DIY Ottoman Subwoofer - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 31 Old 07-13-2019, 05:20 PM - Thread Starter
Liked: 0
New to the thread, my first post.
I've been doing some research on DIY vs buying a sub. I am not comfortable with the cosmetic builds, whenever i paint it never dries correctly, but I can make it strong and functional. So I have decided to either buy a store bought nice looking sub like an SVS PB3000 or do it myself by modifying my ottoman so my wife will never know .
Given my limitations:
  • ~3.1cuft volume
  • internal space of box 26"x26"x8" (I think I can make ~11" mounting depth work so don't be too concerned about sub dimensions)
  • max $1500 on amp + sub
Would I be able to achieve a better sound than say a SVS PB3000 that says it can reproduce 16hz -3dB? I would like to think if i spent the same as the cost of the SVS $1,000 I should get the same or better sound. Is this possible with those dimension? If so what sub would you go with and sealed or ported?
Monstrosity is offline
post #2 of 31 Old 07-16-2019, 08:43 PM - Thread Starter
Liked: 0
I think I have narrowed it down to the Dayton HO18, Dayton HF15, or the UM18-22. I just don't know if the 3.1 ft^3 volume for my sealed/ported box is enough for these subs. Should I just scrap the ottoman idea and just buy an SVS or a monolith?
post #3 of 31 Old 07-16-2019, 10:30 PM
asarose247's Avatar
Quoted: 1257 Post(s)
Liked: 1103
@Monstrosity
Well-
it depends
Welcome to AVS
YOU CAN build yer own dang "ottoman' sub
Table Tuba, a 30x30x16 inch horn loaded sub that will do double duty as a piece of fine furniture
it's worth a look: https://billfitzmaurice.info/TT.html
extremely cost effective, easy build, lightweight, powerful clean bass,
fail-proof plans
get her involved in building it with you
and
making it pretty, all dressed up for Sunday company
i'm sure you could find plenty of good ideas / ways for a living room "look"
on you tube , at the BFM site, and plenty of good creative, supportive minds here at AVS.
just ask . . .
HTH
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #4 of 31 Old 07-17-2019, 07:50 AM
Cichlid109's Avatar
Quoted: 273 Post(s)
Liked: 154
Not trying to be ignorant but if you use it as an ottoman how will you be able to move it or really what about wiring? If you went wireless ( I think PE has something? ) great but otherwise what about the speaker wire??
Denon AVR-4520 LCR BIC PL89ii's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height w/EP-2000, BIC DV84's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #5 of 31 Old 07-17-2019, 07:55 PM
Augerhandle's Avatar
Quoted: 1281 Post(s)
Liked: 1263
"Wireless" means no speaker wire (Bluetooth), but then you'll need a power cord.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #6 of 31 Old 07-17-2019, 07:59 PM
Liked: 1263
Build a 22" x 22" box, down-firing with 5" legs, and about 5 ft. tall. Have the SO whitewash it, and glue on some faux doors with hinges and handles. Call it "the Curio Cabinet".
mevansmusic likes this.
post #7 of 31 Old 07-17-2019, 08:05 PM
smcmillan2's Avatar
Quoted: 950 Post(s)
Liked: 814
As in, not "wireless".
Augerhandle and wlhungdude like this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #8 of 31 Old 07-18-2019, 05:36 AM
Cichlid109's Avatar
Quoted: 273 Post(s)
Liked: 154
Okay let me rephrase, if the sub is going to be used as an ottoman ( according to OP ) which is fine my question how is it going to be wired?? Only reason asking most well in my case the ottoman is in front of my sofa so if making it into a sub / ottoman whether you use plate amp or other how do you wire it without having pwr cord spkr wire etc being seen? Not a big deal if used as an end table or something that sit against the wall. Really just curious.
post #9 of 31 Old 07-18-2019, 06:20 AM
Quoted: 201 Post(s)
Liked: 201
Completely depends on the room. In my case, my sofa is about 18" in front of the back wall my Ottoman is right in front of the couch. I currently have speaker wires run down the back wall and under my couch for bass shakers. Would be super easy to put a slit in the carpet under the ottoman and run the speaker wire under the carpet and have it pop up under the ottoman. Ottomans don't typically need to be super mobile, mine rarely moves more than a few inches.
