Unbalanced to Unbalanced Cleanbox like Gain - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #61 of 69 Old 06-21-2019, 03:47 PM
Stereodude's Avatar
Quoted: 4250 Post(s)
Liked: 2993
Originally Posted by johnson636 View Post
But isn't each method essentially the same since the objective is getting the signal level at or below than -6 on the minidsp? My sub trim is set at -6 and the MV of the avr is at 0 because that's easy to remember.
No, they're not. The method I gave you ensures you're not clipping the input to the MiniDSP or lets you determine if you are clipping it. The method you employed only ensure you're not going to add additional clipping at the output of the MiniDSP. You have no idea if the input is being clipped or not.
Stereodude is offline
post #62 of 69 Old 06-21-2019, 04:07 PM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 672
I'm sure you're correct, the questions are only for my understanding. Being as I've attenuated the inputs of the minidsp so that the signal level never is higher than -10 while playing a 50hz -3dBFS sine wave, how could the inputs ever clip?
johnson636 is offline
post #63 of 69 Old 06-21-2019, 07:53 PM
Stereodude's Avatar
Liked: 2993
Where did you attenuate the inputs of the MiniDSP at?
post #64 of 69 Old 06-22-2019, 06:58 AM
johnson636's Avatar
Liked: 672
The input gain sliders.
Name:	50Hz Input.jpg
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
post #65 of 69 Old 06-22-2019, 07:43 AM
Stereodude's Avatar
Liked: 2993
Those sliders are a digital post input attenuation. They don't reduce the analog voltage going into the A/D converter. As such, they can't reduce clipping on the input.
post #66 of 69 Old 06-22-2019, 07:55 AM
johnson636's Avatar
Liked: 672
Got it. Why do people in the Minidsp thread imply that the inputs can be attenuated by those sliders. I got the method of preventing clipping the minidsp from a post in the minidsp thread and no one mentioned that was an incorrect method and will not prevent clipping.
post #67 of 69 Old 06-30-2019, 06:21 PM - Thread Starter
tjcinnamon's Avatar
Quoted: 1798 Post(s)
Liked: 483
Originally Posted by johnplayerson View Post
http://rolls.com/product/DA134
The rolls 134 will give you lots of gain and 4 outputs to boot for quite cheap. No infrasonic bass loss either. Probably work well for those with
the usual output gain problems even with a mini dsp. Here the unit would install after the dsp.
If you have a balanced mini dsp, I would suggest putting a matchbox ahead of it. As Wayne will tell you, there are plenty of matchboxs with
excellent specifications.
Personally I have a hard time seeing the 2 volt input as an issue. If it was, would it not be an issue already, if your supposed avr measured 9 volts or even 4 volts. My experience is that all rca outputs are for the most part inadequate in driving an XLR output. (throwing all the measuring out the window, to date I see no warnings for people to measure the rca outputs just to hook up other rca equipment, all rca equipement is suppose to be compatible)
Input Impedance: 10 KΩ
Max Input Level: +12 dBV
Output Impedance: 470 Ω
Max Output Level: +12 dB
Max Gain: 20 dB
S/N Ratio: >90 dB
Cross Talk: -70 dB (stereo)
Frequency Response: DC - 60 kHz, +/- 1 dB
THD: <.008%
Power: 15 VDC
Size: 6.5" x 3.5" x 1.5"
Weight: 1 lbs. 3 oz.
Thoughts about this Rolls vs the ART DJPre II? http://www.artproaudio.com/product/d...-preamplifier/
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #68 of 69 Old 06-30-2019, 06:32 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3705
That's a phono preamp.
"Phono EQ Standard Conforms to RIAA Curve"
notnyt is offline
post #69 of 69 Old 06-30-2019, 08:03 PM
FriscoDTM's Avatar
Quoted: 418 Post(s)
Liked: 389
I did a quick test of my 7702 at MV=0 using a -3dBfs 100Hz sine wave to channel 4, leaving Audyssey and the sub trim at normal use settings. I will try to find some time to do more measurements and see if/where clipping occurs. In this case the AVR seems to produce a clean looking 3.68V RMS signal.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
