stick on veneer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-13-2019, 09:00 AM - Thread Starter
Quoted: 277 Post(s)
Liked: 146
stick on veneer?
Any recommendation for where to order the sticky veneer? A place with a bunch of options?
Marantz SR7010 - Emotiva XPA-3 Gen 3 - SeymourAV 16:9 Premier 130" XD - JVC DLA-RS540 - 7.2.4 - L/C/R DIY Fusion 15 Sentinel - Surrounds RSL CG3 - Ceiling Polk RC80i - Dual UM-18s in sealed 4 cu ft with bridged Crown XLS 2002s
klimo is offline
post #2 of 8 Old 06-13-2019, 12:16 PM
asarose247's Avatar
Quoted: 1200 Post(s)
Liked: 1056
Rockler carry's 3M in a few types
i used the self stick white Oak , 12" x 10' , $50, for this creation,
stained with a let down red latex
highlighted in the grain with a black oil stain
and sprayed to be semi-gloss finish
not immediately noticeable but each piece (trys) to match a grain continuation, mol, to the piece on the opposite side of the driver . .
because
lots of masking and Fatmax razor knife blades, steel straight edges for getting that precisely sharp fit
i spent some time working with various paper printed grain patterns to "see" what might work
probably a bit more that most might envision
what type of experience do you have or want to try?
plenty of successful and more straight forward veneer jobs that are really really good work here in the DIY section
Name:	VBSS 2 wood grain layout pattern.jpg
ID:	2579586   Click image for larger version
Name:	VBSS  allowed back in the house.jpg
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #3 of 8 Old 06-13-2019, 12:38 PM
plasma_fan's Avatar
Quoted: 82 Post(s)
Liked: 104
By no means am I a veneer expert, however I have had REALLY good success with wood glue and an iron. Basically roll on the glue to both the veneer and the work piece, let it dry, place your veneer, and press it down with a hot iron. I like this because it lets you work and slide the veneer around without it sticking. stuff I have done seems pretty permanent as well, no signs of lifting.
plasma_fan is offline
post #4 of 8 Old 06-13-2019, 01:47 PM - Thread Starter
Quoted: 277 Post(s)
Liked: 146
Cool. Thanks guys.
I have never tried using veneer. I saw some neat, somewhat easier approaches, with painting everything but the front baffle a nice flat black, then applying a very dark veneer to the front baffle. The results looked really nice and looked to be a bit easier with only doing one face, albeit the rounded over part.
klimo is offline
post #5 of 8 Old 06-13-2019, 03:57 PM
markg35's Avatar
Quoted: 345 Post(s)
Liked: 268
Veneer Factory outlet has the most from what I've seen.3M peel and stick can be added to most of their veneers.
Veneer Supplies.com has less peel and stick options but price and shipping are less depending on where you are located.
markg35 is online now
post #6 of 8 Old 06-13-2019, 08:52 PM
tjcinnamon's Avatar
Quoted: 1798 Post(s)
Liked: 483
I was way freaked out to veneer and looked at any way possible to make it easier. Eventually I just bit the bullet and did the contact cement and wax paper method. It worked amazing and was super easy. You can check my MBM build thread to see it. Way easier than I thought it would be.
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #7 of 8 Old 06-14-2019, 01:11 AM
Quoted: 398 Post(s)
Liked: 342
I would order from a place that has the option to add the 3M backing to veneer, this way you can make a choice after your first experience. Personally I love sticky back and think its worth the slight extra cost but there are some who love contact cement too. I don't hate contact cement, I just love how simplistic the 3M backing is.
Trimlock is offline
post #8 of 8 Old 06-17-2019, 04:13 PM
gangrew's Avatar
Liked: 39
I have bought it from amazon before with no issues. Just search for PSA veneer.
gangrew is offline
