LLT Subwoofer -WinISD design help - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Red Five
  • 1 Post By notnyt
post #1 of 9 Old 06-17-2019, 01:14 AM - Thread Starter
Liked: 0
Question LLT Subwoofer -WinISD design help
This is a first time build using UM18-22 powered with Inuke6k DSP.
Planning to build 2 to go behind the AT Screen
calling the pros & experts, please validate attached Specs and graphs.
Box Dimensions: 20" x 30" x 64" (DxWXH)
Volume at 19 cu.ft tuning at 14 Hz
Ports: 2 @ 3" X 8.875"; Port Length: 34"
1st PR came to ~198 Hz
The Box design with Port and corresponding graphs are attached.
Thank you for the advice..
Name:	SPL-Box Volume19ft3-Tuning14hz.jpg
ID:	2581014   Click image for larger version
Name:	RearPort Velocity18ms-Signal 800watts.jpg
ID:	2581016   Click image for larger version
Name:	Cone Excursion20-Vents2at 3by8.875 length34-1PR 198hz.jpg
ID:	2581018   Click image for larger version
Name:	Box 20-30-64 and Port Location.jpg
ID:	2581020   Click image for larger version
Name:	Port Orientation 2 -Bracing.jpg
SNcube is offline
post #2 of 9 Old 06-17-2019, 04:43 AM
Red Five's Avatar
Quoted: 397 Post(s)
Liked: 447
Use only 85% of the value given in WinISD, not the full 34", so 28.9". Then a you will need to subtract 3" more inches from the vent, with it exiting on a 90 degree angle the height is added to the vent length. 26" will be close to the end result, but with the shorter port you just added more volume, so the tune just got lower with the 26" vent.
SNcube likes this.
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #3 of 9 Old 06-18-2019, 02:05 PM
SteveCallas's Avatar
Quoted: 741 Post(s)
Liked: 683
If vent length only ends up being 26”, id increase the cross section to get it back up to 34”
SteveCallas is offline
post #4 of 9 Old 06-18-2019, 03:56 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3705
model as a single port, not two.
SNcube likes this.
notnyt is offline
post #5 of 9 Old 06-19-2019, 05:34 PM - Thread Starter
Liked: 0
Here's the new layout.
I modified the WinISd numbers with the exact (close enough) interior volume of 16 cuft and port tuning @14Hz. I got a port length of 39.5" with 1PR @ 171Hz.
When I lowered the tuning to 13Hz, the port length increased to 46.6" (which I can accommodate) but the 1PR dropped to 144Hz. ( I read some where that it should be above 160Hz. So, I decided to leave the tuning at 14Hz.
Gentlemen, am I on the right track?
@Red Five , I changed the port orientation (see attached). but what is the theory behind using 85% of prescribed port length?
@SteveCallas , thanks, Can you please check the new layout?
@notnyt , thank you. I changed it to single port 3"x 17.75"
@LTD02 , @eng-399
Name:	Final Design Layout_all.jpg
SNcube is offline
post #6 of 9 Old 06-19-2019, 05:46 PM
eng-399's Avatar
Quoted: 2419 Post(s)
Liked: 4965
eng-399 is offline
post #7 of 9 Old 06-19-2019, 05:54 PM
Red Five's Avatar
Quoted: 397 Post(s)
Liked: 447
I do not have sims handy at this time, but WinISD is off about 15% when calculating slot ports. The other option is model in Hornresp which I would if it were handy
post #8 of 9 Old 06-19-2019, 06:04 PM
Red Five's Avatar
Quoted: 397 Post(s)
Liked: 447
One other note, you are over 48"s so standing waves in the box are now a thing to consider. Pickup a pillow stuff if over that middle brace.
post #9 of 9 Old 06-20-2019, 04:40 AM
Quoted: 741 Post(s)
Liked: 683
I would shrink your FR to 10-100hz when modeling to see more detail. I would never use a 14hz highpass filter on a 14hz tuned subwoofer, drop it much lower.
