 Post By popalock
  • 3 Post By Red Five
  • 1 Post By jevchance
  • 1 Post By Jk7.2
  • 1 Post By BassThatHz
  • 1 Post By LastButNotLeast
  • 9 Post By BigSubNut22
  • 2 Post By BassThatHz
  • 1 Post By Purenv
post #1 of 25 Old 06-09-2019, 07:20 PM - Thread Starter
BigSubNut22's Avatar
Quoted: 12 Post(s)
Liked: 75
I have been looking for one of those GE 30" polystyrene cone subs they sold in the 60's but could not afford, nor the 24" Harltey's from later in the 70's. I finally picked up a couple of 21" Malstroms from Exodus Audio. I then saw the HS 24" SHS monster and purchased one to use behind me for near bass to augment my IB with 32 x 18" doorway. Being like everyone else here when the 32" came out on the market I followed those threads with interest. I looked over some of the available companies and saw that Pierce Audio was coming out with a 33" Home Theater model so I contacted him and we set up an order for a Neodynium motor unit with a 6" voice coil and 20Hrtz FS. Other specs are Qts of 0.59, Vas 47.6 cu ft, Qes 0.66, Qms of 5.3, dual voice coils total of 4.8 ohms combined, BL 28lb, SPL @ 2.83 V of 98 db 12000 watts Pe Xmax 1 inch, Xmech of 5 inchs. I have family in Washington state so I went up to Seattle since I was in the state and picked up the completed unit from Paul. 176 lbs even with the Neo magnet, would have been over 200 lbs! I took a couple of pictures to share with everyone here, hope they will attach.OK. The first coupe are me and the Monster, the next few are my grandkids 6yr and 3 yr olds, last one is the youngest, 9 month old, he is not to sure about being next to this scary big black thing that looks like it could eat him! So I will get my computer son to move over the thumb nails from Paul's e-mails of the building of the driver at his shop. I would appreciate any input on possible alignments if you guys have some inputs I was considering a 5 sided sealed box of about 60" wide and 24" deep, should be about 22 cu feat sealed volume, .7 QTS. I even thought about using 5 of the 18" PR's from Parts express on the back of the pentagram box if I made the box 30" deep. Not too sure how to calculate the appropriate volume on these PR designs. Any way, hope I can do this Big Boy justice on my build.
ID:	2578192   Click image for larger version
ID:	2578194   Click image for larger version
ID:	2578196   Click image for larger version
ID:	2578198   Click image for larger version
BigSubNut22 is offline
post #2 of 25 Old 06-09-2019, 08:04 PM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 672
32 x 18", 2 x 21", and a SHS 24...geezus
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #3 of 25 Old 06-09-2019, 08:12 PM
Quoted: 174 Post(s)
Liked: 132
And now a 33" that is a lot of woofage. You are one of the few giving BTH a run for his money. It is crazy when you see a woofer that makes the Hs-24 look reasonable. Congratulations on getting that beast. I look forward to hearing your impressions.
Randy_J is offline
post #4 of 25 Old 06-09-2019, 08:21 PM
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
Wow. I'm definitely interested in seeing where this goes.
Craig S King is offline
post #5 of 25 Old 06-09-2019, 08:21 PM
johnson636's Avatar
Liked: 672
I think the op has surpassed BTH.
post #6 of 25 Old 06-09-2019, 09:35 PM
popalock's Avatar
Quoted: 1490 Post(s)
Liked: 2088
Been looking for something fun to follow for awhile. Think I found it.
Cute Grandnuts!
Slow-mo free-air xmech video please....
popalock is offline
post #7 of 25 Old 06-10-2019, 05:58 AM
Red Five's Avatar
Quoted: 398 Post(s)
Liked: 448
The sub woofer is almost the size of the TV, I really like it! Horn loading will result in a box the size of a car, even ported with this beast will result in 40 or 50cuft for a mid teens tune. PRs should keep the box size more under control. Sealed would be the most practical then pair this thing up Speaker Power SP1-6000
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
post #8 of 25 Old 06-10-2019, 07:14 AM
Quoted: 87 Post(s)
Liked: 91
I'm sorta intrigued about this GE 30" polystyrene subwoofer. Anyone have any information on it?
stegen likes this.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is offline
post #9 of 25 Old 06-10-2019, 07:29 AM
Jk7.2's Avatar
Quoted: 1408 Post(s)
Liked: 2582
Are you saying you have an IB with 32 woofers that are 18”? Or that the doorway measures 32” X 18”?