In fact I'm planning on doing something similar with my ottoman but with charging cables instead.
Cichlid109 likes this.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #10 of 31 Old 07-18-2019, 04:11 PM - Thread Starter
Liked: 0
Attachment 2592060
Thanks for everyones reply. I like this idea, I will give it some more thought and keep you guys updated and maybe a few pictures once i start getting it all put together.
post #11 of 31 Old 07-18-2019, 04:14 PM - Thread Starter
Liked: 0
Yea, my ottoman doesn't really move so running a wire from it isn't a problem. I was thinking of getting a proamp like the NX3000D since I won't really have space for a plate amp.
post #12 of 31 Old 07-19-2019, 07:21 AM
Quoted: 201 Post(s)
Liked: 201
That'd be my advice, put your amp in the rack and just run speaker wire to the ottoman under carpet (avoid the traffic areas).
DIY 110" AT Screen
post #13 of 31 Old 07-23-2019, 12:46 PM
mevansmusic's Avatar
Quoted: 60 Post(s)
Following along. I have been considering doing a end table on entertainment stand sub build as well.
Sent from my Pixel XL using Tapatalk
mevansmusic is offline
post #14 of 31 Old 07-27-2019, 08:01 PM - Thread Starter
Liked: 0
Update... bought the Behringer NX3000D
So I decided to bail on the ottoman idea I was struggling with it.
However, I went ahead and bought a NX3000D, I already had 2 10" subs laying around and I wired them up. I was unable to get Channel B to output more than 10% SPL of what I was getting out of Channel A. I swapped every wire to make sure it wasn't one of my 2 sub outs from my STR-1070 or one of the wires. Both subs work fine by themselves but when I try to run the NX3000D in Dual with same settings B outputs very little SPL.
Secondly, I have a $10 Nobsound 100W TPA3116D2 Amp with a 60W power supply with the gains maxed out on the NX3000D and the Nobsound the Nobsound is a little louder than the NX3000D. Maybe the NX3000D is a cleaner sound but does this sound right, should a 60w $10 amp beat out on SPL?
I would like to figure this out before I buy a UM18 with a Marty if that's what I decide, please, please, any help would be awesome.
post #15 of 31 Old 08-11-2019, 06:52 PM - Thread Starter
Liked: 0
Update,
Even though it may seem like I am all over the place I am learning a lot. As stated above I have bailed on the ottoman and I got the NX3000D working. However, I was still trying to figure out how to make these 10" subs I have work.
I think the more I read on this forum the more I am thinking to go with an 18" ported sub and I still want to incorporate the 210's somehow. I would like to use both subs for HT and then when listening to music just use the 210's. I was thinking of building an isobaric box for the 210's just to keep it smaller and compact.
Does it make since to use the 210's to target the 40-100hz range and have the 18" crossover and do 50 and below? Am I over thinking it and should I just discard the 210's and just go with the one 18"? Is it a good idea to separate frequencies for 2 subs or just use filters and gains to flatten the freq curve as much as possible?
post #16 of 31 Old 08-11-2019, 08:16 PM
wlhungdude's Avatar
Quoted: 213 Post(s)
Liked: 273
For your Behringer, I'm pretty sure you should be using BIAMP 1 mode, if you have one input and 2 outputs. Sort that out first. Have you connected it to a computer yet? Much easier to see what's going on. ( just use a printer cable )
Get your settings right, and you'll be letting the smoke out of those 10"s in no time.
This is all IMO. YMMV.
Joseph
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #17 of 31 Old 08-12-2019, 08:31 PM - Thread Starter
Liked: 0
Joseph
Thanks for the advice, I am very impressed with the NX300D. During all my troubleshooting I never touched the gain on the Parametric EQ. I kept adjust the the peak limiter and filter and I wasn't getting anything. When I changed the EQ gain that's when my frown turned upside down.
My problem with the 10's are 2 fold.
