Parts Express B&C product giveaway - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By ClevelandFreeman
post #1 of 11 Old 06-17-2019, 08:34 PM - Thread Starter
So I won the following from the Parts Express giveaway:
https://www.parts-express.com/bc-14n...ofer--294-5995
https://www.parts-express.com/bc-de7...bolt--294-6044
https://www.parts-express.com/bc-me9...-bolt--294-626
Any suggestions on speaker designs?
kagtha likes this.
ClevelandFreeman is offline
post #2 of 11 Old 06-17-2019, 08:48 PM
Quoted: 105 Post(s)
Liked: 56
Cool! Looks like some nice stuff.
Michael Rodriguez is offline
post #3 of 11 Old 06-17-2019, 09:02 PM - Thread Starter
I know right? I might build a nice stereo set for my room.
post #4 of 11 Old 06-17-2019, 09:08 PM
Quoted: 105 Post(s)
Liked: 56
I haven't heard of any kits that work with this driver combo. I don't know much about design either.
Do you think that you can use the vented recommendation tuned to 53hz in a two way with the horn and a good L-pad?
Maybe you can play around in Xsim for a while and see where it gets you. I don't know what order of crossover you would need.
post #5 of 11 Old 06-19-2019, 05:22 AM
Quoted: 36 Post(s)
Originally Posted by ClevelandFreeman View Post
Wow that is awesome - those look like some excellent drivers!
The good news is they were free!
The bad news is that you will need to be able to build the boxes and then measure them to start a crossover design. Just an L-pad on the horn is not going to work well.
Do you have a UMIK-1 or other microphone? Any experience doing crossovers before? You could do an active system which is slightly easier than a passive crossover but you still need to be able to measure the driver responses in box, plus you will need 4 channels of amplification.
Sweet win!
scottvalentin is online now
post #6 of 11 Old 06-23-2019, 09:14 PM - Thread Starter
Sweet win!
The only crossover experience that I are with active ones, ie miniDSP. I do have a UMIK-1. I am trying to see if I can use a miniDSP balanced 2 X 4. I have built boxes before but only for subwoofers. I have never built one for a full range speaker before. The problem with an active setup is, like you said, I will need 4 channels of amplification.
I might try to find a passive crossover that will work, in that case I will only need a 2 channel amp.
I am currently trying to find some kind of software to help me design the box.
post #7 of 11 Old 06-24-2019, 06:24 AM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 902
I think B&C has generic crossovers that might work ok. Look for the 1200hz xo. They’re a little bit expensive though.
Samps is offline
post #8 of 11 Old 06-24-2019, 01:53 PM
kagtha's Avatar
Quoted: 105 Post(s)
Liked: 121
Woooooweeee!
Lucky duck!
That compression driver is the tits!
But so is the "14"!
Congratulations.
Sent from my Pixel 3a using Tapatalk
Bedroom Audio: Two Shallow Under Bed PA310-8 12's energized by an SPA250DSP Plate Amp. Two BST-1s. 75 Watt 7.1 Onkyo AVR with Five Martin Logan MLT-2 LCR & Surrounds.
Living Room Audio: One Behringer NX6000D flexing four PA460-8's in a contemporary VBSS credenza build, 100 Watt 5.1 Sony AVR zapping Three horizontal Elusive 1099s LCRs and Two Martin Logan MLT-2 Surrounds. Two BST-1 Bass Shakers charged by the MLT-2 Sub Amp.
kagtha is offline
post #9 of 11 Old 06-24-2019, 08:19 PM - Thread Starter
Thanks, I'll see if I can find them.
post #10 of 11 Old 06-24-2019, 08:20 PM - Thread Starter
Originally Posted by kagtha View Post
Woooooweeee!
Lucky duck!
But so is the "14"!
Congratulations.
Thanks dude. I am so excited.
post #11 of 11 Old 08-13-2019, 08:08 PM - Thread Starter
Unhappy
Finally closed on my house and had the speakers shipped. They are finally here. I don't know if I will have time to build these though....
ID:	2602684   Click image for larger version
ID:	2602686   Click image for larger version
ID:	2602688   Click image for larger version
ID:	2602690   Click image for larger version
ID:	2602694   Click image for larger version
ID:	2602696   Click image for larger version
ID:	2602698   Click image for larger version
ID:	2602700   Click image for larger version
Name:	B&C DE780TN.PNG
ID:	2602704   Click image for larger version
Name:	B&C 14NDL88.PNG
ID:	2602706   Click image for larger version
kagtha likes this.
