Do I need to hire someone to fix the DFB for the full marty? (pics inside) - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #1 of 62 Old 06-23-2019, 06:43 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
I'm pretty sure the DFB is messed up beyond repair, but I wanted to get some more opinions on it.
The screws for the UM18 will drill directly into the 2nd MDF board. Will this have any negative consequences? Do I need to get the front of this redone?
Any help is appreciated.
ID:	2583694   Click image for larger version
Jk7.2 likes this.
TIV13 is offline
post #2 of 62 Old 06-23-2019, 06:55 PM
hd0823's Avatar
Quoted: 715 Post(s)
Liked: 1311
You can just install would blocks behind where the screws will be on the second baffle
Sent from my SM-N950U using Tapatalk
filtor1 likes this.
hd0823 is online now
post #3 of 62 Old 06-23-2019, 07:41 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Great idea. I would have never thought of that.
What is the best method to glue the DFB wood together? Liquid glue? Titebond with a ton of clamps?
TIV13 is offline
post #4 of 62 Old 06-23-2019, 07:48 PM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 669
Just use the same glue used to secure you box together.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 62 Old 06-23-2019, 08:18 PM
hd0823's Avatar
Quoted: 715 Post(s)
Liked: 1311
Yup I love pl3 that stuff is strong put the sub in take a marker pen ect and mark where the holes are at. Take your blocks put glue on them and put them behind the baffle where your dots are and clamp them down.
post #6 of 62 Old 06-24-2019, 11:23 AM
sassuki's Avatar
Quoted: 84 Post(s)
Liked: 190
I’m not sure what DFB is, but here is how I did some reinforcement for my mounting bolts. I used 3/4 oak hard wood to lessen the chance of stripping them out.
kagtha, fill35U, filtor1 and 1 others like this.
sassuki is offline
post #7 of 62 Old 06-24-2019, 11:25 AM
Jk7.2's Avatar
Quoted: 1406 Post(s)
Liked: 2569
I’m guessing double front baffle?
Craig S King likes this.
Jk7.2 is online now
post #8 of 62 Old 06-24-2019, 11:39 AM
Red Five's Avatar
Quoted: 385 Post(s)
Liked: 433
I went a little overkill, but I used longer screws to make sure it did not go anywhere. A few one inch chunks of 2x4 will do the trick if you have one lying around.
kagtha, fill35U and Heide264 like this.
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #9 of 62 Old 06-24-2019, 01:51 PM
sassuki's Avatar
Quoted: 84 Post(s)
Liked: 190
Oh... duh. Makes sense. Thanks
Jk7.2 likes this.
sassuki is offline
post #10 of 62 Old 06-25-2019, 02:31 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Great idea thank you.
Why did you use the metal in the wood where the screw goes?
TIV13 is offline
post #11 of 62 Old 06-25-2019, 05:07 AM
jcmccorm's Avatar
Quoted: 594 Post(s)
Liked: 443
He's using threaded machine screws and not wood screws. Those metal things, blind nuts they're called, push into the wood. They are threaded so that when you put the screw in and tighten it, they act like a "regular" nut. They just don't move is all.
jcmccorm is offline
post #12 of 62 Old 06-25-2019, 09:02 AM
sassuki's Avatar
Quoted: 84 Post(s)
Liked: 190
Jcmcorm was right. Those are the T-Nuts. I like the look of the machine bolt more than a panhead screw, so I used these:
https://www.parts-express.com/parts-...g-kit--260-778
I also fear stripping out MDF with a regular screw, so these felt like the better option.
sassuki is offline
post #13 of 62 Old 06-26-2019, 04:03 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
I may consider that myself.
Not sure where else to ask this, so sorry for the noob question. Is it ok to go ahead and glue my DFB together before I glue everything else together? I dont think it'd be easy to get a good seal trying to do them together while doing the rest of the speaker.
TIV13 is offline
post #14 of 62 Old 06-26-2019, 07:31 AM
asarose247's Avatar
Quoted: 1197 Post(s)
Liked: 1054
I saw and then did this about 6 years ago. . .
for 3 THTLP's and my 2 Lhorns
requires some extra time wrt spot-on alignment, virtual pre-assembly for zero defects in hitting all the right points for seating, sealing
threads should be chased with a tap no matter how careful you are
5 minute epoxy
and a anti-rotation screw
it's gonna say put . . .
LTD02 and sealmaniac like this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #15 of 62 Old 06-26-2019, 01:40 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
5 minute epoxy
Does home depot carry anything like that?
TIV13 is offline
post #16 of 62 Old 06-26-2019, 02:11 PM
asarose247's Avatar
Liked: 1054
that's likely Gorilla Glue 5 minute epoxy, very available , HD too, google it
I'd do 2 T-nuts at a time , so small batches and no worries about it cooking off too fast - and it does
i put only a smidge into the hole wrt to the t-nut barrel -
AFTER i had a bout 1/8" insertion , trying to keep the threads virgin
of course everything has been dry-fit(ted) to death
including driver fit to that part of the baffle
IF there is some t-nut metal overhang beyond the edge( which you've slightly eased)that you think might be hazardous to driver surround travel at "full" throttle,
file / grind it off
take you time and enjoy problem solving process / procedure.
you want it right, once, the first time.