1.) I don't really have a good idea on how to setup up the filters and gains very well so I have been reading up on AustinJerry's +100 page 'how to setup REW for dummies' in hopes that will help.
2.) I bought a bandpass box designed for some cheap really cheap subs 15 years ago but I have always liked the box so after upgrading the subs i stayed with the box. This was originally intended for car audio but since I have moved into HT I don't think I want them to be ported, let alone a band pass box, primarily because of the tuning difficulties.
Don't get me wrong, these things are rattling every light fixture and vent in the house but I think if I went with a different box I could get it to sound clearer.
post #18 of 31 Old 08-13-2019, 01:47 PM
2_liter_ejturbo's Avatar
Sounds like you should build yourself 2 of lilmikes Picowreckers. The sound is clear and flat. You will need to make sure your drivers work in the design, but I never thought 2 10's could do what these do.
https://www.avsforum.com/forum/155-d...cowrecker.html
Here is my build, I tried to get the WAF higher as they are in the living room.
https://www.avsforum.com/forum/155-d...ker-build.html
2_liter_ejturbo is offline
post #19 of 31 Old 08-13-2019, 07:15 PM - Thread Starter
Liked: 0
Those look impressive! I am afraid that looks way too difficult for me to build. How critical are those angles assuming air gaps are all filled in?
post #20 of 31 Old 08-13-2019, 07:54 PM
asarose247's Avatar
Liked: 1103
"How critical are those angles assuming air gaps are all filled in?"
the slight angles of intersection for the interior panels are
from my own experience in wondering about and measuring "to get it right"
were around 5 degrees- nominally slight , not much more and actually a hassle to get exactly on a table saw
in doing a dry fit of panels , to be sure panels ends hit "hit the mark" with a smidge overly long
and then
I found that some finessed application of a belt sander to make a slightly kinda close enough bevel was all that was needed,
as long as in subsequent the dry fitting, the panels end did hit the mark for fit wrt proper length.
the use of PL3 as the adhesive in the joint WILL create the airtight joint .
and by building the box from the inside out, you'll have room to apply a little more if need be, more easily as the build progresses
get a box of disposable gloves
2_liter_ejturbo likes this.
post #21 of 31 Old 08-14-2019, 01:03 PM
Asarose has more horn building experience then I do... These were my first DIY audio thing and the first project that needed to look good.
From what I have gathered from other posts. There is 1 absolute critical dimension the nail, the throat. If this is right, there is a little be more leeway with everything else.
Only tools I used were:
Circular saw
Kreg Rip guide
Tape measure
Quick square
Level (mostly for a straight edge)
PL3
Drill and Impact driver
Kreg pocket hole jig
brad nailer for the trim
I cut all my pieces, then took my time with a tape measure and straight edge and layed out the horn on one of the sides. The plans call out dimensions for both ends of all of the sections so no need to measure the actual angle. Take your time, trace out the boards with a dry fit. Then when you glue and nail/screw everything it's super easy to get everything in the correct spot. All of the corners for the horn were close enough to 90 degrees that I didn't bother sanding or cutting the angle. Just relied on the layout to angle correctly and used PL3 to seal the interface. The 2 angles that need to be cut are the support for the baffle, and the pretty face of the baffle (because it's visible). It's not in the plans but cut the baffle long so you can blend it in with sanding or a router after its assembled.
What drivers do you have?
It is hard to describe how these sound, but the cannon fire in Fury literally smacks you in the face/chest like your standing next to the tank. I know I will probably want to build myself a submaximus V3 eventually but for less than half the cost and way less then half the size, the picos do amazingly well.
post #22 of 31 Old 08-14-2019, 02:31 PM
asarose247's Avatar
Liked: 1103
sometimes - -
cutting ALL pieces first- can feel pretty good
finally- progress
however. . .as I've reported else where and experienced . .
like with Max V3, my ply was not .75 but .709
is .04" that critical? it depends
're-calculating"
minor yes,
annoying as all get out- very much so
i recommend a measured deliberate pace for building,
lots of dry fit , stabilization / non-slippage blocking,
Hit the Mark
in a current thread about another V3 build I've posted some construction pics that might inspire using more visualization of the process
once!- right!- the first time.
to the list of tools- a good combo square and maybe an extra 16" blade
HF sells a kit with an up to 24" blade but i also have a few metal yard stick around just to be able to double check
post #23 of 31 Old 08-14-2019, 07:30 PM - Thread Starter
Liked: 0
edited quote for length
Kreg Rip guide
I never knew 'rip guides' existed! Thanks! I don't have a table saw so that will help a bunch. I was debating on needing to buy one and then trying to figure out where to put it.
