Mounting DIYSG Atmos speakers - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By torii
  • 1 Post By torii
  • 1 Post By Boxozaxu
  • 1 Post By asarose247
  • 1 Post By Hoodcom
  • 1 Post By lawdogx
  • 2 Post By asarose247
post #1 of 8 Old 07-12-2019, 01:28 AM - Thread Starter
Liked: 4
Does anyone recommend a specific ceiling mount for the DIYSG Atmos square box speakers? I am trying to figure out what is the best method. They are the Volt 10 Atmos flat pack (square shape).
mrc12973 is offline
post #2 of 8 Old 07-12-2019, 01:44 AM
torii's Avatar
Quoted: 3318 Post(s)
Liked: 1871
like this guy did? or actually on the ceiling? https://www.avsforum.com/forum/155-d...m-sound-3.html
mrc12973 likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #3 of 8 Old 07-12-2019, 01:46 AM
torii's Avatar
Liked: 1871
I would put a mounting plate on the back of the speaker and due to the size look for a fixed mount.
torii is offline
post #4 of 8 Old 07-12-2019, 11:05 AM
Boxozaxu's Avatar
Quoted: 508 Post(s)
Liked: 346
I just used construction screws. With the woofer removed, I screwed a couple of screws through the back of the speaker, through the ceiling and into where I knew there was wood blocking. I did this with volt 6s but I wouldn't think twice doing it with volt 10s. You can screw directly into the ceiling joists if you can't get access to install wood blocking.
Boxozaxu is online now
post #5 of 8 Old 07-12-2019, 03:54 PM
asarose247's Avatar
Quoted: 1197 Post(s)
Liked: 1054
when ATMOS burst onto the scene almost 5 years now,
the 'where at" and "how to" for on ceiling speakers
has produced some imaginative and virtually almost always effective options, TSTL
you may want to post details of the room, seating, distances and all that info
some want to aim the speakers, some will go with straight down and the wide dispersion,
but whatever fits YOUR room and seating is the most important
the suggestions already given are "right"
if th ceilings are really high. something like this : https://www.amazon.com/Panavise-717-...uments&sr=8-24
but it's for you to "see" what your layout will be
these are my front heights on a full motion mount - gets it right where it need to be . .
HTH
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #6 of 8 Old 07-12-2019, 05:04 PM
Hoodcom's Avatar
Quoted: 160 Post(s)
Liked: 159
There's a lot of ways in achieving this goal, much like the ones suggested above.
In fact @asarose247 's build inspired me to do this with my Atmos channels in my room. (Tread linked in my signature.)
I certainly have no regrets with going this route. I hope this helps give you ideas on all the options you will possibly have.
Hoodcom is online now
post #7 of 8 Old 07-12-2019, 05:08 PM
lawdogx's Avatar
Quoted: 90 Post(s)
Liked: 87
My current RSL atmos speakers sound great but they’re like 10dB less efficient than the rest of my system. I’d swap them out for Volt 10’s in a second once I figure out how to flush mount them. Matt posted some mock ups a while back of a wood piece that would allow volts to be ceiling mounted and run ib. If I had any router skills at all I’d be running these.
ID:	2590176   Click image for larger version
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E Atmos; 4 x UM18-22 Mini Marty's.
COMPONENTS: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d; Epson 5040UB.
lawdogx is online now
post #8 of 8 Old 07-12-2019, 05:18 PM
asarose247's Avatar
Liked: 1054
FTR
i do remember that conversation with @Hoodcom
and i didn't want to overwhelm the OP with what for many could be a bit over the top
except to maybe start asking "what if?"
but this is a SCATMOS on ceiling array, with 40 ft^2 of broadband absorption for more direct sound from the "tops"
Name:	8 pieces ATMOS Cloud20160613_162349[1].jpg
Hoodcom and mrc12973 like this.
