DIYSG Apollo-7 MT build - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #1 of 71 Old 06-15-2019, 05:24 AM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
I recently got the urge to break out my ancient vinyl collection, and realized two things:
1) I'm old
2) I have NOTHING to play it on!
I can't do anything about the first, but I've embarked on a project to solve the second.
I'll probably start a main thread for the rest of the system, so everyone can learn from my mistakes, so this thread will focus on the speakers. As any (smart) DIYer would do, the first place I looked was DIYSG for a pair of kicka$$ bookshelves to handle speaker duties. If you haven't had the pleasure, I highly recommend Erich and the crew over at DIYSoundGroup for tackling your own speaker projects. I used his stuff for my HT build, and couldn't be happier. For these bookshelves I wanted something capable of giving me a broad range of sound, with good efficiency and solid clarity. I'm not 100% sure about whether I'll add a sub down the line, so after much consideration I went with a pair of Apollo-7 MTs. In the past I've built the boxes from scratch, but this time I decided to give his flatpacks a go, and let my DIYness focus on potentially prettying them up with some veneer when I finish.
First step: Unboxing
We've all had to deal with Erich's shoddy packing jobs in the past, and this time was no exception.
Literally a box, stuffed with popcorn, another box, with more popcorn, protective wrapping, and beautifully sorted components within. I've never seen anyone who puts better time and effort into ensuring their product arrives safely. They do an incredible job!!
After playing with the flatpack, I'm 99% sure it'll take me less time to glue it up than it did to unbox.
ID:	2580232   Click image for larger version
ID:	2580234   Click image for larger version
ID:	2580236   Click image for larger version
DougUSMC is offline
post #2 of 71 Old 06-15-2019, 05:45 AM
Jk7.2's Avatar
Quoted: 1526 Post(s)
Liked: 2743
Cool project. I’ll be watching for sure, as I believe I have the same flat packs here for a pair of helix dome speakers I just bought. I also plan on veneering mine. So I’ll be subbed and watching your progress!
Jk7.2 is online now
post #3 of 71 Old 06-15-2019, 06:30 AM
bear123's Avatar
Quoted: 2656 Post(s)
Liked: 4152
Would be great to see a comparison between the Apollo and Helix Dome as both are 7", seemingly similar designs. I do wish there were more measurements available for some of these designs. The measurements available on the HTM series are one of the big reasons I felt comfortable trying that design.
The Apollo woofer is supposed to be pretty amazing but I wonder what, if anything, it might give up above the low bass with its very high excursion. The Helix is 8 ohms and more efficient requiring far less than half the power(1/4?). I think it would be very interesting to hear these compared to the HTM's. Basically, comparing wide dispersion speakers to controlled directivity.
Both of these designs have caught my eye as far as a possible project, just to do something different.
bear123 is online now
post #4 of 71 Old 06-15-2019, 07:01 AM
Jk7.2's Avatar
Liked: 2743
Well the SE mi gtg will have the helix dome, htm-8, htm-6, HT-8’s, and those are just my speakers. Others may bring more. Join us and have a listen.
Jk7.2 is online now
post #5 of 71 Old 06-15-2019, 08:22 AM
bear123's Avatar
Liked: 4152
What are your thoughts concerning the Helix dome vs the HTM's, or other well known retail "hifi" speakers?
post #6 of 71 Old 06-15-2019, 08:31 AM
Jk7.2's Avatar
Liked: 2743
I sent you a PM
bear123 likes this.
Jk7.2 is online now
post #7 of 71 Old 06-15-2019, 11:58 AM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
Hmmm, challenge #1 :
Normally I'd glue up the whole box, minus face piece. Drill out holes for terminal posts, pre-drill for crossover board. Spray glue, add denim insulation. THEN glue on front baffle piece, sand down the whole box, prime, then Duratex. THEN when the whole thing is ready, screw in the board, install drivers, et voila.
I was planning to go through the same steps, replacing the "Duratex" step with "Veneer, stain, seal". The challenge is that the board is a pretty good size, so I won't be able to screw it to the back panel, due to a cross brace being in the way. The board can either go on the bottom or a side, and I'm not 100% convinced of my ability to hand-screw it into place with such a tight fit.
Pics of the dry fitted pieces, with the board lying against the bottom panel:
I'm thinking the best thing to do is glue the 6 sides together w/o the front, drill out terminal posts, add insulation, install crossover board. THEN glue the front on, veneer, etc...
Thoughts? Am I missing something?
