Question on setting up crown on ypao - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By johnson636
post #1 of 6 Old 06-21-2019, 08:32 PM - Thread Starter
Quoted: 71 Post(s)
Liked: 6
I'm almost done with my subs and most likely will be setting them up tonight, I'm just going by memory of browsing the forums a long time ago but I turn the knobs all the way up on the crown xls 2502 when I run ypao right?
valleyslim is offline
post #2 of 6 Old 06-22-2019, 07:04 AM
johnson636's Avatar
Quoted: 1150 Post(s)
Liked: 679
I don't know about anyone else, but I can't understand what you're trying to say Your words are garbled up.
stegen likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 6 Old 06-22-2019, 07:09 AM
nbk13nw's Avatar
Quoted: 73 Post(s)
Liked: 43
Start around the 11 or 12 oclock position on the crown. See what levels rhe AVR sets the subs. Aim for a level around -9 to -3. If the level is set low then turn up on the crown if needed or run the level on the AVR up to maybe -3 or so. Set it to where you like it, but personally i would not go above -3 on the AVR, adjust the crown amp to bring it up a bit to your preference
Onkyo TX RZ830, Chane 3600, AudioSource AMP100VS, XBox One X, Samsung UBD-K8500, NVIDIA Shield, D-Link 16-Port Gigabit Switch, Caavo, Control Center, 2 x KEF Q900's Mains, 1 x KEF Q650C Center, 4 x KEF Q100's Surrounds, 4 x RSL C34E's ATMOS, 4 x Chane SBE-118's
nbk13nw is online now
post #4 of 6 Old 06-24-2019, 12:30 PM
Quoted: 87 Post(s)
Liked: 91
As you're reading it, replace each s with an s.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is offline
post #5 of 6 Old 06-24-2019, 12:33 PM
RGrizzzz's Avatar
Quoted: 29 Post(s)
Newbie question. Why would you want the YPAO adjustment down in the -9 to -3 range? I'd think you'd want it as close to 0 as possible, so you have the most flexibility out of the knobs on your sub's amp.
Ron
RGrizzzz is offline
post #6 of 6 Old 06-24-2019, 12:42 PM
Quoted: 87 Post(s)
Liked: 91
Ron
So you don't clip the input on the Crown.
DIY 110" AT Screen
