Dual B&C 21DS115-4 Build - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 42Likes
post #61 of 88 Old 07-13-2019, 04:00 AM
bear123's Avatar
Quoted: 2552 Post(s)
Liked: 3995
I don't see any bracing running across the back panel of the enclosure other than around the outer edges.....its seems to me this is leaving a quite large central area unbraced. Maybe two shallow braces across the center perpendicular to each other and then expanding outwards towards the baffle as you clear the driver.
bear123 is online now
post #62 of 88 Old 07-13-2019, 04:50 AM
Quoted: 421 Post(s)
Liked: 348
Since that's the area of the port, the port itself should add quite a bit of panel stiffness, especially with 4 runners.
Trimlock is offline
post #63 of 88 Old 07-15-2019, 07:39 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Yeah I was thinking the port rails should add a lot of stiffness to the back port panel. Although I will probably add some more bracing on there anyway, better to be over braced than under!
Sent from my SM-G950F using Tapatalk
monty6400 is offline
post #64 of 88 Old 07-18-2019, 05:30 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Drivers arrived, however they've sent me an 8ohm and 4ohm instead of 2 4ohms, nothing is ever straightforward!
post #65 of 88 Old 07-18-2019, 07:12 AM
michael hurd's Avatar
Quoted: 635 Post(s)
Liked: 673
The 8 ohm 21DS115's have slightly less motor strength than the 4 ohm drivers. In practice, you might have a little less than 3 dB loss in output vs the 4 ohm drivers. I wouldn't sweat it, unless they have a free return policy.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #66 of 88 Old 07-18-2019, 07:50 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
I've emailed and they said they would send the 4ohm no problem, and are picking the 8ohm up tomorrow, the ocd in me wouldn't want a mix!
chadsmith013 and kagtha like this.
post #67 of 88 Old 07-18-2019, 03:00 PM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Breaking them in!
kevings, Jk7.2 and kagtha like this.
post #68 of 88 Old 07-19-2019, 05:21 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Managed to fit window bracing onto the cut sheet so may aswell use them. Final design, getting the wood cut this weekend! Also forgot to mention, will the port rails not running flush to the baffles cause any issues, they are set 2" deep into the port as I prefer this look aesthetically?
ID:	2592470   Click image for larger version
Red Five likes this.
post #69 of 88 Old 07-19-2019, 05:35 AM
Red Five's Avatar
Quoted: 432 Post(s)
Liked: 282
I would not worry too much about the port rails. If anything you might bump your tune up a couple tenths of a Hz. If it was modeled on WinISD it will probably come in a touch low anyway
monty6400 likes this.
Stormbreaker (For Sale) | Wisconsin Home Theater Meet Thread
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #70 of 88 Old 07-21-2019, 04:58 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Got some of the bigger cuts done at local diy store, waiting on a new circular saw and router to do the rest, should be here by midweek. Also got the cables made as the drivers I've got have the spade terminals not springs!
kagtha likes this.
post #71 of 88 Old 07-21-2019, 05:36 AM
dasa2131's Avatar
Quoted: 55 Post(s)
Liked: 59
Those subs are going to be killer! Can't wait to see more progress.
Dave
dasa2131 is offline
post #72 of 88 Old 07-21-2019, 01:47 PM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
ETA for saw and router is Thursday so no action until then, after that should be pretty fast turnaround. Thinking around a week.
post #73 of 88 Old 07-25-2019, 05:25 PM
kagtha's Avatar
Quoted: 105 Post(s)
Liked: 121
Soooo beautiful. Subscribed!
Bedroom Audio: Two Shallow Under Bed PA310-8 12's energized by an SPA250DSP Plate Amp. Two BST-1s. 75 Watt 7.1 Onkyo AVR with Five Martin Logan MLT-2 LCR & Surrounds.
Living Room Audio: One Behringer NX6000D flexing four PA460-8's in a contemporary VBSS credenza build, 100 Watt 5.1 Sony AVR zapping Three horizontal Elusive 1099s LCRs and Two Martin Logan MLT-2 Surrounds. Two BST-1 Bass Shakers charged by the MLT-2 Sub Amp.
kagtha is offline
post #74 of 88 Old 07-26-2019, 12:07 PM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Second driver arrived, saw and router arrived, however rain has also arrived!
post #75 of 88 Old 08-04-2019, 07:27 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Finally got all the wood and baffles cut, just got to do the bracing and start gluing!
post #76 of 88 Old 08-04-2019, 07:28 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Pics
post #77 of 88 Old 08-04-2019, 08:17 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Mock fit, all looks good!
post #78 of 88 Old 08-05-2019, 07:13 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Started gluing, boxes should be ready by the end of the week hopefully!
chadsmith013 likes this.
post #79 of 88 Old 08-06-2019, 08:20 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Bracing started, what an absolute pita!
post #80 of 88 Old 08-06-2019, 08:28 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Looks good and is very sturdy but takes ages!
post #81 of 88 Old 08-06-2019, 12:25 PM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Like a glove!
LTD02, chadsmith013, Rcris and 1 others like this.
post #82 of 88 Old 08-14-2019, 03:30 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Bit more progress but going slowly! Should have them done in the next week or two.
LTD02 likes this.
post #83 of 88 Old 08-14-2019, 04:02 AM
Quoted: 31 Post(s)
I have one of these drivers that I need to build an enclosure for and your bracing is giving me second thoughts about using window bracing.
Good job, it looks incredibly solid!
RobertChicken is offline
post #84 of 88 Old 08-14-2019, 04:09 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Thanks mate, the box is an absolute tank, but also weighs the same as a tank, 2x4s might have been a better option with regards to weight but at least I know its braced well! Each box used about 3 sheets of mdf so I'm assuming the weigh more than 100kg (220lbs) without the drivers, and I have to get them up a small English staircase yet!
post #85 of 88 Old 08-14-2019, 04:20 AM
Quoted: 31 Post(s)
That sounds nuts even with a jack/trolley. All the best with that, maybe get someone to help and just take it slowly, also you might wanna put some wheels on it for general movement.
post #86 of 88 Old 08-14-2019, 05:54 PM
kevings's Avatar
Quoted: 333 Post(s)
Liked: 515
Monty,
The new sub is looking great! Hey, here's an item you may want to consider picking up, when the time comes to move your subs into your theater.....
These straps make moving large heavy subs ridiculously easy. If you have a friend that can help you, moving that 250lb + subwoofer, will feel like it weighs about one tenth of that weight.
When a friend recently came over to my place to help me move around a few Devastator cabs I built, we were laughing out loud the first time we picked one of them up with these straps, due to how light they made the cabinets feel.
Name:	Shoulder dolly.jpg
kevings is offline
post #87 of 88 Old 08-15-2019, 06:50 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Originally Posted by kevings View Post
Monty,
I'll probably have to give these a go, they are ridiculously heavy!
post #88 of 88 Old 08-15-2019, 06:51 AM - Thread Starter
Quoted: 97 Post(s)
Liked: 146
Enough clamps?