ID:	2580352   Click image for larger version
DougUSMC is offline
post #8 of 71 Old 06-15-2019, 12:04 PM
Jk7.2's Avatar
Liked: 2743
This is what I do most of the time. It’s easier to get the internal cab crossover mounted, wired, and lined without the baffle on.
Jk7.2 is online now
post #9 of 71 Old 06-15-2019, 12:41 PM
Quoted: 44 Post(s)
Liked: 37
That's how I do it - those are going to be awesome
scottvalentin is online now
post #10 of 71 Old 06-15-2019, 12:47 PM
smcmillan2's Avatar
Quoted: 905 Post(s)
Liked: 793
I cut the terminal cup holes prior to putting anything together. Easier to handle a 2" hole saw on the drill press than in a hand drill.
I also mount the crossover (usually pre-wired) prior to gluing the baffle.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #11 of 71 Old 06-15-2019, 12:55 PM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
Interesting, I guess I've been spoiled in the past. To me it's always been easier to have a single "gluing stage", followed by "electronics", "finishing", "final assembly".
I also don't like doing finishing with the board already installed, I prefer to have it safely set aside. "Board + spray glue" doesn't work well...
DougUSMC is offline
post #12 of 71 Old 06-15-2019, 01:00 PM
asarose247's Avatar
Quoted: 1246 Post(s)
Liked: 1091
Waiting to see how this sounds . . .
I do remember your HT build /posts
as i'm thinking about a good for 'ordinary" stereo as close to full range as might be "reasonable"
I asked @mtg90 about the HTM12's and a possible cab / port mod since redoing the baffle is not usually "simple"
If the HTM-12 was built as 18"w x 25"h x 18"d it will give an F3 in the upper 40's and in room should give decent extension and output down to the low 40's upper 30's. Ports for this modification do not need to be changed from the 3" stock length.
The imaging of the SEOS horns works very well for my 70 y.o.+ ears
not the least bit uncharmed with the HTM6's BTW
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #13 of 71 Old 06-16-2019, 03:40 AM
Quoted: 446 Post(s)
Liked: 364
unless your spray glue has corrosives or metals in it, I don't see why youd need to worry?
Are you planning on joining these using spray glues?
Trimlock is offline
post #14 of 71 Old 06-16-2019, 03:17 PM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
Hey asa, long time! I didn't realize you were getting up there that far??
Nope, just spraying them w/3m to adhere the denim insulation. I joined them w/regular wood glue.
Segue...
Got everything glued up today, about as simple as can be. It took about 15 minutes to get both glued up, and next to zero tools. I've decided to start including some add'l info, for any that thing these are too tough to take on. For this step I used 8 clamps I have from other projects. These fit together so well that the clamps are really just to squeeze out excess glue and hold it while it glues up. Anything you have around will work. Other than that, just a brush I use for spreading glue, a wet rag (cleaning up while gluing is easier than scraping later), and the glue.
Current status: drying overnight
DougUSMC is offline
post #15 of 71 Old 06-19-2019, 07:05 PM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
Not much time today, but I at least got 15 minutes on the boards.
Step 1: Find a couple of blocks, so you can screw the boards in slightly elevated. This will let you finish the rest more easily
Step 2: Take out all components, straighten then slightly bend the leads downward so they can be placed on the board properly (markings showing, slight bend with an even curve, well spaced for the holes in the board)
Step 3: Dry fit all of the parts, to make sure they're ready for final attachment and soldering
Current status:
Lastly: I have no idea what these are for. Anyone have a hint??
ID:	2582172   Click image for larger version
ID:	2582174   Click image for larger version
DougUSMC is offline
post #16 of 71 Old 06-19-2019, 07:08 PM
bear123's Avatar
Liked: 4152
Insert them just as you have them oriented into the holes in the corners of your board. Use the supplied little screws to mount the board with these "stand offs" into your enclosure. Gives a little space between the bottom of the board and the surface you are mounting to.
Maybe it shows up in this shot of my board:
smcmillan2 and Jk7.2 like this.
post #17 of 71 Old 06-19-2019, 07:17 PM
smcmillan2's Avatar
Quoted: 905 Post(s)
Liked: 793
You missed Step 4: Hot glue the components to the board, then solder them. Huge help as they won't move around on you while doing so.
I don't affix mine to anything while soldering. Align component, hot glue, solder is my preferred method.
post #18 of 71 Old 06-20-2019, 04:15 AM
Rickreagan120's Avatar
Quoted: 16 Post(s)
Just finished my mtm helix build. Would be cool if we were neighbors so we could do a comparison. I would love to see how they stack up against each other.