Driver:
- I have two Thunder 8000 2003 10" single voice coil (I still can't believe I bought them ~15 years ago)
- MTX T8104A <--PDF Link to spec
post #24 of 31 Old 08-14-2019, 07:39 PM - Thread Starter
Liked: 0
Originally Posted by asarose247 View Post
sometimes - -
finally- progress
're-calculating"
minor yes,
Hit the Mark
Good suggestion on the combo square, I am missing a lot of tools for this job, lol. Thanks,
I am a measure 8-1/4" twice and then I will cut 7-3/4". It drives me crazy, dang dyslexia or something, my mind sees a 1/4" and then subtracts or adds a 1/4" incorrectly from the whole number.
post #25 of 31 Old 08-15-2019, 11:03 AM
I am by no means a Hornresp expert, but I did add the driver specs to the picowrecker hornresp model.
It looks very similar to the Alpine type s model. It would need a high pass filter around 23-24hz to keep excursion in check.
post #26 of 31 Old 08-26-2019, 08:29 PM - Thread Starter
Liked: 0
At this point I wonder if I should just rename this thread or start a new one because this really has very little if anything to do with an ottoman build anymore, lol.
I went ahead and decide to just get 2 18 HST ported subs that are insanely impressive and had a few follow questions.
1.) All seriousness, should I be concerned about the structural integrity of the house because I am hearing a lot of creaking noises in my house?
2.) Also, the subs are awesome but one of the two subs box appears to also be making some noises when >90dB and below 30hz. I believe it has to do with the mdf gaping between some of the supports moving around from the vibration. When I tap on enclosure gently with a rubber mallet I can reproduce the squeaking sound around a few of the brace points.
- I was wondering if I should just shove some glue along all the braces
- add a few screws to from the outside drilling into the braces to pull them tight
- or add a few shims if possible to add some stability and more contact with the mdf.
----EDIT--- I was able to figure out how to upload the image with drawings of where the gaps I am talking about.
Any ideas?
ID:	2607638   Click image for larger version
ID:	2607640   Click image for larger version
ID:	2607642   Click image for larger version
post #27 of 31 Old 08-26-2019, 08:46 PM
asarose247's Avatar
Liked: 1103
shove some glue . . .
a moderately healthy bead of PL3 on any suspect wood to wood juncture
disposable gloves for spots you can't get the gun into
for $5, would stay fixed
post #28 of 31 Old 08-27-2019, 05:28 AM
buggers's Avatar
Quoted: 43 Post(s)
+1 on the urethane glue. It will fix a multitude of mistakes...
buggers is offline
post #29 of 31 Old 08-27-2019, 07:18 AM
Zarkoff500's Avatar
Quoted: 224 Post(s)
Liked: 168
You can also just add some MDF blocks with wood glue. Basically just surround the gaps with 1" to 2" thick blocks and once dry, it should take care of the problem. See my picture for a general idea.
Zarkoff500 is offline
post #30 of 31 Old 08-28-2019, 09:51 AM
Quoted: 23 Post(s)
Liked: 3
Oh wow, thanks for posting the latest pics showing the gaps in the braces. Sorry about that.
I used to make fancy diamond braces for my sub boxes, but based on your pics, I think my next box will get Bill Fitzmaurice style wooden dowels. That should work well and lessen the chance of having any gaps........the main place you need support in a speaker cab is the middle / center of the panels, that's where they move the most. And it would also lighten the cabs and push the resonant frequency up. That guy was right all along.
Ex JL Rep is online now
