Cold solder joints? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By imrf
post #1 of 10 Old 07-05-2019, 08:13 PM - Thread Starter
imrf's Avatar
Quoted: 202 Post(s)
Liked: 124
Cold solder joints?
So I’m soldering up the one crossover that I have to for my HT-10s and it looks like I can’t get away from what looks like cold solder joints. I don’t want to keep holding the iron on the pads too long to avoid ruining the board. Thoughts? My iron goes to 900. I know I’m rusty at this but sheesh. Lol
imrf is online now
post #2 of 10 Old 07-05-2019, 08:35 PM
mtg90's Avatar
Quoted: 766 Post(s)
Liked: 1580
What type of solder are you using? I've found lead free stuff can look dull like that when it cools.
mtg90 is offline
post #3 of 10 Old 07-05-2019, 08:51 PM - Thread Starter
imrf's Avatar
Quoted: 202 Post(s)
Liked: 124
Honestly I don’t know for certain if it is or isn’t. It was in a tube in a kit I just bought. My guess would probably be lead free. The connections seemed tight. I’ve read a bad/cold joint usually can crack and be wiggled but I couldn’t get it to do anything. I know that may not be the be all end all test.
Anything else I could do to test it for issues before mounting it all?
imrf is online now
post #4 of 10 Old 07-05-2019, 09:13 PM
Matt2026's Avatar
Quoted: 834 Post(s)
Liked: 24237
Spoiler!
Going back to my working days it was thought that you could visually inspect for cold solder joints. Having military customers we didn't want to make mistakes. Since this was 30 or so years ago things may have changed, in any case, sometime along the way a study was done by some respected people and they determined you couldn't identify a cold solder joint by visual inspection. Joints that were in fact bad could look all nice and shiny and visa versa... FWIW
Regards, Ken (Retired)
9.1.) Denon 4520CI; Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Aircom T-8, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #5 of 10 Old 07-05-2019, 11:35 PM
stereo2.0's Avatar
Quoted: 44 Post(s)
Liked: 37
...Thoughts? My iron goes to 900...
You never usually have to set the soldering iron higher than 650°F to get a good solder joint, unless the only tip you have is too small for the joint.
A setting of 600°F should be hot enough for most connections.
Setting it to 900°F will just burn off the flux too fast and actually help create a cold solder joint.
Most lead-free solders solidify to a matte (non-shiny) finish, so you can't use that criteria to judge a solder joint as being cold or not.
Did the solder want to wet up the wire as you soldered it (good solder joint), or dimple down and not want to wet the wire at all? (cold solder joint)
Note: I've assumed the PCB pads and wire were clean and free of grease/oils before you soldered them, because they have to be clean before a good joint can be made.
If the parts were clean and the solder wetted both parts readily you can assume they're good joints, but good joints can still fail later if the solder is also being used to physically hold heavy components in place.
Make sure all bulky parts are secured with black zip ties or glue before soldering them to the crossover PCB, however, small resistors won't physically stress the solder joints so they don't need to be secured.
stereo2.0 is offline
post #6 of 10 Old 07-06-2019, 04:26 AM
windshear's Avatar
Quoted: 79 Post(s)
Liked: 31
Add a bit of solder to the tip first, to ensure a good solder bridge. Depending on the tip size, it will determine your feed rate of the solder. Most joints look like they don't have enough solder. Clean the tip regularly. Make sure the tip touches the pad as well as the wire lead at the same time, so they both heat up, ensuring heat spread. The pad size and wire lead will determine how to withdraw the solder iron tip, you need to try and see what works best. Ideally you should cut the lead to the correct length then solder, that way you can pull the iron tip up the lead when with drawing it. This will ensure a nice conical shape as it cools.
Classe CA2300 CA5300 CA2100
Classe CP800 "2.6". Marantz AV8805 "7.6.4"
B&W 2x800Di HTM1D 4xSCMS 4xCCM7.4
2x Dual Opposed DIY HST18's
2x Triangular DIY UM18-22's
windshear is offline
post #7 of 10 Old 07-06-2019, 12:16 PM
Augerhandle's Avatar
Quoted: 1153 Post(s)
Liked: 1140
Looks like a job well done to me.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #8 of 10 Old 07-06-2019, 12:34 PM
autox320's Avatar
Quoted: 70 Post(s)
Liked: 126
ditto; can't stand the new lead free stuff and try to avoid it if I can LEAD FREE SUCKS
Not sure if the pics or what but make sure some of those legs don't have a C or hole around them; could be the camera lighting but just make sure they are flowed in. Other than that looks good to me man.
"dB levels? - Long as can't foam my beer."
autox320 is offline
post #9 of 10 Old 07-06-2019, 07:02 PM
Matt2026's Avatar
Quoted: 834 Post(s)
Liked: 24237
I agree, I still have about a half spool of the old leaded stuff
Matt2026 is offline
post #10 of 10 Old 07-06-2019, 07:16 PM - Thread Starter
imrf's Avatar
Quoted: 202 Post(s)
Liked: 124
Thanks guys. To the one who asked, it’s the camera angle, no holes in the soldered components.
I hooked it up and did a dry run and it sounded ok to me, even cranked up. I’m going to run with it. Probably just the solder that came with the kit.
On a side note, the midbass on these it’s quite amazing!
Matt2026 likes this.
imrf is online now
