Dual B&C 21DS115-4 Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 49Likes
post #31 of 93 Old 07-04-2019, 07:07 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Originally Posted by Purenv View Post
Are you replacing or adding to your 2 Faital Pro subs?
I will be replacing them with these, according to my umik one the faital were capable of pretty much 122db across the spectrum, although not sure with how much distortion. These model about +6db across the spectrum each compared to the faitals. So hoping should gain quite a bit of headroom, hence leaning more towards 4ohm. What is the best fan for the inuke to keep it cool and quiet?
Sent from my SM-G950F using Tapatalk
monty6400 is offline
post #32 of 93 Old 07-04-2019, 07:09 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Realistically how much more power can the inuke give dual 4ohm compared to dual 8ohm?
post #33 of 93 Old 07-04-2019, 07:19 AM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
About 1300wpc @ 8 ohm vs about 2000wpc @ 4 ohm, according to this:
monty6400 likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #34 of 93 Old 07-04-2019, 10:28 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Thanks guys, really torn between the 4 and the 8 now, maybe I'm overthinking it all! Leaning for towards the 4 but if the inuke can pretty much push the same amount of voltage into both loads, the 8ohm will obviously be easier to drive!
post #35 of 93 Old 07-04-2019, 11:02 AM
Purenv's Avatar
Quoted: 184 Post(s)
Liked: 122
Originally Posted by smcmillan2 View Post
About 1300wpc @ 8 ohm vs about 2000wpc @ 4 ohm, according to this: https://www.youtube.com/watch?v=73Z2fNcGGDI
depending on sound content... between 300-650 watts. like i said earlier, at that volume only a microphone whould be able to tell the difference. as a side note the amp will run hotter and draw more power from the outlet to get to put out that extra power. I will be running to LaVoce 21s 8ohm for that very purpose to run cooler, less power draw fromoutlet, and equiptment will see less strain.
Purenv is offline
post #36 of 93 Old 07-04-2019, 11:08 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Yeah just modeled my box at 1100w vs 1500w and the difference is too little to care, looks like I'll go with the 8 if it means happier equipment! I would buy the lavoces but I am shipping from France, as the lavoces are heavier, but slightly cheaper, the total incl shipping is the same, so figured may aswell go with the B&C!
EndersShadow likes this.
post #37 of 93 Old 07-04-2019, 11:24 AM
3ll3d00d's Avatar
Quoted: 2336 Post(s)
Liked: 2478
DCR is irrelevant for a ported sub as you will add a HPF to lop off the bottom end anyway. Impedance minimum will be around tune in this case and will depend on the enclosure itself. Model it to verify.
IIRC the discussion on this driver on data-bass mentioned that a bridged inuke 3000 is pretty much a perfect fit for the 4 ohm version.
3ll3d00d is online now
post #38 of 93 Old 07-04-2019, 11:41 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
What would you go with, people saying 4ohm is good for 1 channel of the 6000 but running 4ohm dual channels means the amp runs into problems. Modeled 8ohm yellow vs 4ohm grey!
post #39 of 93 Old 07-04-2019, 01:21 PM
3ll3d00d's Avatar
Liked: 2478
who says it runs into problems? as far as I recall, you lose about 1dB when comparing a 6000 vs 2 separate 3000s. Are you really going to notice that? seems a bit unlikely to me. Still you have the choice either way. I would think it's also a question of where the amps are, quietly cooling 2 3000s is probably easier than 1 6000.
post #40 of 93 Old 07-04-2019, 01:26 PM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Earlier someone said during testing both channels at 4ohms it could shut down and that they basically put out give or take 300w ish 4ohm vs 8ohm. The amp is quite close!
post #41 of 93 Old 07-04-2019, 01:28 PM
3ll3d00d's Avatar
Liked: 2478
300w? you mean difference between the two? if so then yes this is in the region of 1dB given inuke power output. Like I say, do you really care about 1dB here or there at 120-125dB?
if you drive any amp hard enough it will shut down or protect itself in some way
post #42 of 93 Old 07-04-2019, 01:34 PM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Sorry, I meant the difference between dual 8ohm or dual 4ohm on the inuke, my thinking is if the inuke is only happy pushing a similar (300wish) into 4ohm vs 8ohm, may aswell go with 8 as this should be easier and cooler to run?
post #43 of 93 Old 07-04-2019, 01:40 PM
3ll3d00d's Avatar
Liked: 2478
I don't follow, what is 300wish?
post #44 of 93 Old 07-04-2019, 01:44 PM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Someone mentioned the difference between what the inuke can push dual into 4ohm vs 8ohm is around 300w. Ie it can do dual 8ohm at 1100rms all day but goes into protect mode doing more than 1500w dual 4ohm. I think I am majorly overthinking it and the difference probably wont be that great. But a few have no mentioned the inuke 6000 isn't great into dual 4ohms, but most builds on this forum seem to use the inuke 6000 with the 4ohm versions so I'm a bit puzzled!
