Pioneer CS-G303 - Modernize - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By johnson636
  • 1 Post By Cichlid109
post #1 of 7 Old 06-15-2019, 04:21 AM - Thread Starter
robertkjr3d's Avatar
Quoted: 31 Post(s)
Like many my 'CS-G303's are ok. But the paper on the midranges is shot. I think this is a common issue with vintage-paper-cones. Especially this model. It looks like when you search on ebay for parts, you can't even find people selling ones that aren't 'worn'. I seem to remember people complaining that the tweeters could be altered as well to be more crisp. But I can't find that thread.
I have read people actually going in and changing the crossover too. I really don't want to go that far. But I'm willing to swap out some drivers. I might be willing to play with the crossover. But I'm just not good at that part.
I'm currently using these speakers as my Rear-Channels in my surround system. I've also DJ'd with them.
robertkjr3d is offline
post #2 of 7 Old 06-15-2019, 07:09 AM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 671
Or you could drop the hassle and just replace them
buggers likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 7 Old 06-15-2019, 12:52 PM - Thread Starter
Quoted: 31 Post(s)
Yes.. But of course my thought is replacing a bad driver (or two) is cheaper.
When I buy speakers. I kinda go big or go home.
post #4 of 7 Old 06-15-2019, 03:06 PM - Thread Starter
Quoted: 31 Post(s)
Would it be so bad to swap the midranges out for these Pyle-Pros? It appears I'm not the first person who has done this with success.
https://www.parts-express.com/pyle-p...ProductDetails
The pyle-pros fall within the frequency points. The speakers have XOver points at 3.5khz, and 7khz... And it is the right size.
post #5 of 7 Old 06-15-2019, 03:35 PM - Thread Starter
Quoted: 31 Post(s)
I didn't think of this until I linked it. But I thought I used these in another DIY speaker set that I'm about to get rid of. I'm in the middle of upgrading the whole home-theater...
But I actually have a set of 5in Pyle-Pros. I think they are 5in anyway in the shed. I found that I used a different drivers.
I have these: These are a cousin of the one above.
https://www.parts-express.com/pyle-p...ProductDetails They are the closed back version. I'm gonna give it a try. Assuming they are 5in.
Edit: They are 5 1/4in I've played that game before. Trying to fit a speaker that was too big before. Not going to play that again.
post #6 of 7 Old 06-16-2019, 07:24 AM
Cichlid109's Avatar
Quoted: 256 Post(s)
Liked: 154
You might have better luck if you go to the speaker forum.
robertkjr3d likes this.
Denon AVR-4520 LCR BIC PL89ii's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height w/EP-2000, BIC DV84's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #7 of 7 Old 06-18-2019, 08:00 AM
buggers's Avatar
Quoted: 13 Post(s)
Speaker parts are not a mix and match kind of thing...If you can't find new replacement drivers then just replace the whole thing.
buggers is offline
crossover , Pioneer , vintage