8-24's should be plenty of good holding power, maybe washer head for more surface area squish
I usually use a 2" wide fiber re-enforced 1/8th" plumbing tape as gasket material. cut to a more usable BUT FULL width
HD https://www.homedepot.com/p/Armacell...8230/100539553
which answers the question: did I compromise on getting this sucka' sealed?
post #17 of 62 Old 06-26-2019, 05:30 PM
smcmillan2's Avatar
Quoted: 800 Post(s)
Liked: 703
No disrespect to anyone using other fasteners, but in my case I have found using #8 pan head screws have held all my drivers in place.
Your use case may dictate stronger fasteners, my sealed UM18s have been fine so far. We listen at -20 to -10 so take that into consideration. Horses for courses, everyone has different issues/requirements.
smcmillan2 is online now
post #18 of 62 Old 06-26-2019, 05:35 PM
hd0823's Avatar
Quoted: 715 Post(s)
Liked: 1311
I used 2 in spax power lags my last build and will be using these from now on. Easy and super strong holding power
Purenv likes this.
post #19 of 62 Old 06-27-2019, 06:14 AM
Purenv's Avatar
Quoted: 175 Post(s)
Liked: 119
^^^^^ those will hold forever....
Purenv is online now
post #20 of 62 Old 06-27-2019, 07:30 AM
hd0823's Avatar
Quoted: 715 Post(s)
Liked: 1311
Lol yeah theres something about using a ratchet to tighten down your sub fasteners that Gives off level of confidence
post #21 of 62 Old 06-27-2019, 09:09 AM
Purenv's Avatar
Quoted: 175 Post(s)
Liked: 119
HD0823, do you happen to have a link for anyone who might be interested in getting those fasteners?
post #22 of 62 Old 06-27-2019, 09:31 AM
hd0823's Avatar
Quoted: 715 Post(s)
Liked: 1311
Yup right here and there cheap so that helps.
https://www.homedepot.com/p/SPAX-1-4...0507/202041031
post #23 of 62 Old 06-27-2019, 01:33 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Would appreciate any confirmation this is the correct action to take.
"Not sure where else to ask this, so sorry for the noob question. Is it ok to go ahead and glue my DFB together before I glue everything else together? I dont think it'd be easy to get a good seal trying to do them together while doing the rest of the speaker."
TIV13 is offline
post #24 of 62 Old 06-27-2019, 01:49 PM
hd0823's Avatar
Quoted: 715 Post(s)
Liked: 1311
I did my double front baffle after on the cyclops just played the box on it's back side when I was working and yes I recall the um having 8 mounting holes so 8 per box . There also isnt any right or wrong faster out of the ones mentioned I've used the tnuts=slab nurs also. You just have to make sure everything is aligned when Using them.
TIV13 likes this.
post #25 of 62 Old 06-28-2019, 07:22 PM
acras13's Avatar
Quoted: 316 Post(s)
Liked: 292
Not an expert on subwoofer boxes having only made 3-4 in recent times , but I have glued the double baffle together before even routing the driver hole on all of them . I then test fit everything to make sure I didn't mess up any measurements , square up if I did , then mark which way is up then route the driver hole . I personally prefer titebond or whatever wood glue you prefer for gluing panels together , saving the PL for joints . It's far easier to get a layer of titebond spread over the entire surface , and I feel that is the best way to join the DFB . I don't know if it is better than stripes of PL , or if it even makes a difference , but it's my way .
TIV13 likes this.
Turn that $*!# UP!! --Beethoven
acras13 is offline
post #26 of 62 Old 06-29-2019, 03:22 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Anyone have a lead on where I can get a mattress topper from? My walmart only has one brand but its not all egg crate, it has some other stupid ass designs on it. Then they have memory foam ones which aren't the most affordable.
This is the one from my local walmart.
https://www.walmart.com/ip/Mainstays...-Each/10083472
Does the design matter, or does it just need to be foam?
Found this one if the above isn't what I need.
https://www.walmart.com/ip/Lightweig...lows/484123489
TIV13 is offline
post #27 of 62 Old 06-29-2019, 02:51 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Anyone able to help please?
TIV13 is offline
post #28 of 62 Old 06-29-2019, 03:22 PM
Quoted: 28 Post(s)
The design doesn't matter, just needs to be foam that is permeable (air can pass through it). The first one looks fine, second one also looks fine. Memory foam won't work since it doesn't let air pass through easily (or at all).
scottvalentin is online now
post #29 of 62 Old 06-29-2019, 03:24 PM
asarose247's Avatar
Liked: 1054
foam topper egg crate style
Amazon . . .
also,
polyester pillows can be strategically positioned wrt internal resonance damping . .
somebody out there can address that . .
the entire inside of the cab doesn't need all surfaces covered
and those who know better may suggest where to stick your pillow- no kidding
in this pic, a MBM tuned dual PA460 sub needed, per @LTD02 , just a normal pillow, stapled to braces,
that 1 was q queen sized one for a tab extra polyester fill - walmart
with about 1K off a inuke 6K amp, it does oh-tay
oddly when comparing sizes and amount of actual fill, by weight, usually a pillow brings the best value per pound as opposed to pre-bagged fill as may be used for not HT /Sub projects
but who want to do that?
Name:	VBSS red base and 2 sections with black.jpg
ID:	2585686   Click image for larger version
Name:	VBSS ready  for spray semigloss.jpg
post #30 of 62 Old 06-29-2019, 03:43 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Thank you so much!
TIV13 is offline