Edit: never mind. Clicked on your other threads. I see it now. Lots to read today! Thanks!
stegen likes this.
Jk7.2 is online now
post #10 of 25 Old 06-10-2019, 01:10 PM
tjambro's Avatar
Quoted: 29 Post(s)
Liked: 74
Tell me you didn't just say a 33" sub driver...in any alignment...is practical?
Ain't this a great hobby?
tjambro is offline
post #11 of 25 Old 06-10-2019, 06:35 PM
BassThatHz's Avatar
Quoted: 3679 Post(s)
Liked: 4173
You're about the only person that makes me look sane. Definitely more cone-area and displacement than I have.
I would do IB with that thing, that's about the only "box" that would do it justice.
How will you power it though, a bridged K20?
There is absolutely no way any of your walls are still in one piece with that much displacement, I'd bet money that your doors jump right off their hinges every time the ULF hits (unless they're heavily-modified).
Purenv likes this.
BassThatHz is offline
post #12 of 25 Old 06-10-2019, 09:04 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 75
This will take me some time to complete, I spent all day in my basement painting wall trim, trying to do repairs from Nov 4th when my water heater outlet hose blew off its fitting and pumped hot water into my basement for 45 minutes. My mistake was having a remediation crew come out to do cleanup. They tore out my heartwood pine wainscotting that was from the 50's and could not be replaced. I have done a different style wainscotting with smooth paneling and raised borders, I am really close to getting this room back together than I can start on the building project for this Beast. Oh, and also when I was at Pierce Audio I noticed that Paul has a cone for a P.A. type 33" speaker that would be a supreme Mid Bass Monster, you could contact him about that application. I also have contacted my utility company about getting my house upgraded from its original 100 amp supply upgraded to modern 200 amp supply. Should not be too hard, my AC comes from a outdoor pole about 50 feet from my home. I am leaning towards a fp20k amp to run the 24" DVC and the 33" also DVC, 2 Ohms per coil. Still trying to find a somewhat safe way to order one of those amps. I really appreciate all your input and wisdom as I have very rudimentary computer skills so I hope everyone has patience with me on this project.
post #13 of 25 Old 06-10-2019, 10:59 PM
N8DOGG's Avatar
Quoted: 1298 Post(s)
Liked: 1529
When my buddy built both his 32s, we ended up sealed 19cf, 8 ohm coil and one bridged fp14000 per driver. Its a perfect match. If I was you, Id be going straight to Speaker Power since its a 4 ohm load.
Juliens mach 5 32's can soak up the entire fp14000....
The parts for both subs are the same, motors may be different to some extent but you will love them Im sure!
Dont see to many builds with 32s!
N8DOGG is offline
post #14 of 25 Old 06-11-2019, 07:51 AM
Quoted: 87 Post(s)
Liked: 91
Originally Posted by N8DOGG View Post
...one bridged fp14000 per driver...
My... goodness...
stegen likes this.
DIY 110" AT Screen
post #15 of 25 Old 06-11-2019, 06:09 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 75
Hey Jevchance the 30" sub was actually a Electro Voice 30W used in the Patrician 4 way horn system back in the 50's. Was in a corner loaded design like the venerable Klipschorn. Was rated 150 watts with a 4" voice coil and about 7 mm xmax, 4 lb motor structure, 100db sensitivity a 2.83 Volts. For something really wild check out a handbuilt 76" clear plexi subwoofer built by graduate students at Wisconsin-Madison university. I left the website addr at work, sorry, but it comes up under the 30" EV google search. There is also a guy that hand builds a 48" sub with cabinet and power amp custom equilized to the customers room. This super sub is a fun rabbit hole to go down.
post #16 of 25 Old 06-11-2019, 06:34 PM
BassThatHz's Avatar
Liked: 4173
XBS does paypal, just ask them.
