What would you build? Sub wise? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Jk7.2
  • 1 Post By Mr. Electric Wiz
  • 2 Post By aron7awol
post #1 of 19 Old 06-16-2019, 03:00 PM - Thread Starter
grahamricho's Avatar
Hi all my room is 9 foot x 18 foot and is a dedicated av room, with a fixed projector screen.
I have built a baffle wall with DIYSG HTM 12 speakers built into the wall.
I have space under the main speakers for 2 x subwoofers and have bought 2 x Dayton Ultimax 18 inch drive units.
I now need to decide what enclose to put the Subwoofer drive units in? Sealed? Ported etc ?
The space I have for each subwoofer is 21.5 inch depth x 39.5 inch length x 27.5 inch height.
So what do i build? thanks
grahamricho is offline
post #2 of 19 Old 06-16-2019, 03:01 PM
Jk7.2's Avatar
Quoted: 1408 Post(s)
Liked: 2577
Use every inch of space, and build a ported cab tuned to 17 ish. Two of those will be sweet.
aron7awol likes this.
Jk7.2 is online now
post #3 of 19 Old 06-16-2019, 03:03 PM
Quoted: 1476 Post(s)
Liked: 1060
Check out the Marty thread.
Two full Marty’s are the way to go.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4 of 19 Old 06-16-2019, 03:09 PM
Mr. Electric Wiz's Avatar
Quoted: 112 Post(s)
Liked: 64
Or there’s always tapped horn. I’m about to build 2 Pico wreckers.
2_liter_ejturbo likes this.
Mr. Electric Wiz is online now
post #5 of 19 Old 06-16-2019, 03:10 PM - Thread Starter
Hi thanks but i dont have room for 2 full martys ?
post #6 of 19 Old 06-16-2019, 03:12 PM - Thread Starter
I can build 2 encloses to the sizes ive given but how do i work out the port length and size of the port? thanks
post #7 of 19 Old 06-16-2019, 03:13 PM
Liked: 1060
Oh sorry missed that part. There’s also the Marty Cube and others. Stonehenge maybe?
post #8 of 19 Old 06-16-2019, 03:14 PM - Thread Starter
Thanks, the stonehenge ?
post #9 of 19 Old 06-16-2019, 03:27 PM
d-rail34's Avatar
Quoted: 376 Post(s)
Liked: 709
It looks like a modified version of the Mini Marty (24" x 25.5" x 40") might work in your space, or perhaps a modified Johnny Sub design, which just a bit smaller than the Mini Marty @ 24" x 25.5" x 32". both can be laid on their sides to fit within your height requirements.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon: AVR-X2400H/Hsu Research: HB-1 Bookshelfs (4)/Hsu Research: HC-1 Center (1)/SVS: PB12 Plus (1)/Samsung: UN65H7150/Sony: UBP-X800/PC: Built by D-Rail
Bedroom - Blose: Cinemate II GS 2.1/Sony: XBR49X800E/XBox: One S
d-rail34 is offline
post #10 of 19 Old 06-16-2019, 03:45 PM - Thread Starter
So if i build a cabinet the sizes i said, how do i work out the port size and tuning?
Because both the mini marty and johnny sub are both deeper than my sizes ? thanks
post #11 of 19 Old 06-16-2019, 04:00 PM
Quoted: 112 Post(s)
Liked: 64
You really need to model it. WinISD is one free software example.
d-rail34 likes this.
post #12 of 19 Old 06-16-2019, 04:14 PM - Thread Starter
Thanks, ive had a quick look, how comes no dayton drivers are in the database?
post #13 of 19 Old 06-16-2019, 04:23 PM
Quoted: 2379 Post(s)
Liked: 10187
Did a quick model using your dimensions (~10cf net). 2 square ports, 5"x5"x44" long should bring tune in between 15-16Hz and should be flat in most rooms down to 15Hz at least.
Jk7.2 and d-rail34 like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #14 of 19 Old 06-16-2019, 04:28 PM - Thread Starter
Thank you, so the ports size can be any size the equals your 2 x 5" x 5" ? so 1 x 20" x 2.5" ? thanks
post #15 of 19 Old 06-16-2019, 04:29 PM
Jk7.2's Avatar
Liked: 2577
Thank you, so the ports can be any size the equals your 5" x 5" ? so 20" x 2.5" ? thanks
I’d go 3” tall.
My hst cabs are very similar size overall. 10cf. 3”x 17 X 44” ports.
The hst’s move a hell of a lot of air though.
Jk7.2 is online now
post #16 of 19 Old 06-16-2019, 04:36 PM - Thread Starter
Thanks, so how do you work out bracing in the actual volume of it? The more bracing you use the smaller the internal volume you have? thanks
post #17 of 19 Old 06-16-2019, 05:25 PM
Liked: 10187
I prefer square over slot personally, but a slot port is fine, just match the cross-sectional area and length.
The bracing won't take up enough space to make a significant difference. You should end up around the 10cf net internal that I estimated.
post #18 of 19 Old 06-18-2019, 07:33 PM
BassThatHz's Avatar
Quoted: 3679 Post(s)
Liked: 4171
Depending on the mounting depth you may have had the space for dual ported's in your baffle wall.
But if it's already finished or the depth isn't there then I guess it's a no-go.
In that case, just go with the biggest ported boxes you can make... that would likely be the largest boom-per-dollar for the effort.
I'd only recommend sealed if space is of great concern, or if your goal was maximum single-digits with an array of 18's... (not just 2).
BassThatHz is offline
post #19 of 19 Old 06-19-2019, 07:19 AM
Quoted: 12 Post(s)
Liked: 3
Just so you dont have to hunt too far, here are the winISD files for the Ultimax.
I would go the largest you can @ roughly 17 Hz. Keep in mind the port air velocity. As a good start, you can check out the Marty variations and push pull the sides to accomplish the same volumes that would fit
Jon C is offline