Rickreagan120 is offline
post #19 of 71 Old 06-20-2019, 07:10 AM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
Ah, very cool. I usually just buy 1/4" rubber spacers and use them, but these will save me a trip. THANKS!
Maannnn, you just stole the thunder from tonight's update! I was going to do steps 4 (glue) and 5 (zip ties) tonight, but ran out of zip ties!! Those should be posted later tonight.
Yeah, that would be super interesting. I was considering something larger but I went with these out of aesthetics for the future furniture build I'll be doing for the turntable.
DougUSMC is offline
post #20 of 71 Old 06-20-2019, 11:54 AM
_tk
Quoted: 556 Post(s)
Liked: 237
I glue and zip-tie before I solder. Is there a reason to do it the other way around?
I like the Apollo 7 kit, but the 4 ohm nature of it somewhat concerns me (given the receiver I want to run them on).
_tk is offline
post #21 of 71 Old 06-20-2019, 02:12 PM
asarose247's Avatar
Liked: 1091
all tremendously attentive to the details
should be a great build / how they sound/perform post at the diysg site. . .
post #22 of 71 Old 06-20-2019, 02:29 PM
optoguy's Avatar
Quoted: 42 Post(s)
Liked: 34
Theses are the two I'm considering for surrounds. i would also love to see how they stack up against each other!
Darren A.
optoguy is offline
post #23 of 71 Old 06-20-2019, 02:51 PM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
Nope, you're right. Apologies if I worded it badly, but that's my plan too:
1) Dry fit parts (last night)
2) Secure parts (zip tie/glue - tonight)
3) solder (maybe tonight)
Why does 4 ohm worry you? Most receivers can run that? For me personally I'm looking for a nice tube amp to run these w/my record player, so it shouldn't be a problem.
DougUSMC is offline
post #24 of 71 Old 06-20-2019, 06:43 PM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
The boards are done!
I started by hot gluing everything down, and zip tying everything that had holes allowing for it.
Next, I unscrewed the board from the block, flipped it over, and straightened all of the leads poking through
Finally, soldered everything, then snipped off the excess leads
All done!!
To top it off, here are the tools used tonight: a cheapo $6 hot glue gun, moderately priced soldering station, snips, and a screwdriver.
All in, probably another hour or so tonight to finish it all up and clean up
ID:	2582576   Click image for larger version
ID:	2582578   Click image for larger version
ID:	2582580   Click image for larger version
ID:	2582582   Click image for larger version
ID:	2582588   Click image for larger version
jjcook likes this.
DougUSMC is offline
post #25 of 71 Old 06-20-2019, 06:51 PM
sandydankness's Avatar
Quoted: 135 Post(s)
Liked: 109
Whoa, had no idea there were that many parts in a 2 way crossover. Imma have to take a look at these for 2 channel.
sandydankness is offline
post #26 of 71 Old 06-21-2019, 08:56 AM
_tk
Quoted: 556 Post(s)
Liked: 237
Running with a vintage Marantz. It'll handle 4 ohm, but I'd rather keep loads a bit less.
Out of curiosity, why did you choose this kit vs. the Helix Dome MT (that is 8 ohms)?
_tk is offline
post #27 of 71 Old 06-21-2019, 08:58 AM
_tk
Quoted: 556 Post(s)
Liked: 237
I sent you a PM
Can you post that info here? I too am curious about the Helix vs the Apollo kit.
_tk is offline
post #28 of 71 Old 06-21-2019, 09:44 AM
Jk7.2's Avatar
Liked: 2743
Haven’t heard both. I gave him someone else’s name to ask.
Jk7.2 is online now
post #29 of 71 Old 06-21-2019, 10:42 AM - Thread Starter
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
That's cool. I'm planning to build a tube amp kit, which will be just as happy w/the 4 ohm.
Given that it's tubes, I'll pick up some more warmth. Most of the kits I've seen dig 4 ohm setups, and need lower wattage numbers to drive solid speakers. I'm really hoping that I don't feel the need to add a subwoofer for the LF, but anything that won't cover 30Hz makes me doubt it.
Basically, I'm hoping that extra 4-5Hz of LF that the Apollo has on the Helix keeps me happy. That's what drove the choice over to the Apollo.
DougUSMC is offline
post #30 of 71 Old 06-21-2019, 11:17 AM
_tk
Quoted: 556 Post(s)
Liked: 237
I'd like to see a DIY shootout of the Helix vs Apollo vs Classix II. All are roughly the same style of build and size, but by three different designers.
You will have to post your impressions on the Apollo after you get them built. But...85db sensitivity and 4ohm speakers typically require a lot of power really to sound their best, dynamically.
_tk is offline