The fp20k on a 200a breaker should be fine, it will be able to power the 24, the 33, and the 2 21's all at once. The 33 will be a bit underpowered with that amp but it does save you huge money consolidating everything down to 1 amplifier, and lots of rack space no doubt.
If you bought 2 you could probably run the 32 18's with the other, it puts out a lot of power at dual 8-ohm bridged or quad 4-ohm.
Less so at higher ohms of course...
post #17 of 25 Old 06-11-2019, 06:38 PM
LastButNotLeast's Avatar
Quoted: 2364 Post(s)
Liked: 1989
Too late for a sanity check, I presume.
Michael
dftkell likes this.
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #18 of 25 Old 06-16-2019, 03:27 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 75
Took couple more pictures showing the Beast out of the crate and gr kids for scale. Also see if can attach some build pictures from Paul. K, having my son help with this picture stuff, the pictures after gr kids are of parts and pieces from Pierce Audio challenges during construction. The Neo block had to be machined and then aluminum jigs set up to hold the Neo and bolts and epoxied into place. At one point the mill broke and needed a new vise. Any questions let me know, also the depth is 17 inches just for general info.
ID:	2580862   Click image for larger version
ID:	2580870   Click image for larger version
ID:	2580872   Click image for larger version
ID:	2580890   Click image for larger version
ID:	2580894   Click image for larger version
Name:	12k steel4.jpg
ID:	2580896   Click image for larger version
Name:	12k steel1.jpg
ID:	2580898   Click image for larger version
ID:	2580900   Click image for larger version
ID:	2580904   Click image for larger version
ID:	2580906   Click image for larger version
ID:	2580908   Click image for larger version
Name:	12K NEO finished4.jpg
ID:	2580910   Click image for larger version
ID:	2580914   Click image for larger version
ID:	2580916   Click image for larger version
ID:	2580918   Click image for larger version
ID:	2580920   Click image for larger version
ID:	2580924   Click image for larger version
ID:	2580926   Click image for larger version
Last edited by BigSubNut22; 06-16-2019 at 03:47 PM. Reason: adding more pictures from Pauls shop.
post #19 of 25 Old 06-17-2019, 07:25 PM
BassThatHz's Avatar
Liked: 4173
My lower-back hurts just thinking about lifting 176lbs!
I guarantee you that if you drop that beast on your foot, the hospital will have to amputate your leg at ear-level...
d-rail34 and BP1Fanatic like this.
post #20 of 25 Old 06-18-2019, 01:52 PM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 171
Thumbs up
Wow!!!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #21 of 25 Old 06-20-2019, 07:39 AM
Mazza's Avatar
Liked: 35
Now I'm thinking that's an innovative way to run your "added mass" Vas calc sweep?
Mazza is offline
post #22 of 25 Old 06-20-2019, 10:00 AM
Purenv's Avatar
Quoted: 177 Post(s)
Liked: 119
You KNOW that lil’ guy is going to be a future basshead.
Red Five likes this.
Purenv is offline
post #23 of 25 Old 06-21-2019, 10:11 PM
Quoted: 359 Post(s)
Liked: 510
Good choice in beer.
post #24 of 25 Old 06-25-2019, 11:44 AM
uniquepattern's Avatar
Quoted: 808 Post(s)
Liked: 857
Oh wow, I cant wait to see what happens with this!
uniquepattern is offline
post #25 of 25 Old 06-25-2019, 12:41 PM
noah katz's Avatar
Quoted: 1819 Post(s)
Liked: 631
Wow
Horn would be the size of a house at least, assuming it's a bass horn.
I believe Qe is too high for horn or ported/PR.
Agreed that sealed IB is best for performance.
Oh, and also when I was at Pierce Audio I noticed that Paul has a cone for a P.A. type 33" speaker that would be a supreme Mid Bass Monster...
I wonder what the breakup freq of a cone that big is.
Seems analogous to saying if a 1" tweeter is good, a 4" tweeter is better.
That's a drill press vise (only needs to withstand vertical force), not a milling vise.
Noah
noah katz is offline
