Possible 1099/Volt-10 build - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By SPStorm Productions
  • 2 Post By Erich H
  • 1 Post By Randy_J
post #1 of 6 Old 06-18-2019, 10:26 PM - Thread Starter
Liked: 2
I am pretty sure I want to go DIY for my bedroom 7.2.4 setup. My main goal is watching movies (probably 95% / 5% video games and music). I have been reading about the diysg 1099s and Volt 10s. I would really appreciate some feedback on my proposed plan. I have uploaded a couple sketchup screenshots. The room I want to watch movies in is a 14' x 14' bedroom that I may remove the bed and desk from in the future when people move out of the house. The components will go in a walk in closet attached to the bedroom. I have wanted an atmos setup for years. I just bought an lg 65" OLED and a Denon x4500h is on the way. I also ordered a AudioSource AMP100VS to allow me to use the 2 extra un-amped channels on the receiver (so I will have 11.2). Also on the way is 2 Seatcraft Equinox seats. I was thinking of putting casters on the seats to be able to roll them to the one side or the other when not in movie mode. All the speakers in the sketchup are placed at the Dolby recommended angles (well, at least what I think are the recommended angles). The L/R are 26°, the L/R Surrounds are at 90°, the L/R Rear Surrounds are at ~142°, the in-ceiling atmos are in line with the L/R fronts and are 45° from the listener position (when looking at the side view).
I have some questions that I would love to get answered and/or general feedback:
1) Am I crazy to stuff all this in a 14' x 14' space that has a full bed and a desk. So, is 7.2.4 going to sound good in this space?
2) Are the 1099s/Volt-10s a good choice for me? I considered Alchemy (fusion) 8s for L/R/C and Volt-6s for surround/atmos, I am ok with having overkill if the sound will be better with the 1099s/Volt10s. At some point I may even tear down the wall to the adjacent bedroom and build a real home theater like some of you guys have. I am jealous as hell!
3) Speaker height - I think I have been reading that the Left/Right/Center and surround speakers should be at ear level (the tweeter horn on the 1099s), is that correct? If so, should I raise my TV so the center can be at ear level. I wanted the TV to be centered at eye level which would put the center 1099 lower than ear level. I was thinking of having all the floor speakers at ear level except the center which would be slightly lower. If this would work, should I angle the center up a bit to point it towards ear level?
4) Volt-10 surrounds. Is it ok to mount them in the walls/ceilings without enclosures? If so, does anyone know how deep the speaker alone is? Would it fit in a 3.5 inch wall?
5) Should the rear surrounds be angled or are the volts ok to mount flat on/in the wall since they have uniform off-axis performance?
6) The Left Surround by the window - would it be ok to lower that one below the window so I could mount it in the wall and not block the window? If not, I can put it on a stand.
If this all looks good to you guys, I will be patiently waiting for the 1099s to come back in stock. In the meantime I will order the Volts and use my current Polks for L/R/C.
Thanks in advance!
-Sean
ID:	2581818   Click image for larger version
SPStorm Productions is offline
post #2 of 6 Old 06-19-2019, 01:27 AM - Thread Starter
Liked: 2
I actually went ahead and ordered 3 1299s and 8 volt-10s. I figure the worst thing that could happen is I end up needing to build a dedicated home theater for these.
ian#77 likes this.
post #3 of 6 Old 06-19-2019, 05:33 AM
ian#77's Avatar
Quoted: 23 Post(s)
Did Eric say if he had the 1299s in stock? i dont think you could go wrong with any of those speakers.
DENON X6500H,
FRONTS SVS ULTRA CENTER,SVS ULTRA BOOKSHELF'S
SUBS SVS PB-3000'S x2 UM18 x2
SURROUNDS YAMAHA NS-333 SIDE KLIPSCH QUINTET REAR
RAPTOR 700 FOR WHEN YOU NEED TO STOP WATCHING MOVIES
ian#77 is offline
post #4 of 6 Old 06-19-2019, 05:54 AM - Thread Starter
Liked: 2
Thanks. I was able to place the order through the website. I didn’t talk to anyone. I will start a build thread when I get started.
ian#77 likes this.
post #5 of 6 Old 06-19-2019, 10:29 AM
Erich H's Avatar
Quoted: 1855 Post(s)
Liked: 2659
Fusion-8's might be too powerful for that room.
You'll need some powerful subs to keep up with the 1299's. Like multiple 18's.
Jk7.2 and d-rail34 like this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #6 of 6 Old 06-20-2019, 07:19 AM
Quoted: 174 Post(s)
Liked: 132
I am wanting to eventually run titans and volt 10s in my 15 x 17 foot room. I have a pair of Hs-24 for lows but am considering a pair of submaximus with b&c 21s for the mid bass. So i think you are just fine.
scottvalentin likes this.
Randy_J is offline
diysg diy 1099 volt-10 7.1.4