post #45 of 93 Old 07-04-2019, 01:49 PM
3ll3d00d's Avatar
Liked: 2478
this is what I have been saying
a 300W difference at these power levels is in the region of 1dB so it is true to say that a single inuke 6000 will give up slightly before an inuke 3000
my point is that you're in a home environment, are you really going to notice a 1dB difference when you're listening at 120-125dB peaks?
lets put it this way, this is basically in the region of reference level listening, can you tell the difference between listening at reference and -1?
if yes, buy 2 3000s
if no, be happy with a 6000
if you're putting the 6000 into a location in which you can hear the fans and you have space then you may want 2 3000s anyway to make it easier to cool them (and hence encourage a longer life)
post #46 of 93 Old 07-04-2019, 01:51 PM
3ll3d00d's Avatar
Liked: 2478
btw the difference is that 300W sounds like loads, 1dB not so much
marketing eh
post #47 of 93 Old 07-04-2019, 01:53 PM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
if yes, buy 2 3000s
So back to original question, 4 or 8ohm driver? I'm leaning towards 8 to keep the inuke happy?
post #48 of 93 Old 07-04-2019, 02:02 PM
3ll3d00d's Avatar
Liked: 2478
I would go 4
You can always turn it down a bit if you need to
post #49 of 93 Old 07-04-2019, 02:20 PM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
If I go 4 I'll get these fans, and set a limiter at 1.5kw. Noctua NF-A8 PWM
post #50 of 93 Old 07-04-2019, 03:14 PM
N8DOGG's Avatar
Quoted: 1304 Post(s)
Liked: 1534
Go 4ohms, they will be easier to sell if you ever need to.
N8DOGG is offline
post #51 of 93 Old 07-04-2019, 04:23 PM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Think I will, hopefully wont run into any problems!
post #52 of 93 Old 07-05-2019, 03:50 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Going to order the 4ohms on Monday when my old subs arrive with their new owner, and hopefully begin building when I get back from holiday, do all my box calculations check out. Final box is 88x80x60, with 84.4x6x115 cm long port. Around 350l or 12cuft tuned to 18hz after driver and port displacement.
post #53 of 93 Old 07-05-2019, 03:52 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
1st port resonance is 155hz, velocity max is 20ms-1 at 1500w, 15mm excursion.
post #54 of 93 Old 07-07-2019, 03:06 PM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Final cab design with bracing and lower tune at 17hz. Does this bracing look sufficient?
ID:	2588572   Click image for larger version
Red Five and kagtha like this.
post #55 of 93 Old 07-07-2019, 05:45 PM
Red Five's Avatar
Quoted: 443 Post(s)
Liked: 287
The bracing is more than sufficient.
monty6400 and kagtha like this.
Stormbreaker (For Sale) | Wisconsin Home Theater Meet Thread
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #56 of 93 Old 07-07-2019, 05:50 PM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Ever since I underbraced my first cabinet and heard panel resonances I've had worries about bracing ever since. Post traumatic bracing disorder.
notfastenough likes this.
post #57 of 93 Old 07-08-2019, 11:42 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
Done the fan mod today!
OJ Bartley likes this.
post #58 of 93 Old 07-09-2019, 01:52 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
4ohm drivers ordered, should be here next Wednesday! See you guys then!
post #59 of 93 Old 07-09-2019, 11:15 PM
kagtha's Avatar
Quoted: 106 Post(s)
Liked: 123
Do tell more about this. What do they sound like? I always thought.. wow here is another engineer... Over engineering.
But I think I might be on the wrong side of this.
I understand resonance disapates energy but how much? Does it sound that much better super still!?
Sent from my Pixel 3a using Tapatalk
Bedroom Audio: Two Shallow Under Bed PA310-8 12's energized by an SPA250DSP Plate Amp. Two BST-1s. 75 Watt 7.1 Onkyo AVR with Five Martin Logan MLT-2 LCR & Surrounds.
Living Room Audio: One Behringer NX6000D flexing four PA460-8's in a contemporary VBSS credenza build, 100 Watt 5.1 Sony AVR zapping Three horizontal Elusive 1099s LCRs and Two Martin Logan MLT-2 Surrounds. Two BST-1 Bass Shakers charged by the MLT-2 Sub Amp.
kagtha is offline
post #60 of 93 Old 07-13-2019, 03:20 AM - Thread Starter
Quoted: 98 Post(s)
Liked: 151
It only used to really happen at certain frequencies, but parts of the back panel used to vibrate and make a loud resonating sound. I've read somewhere that if you sand the box with disc sander, and can get a panel to sing it isn't braced enough!
kagtha likes this.
