B.M.D. - Beast Mode Devastator - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #31 of 117 Old 07-18-2019, 07:55 PM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
Originally Posted by superkyle View Post
Please go over this with a fine tooth comb. Tried to keep ports the exact same size but that’s not possible so one needs to change but only very slightly. I doubt it changes anything though. I very easily could of made a mistake so someone let me know if you want to work through it with me to make sure it’s correct.
One of the upper window frame braces is 13.75". I will have to look at it closer later.
Stormbreaker (For Sale) | Wisconsin Home Theater Meet Thread
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #32 of 117 Old 07-18-2019, 08:13 PM
Audiophile75's Avatar
Quoted: 97 Post(s)
Liked: 48
Originally Posted by Red Five View Post
This is the LaVoce SAN214.50 vs the B&C 21DS115-8 at 1w1m.
Dayton PA460 vs B&C 21DS115-8 1w1m
Are you telling me a $90 pa460 is similar to a $600 21”? It looks pretty close which makes me wonder if I’m reading this wrong.
Audiophile75 is online now
post #33 of 117 Old 07-19-2019, 04:13 AM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
Are you referring to the one I added 3/16” to? Those are tricky but since I kept the front ports the same size the rear chamber had to increase by the difference of 3 plywood’s thick. But again very well could of made a mistake lol
Always destroying exergy!
superkyle is online now
post #34 of 117 Old 07-19-2019, 04:14 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
1w1m yes, but one is done at 11mm around 220 watts and the other doesn't stop until 21mm around 1600 watts The PA460 still gets to about 121db in the mids if I recall and 112 or 113db around 20Hz
neo_2009 and kagtha like this.
post #35 of 117 Old 07-19-2019, 04:14 AM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
Beat to the punch
post #36 of 117 Old 07-19-2019, 05:08 AM
Quoted: 421 Post(s)
Liked: 348
The 21" has more power handling and xmax, it also has better inductance and almost certainly better CMS as well.
I imagine the two, when measured, will show the 21" having a much better (and cleaner) response than the 18."
Trimlock is online now
post #37 of 117 Old 07-19-2019, 05:25 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
@Rcris
This is my educated guess where a 60.5x25.5x24 BMD will land. I compared it against standard BMD using window frames and also the 8.3ft3 18Hz tune box you linked. There is a lot of low end loss due to the loss of displacement, but it does have its advantage against the ported box. With a 47.75" vent the first port resonance is pretty low, but that is what it took to get it down to 19Hz tune.
Name:	Rcris BMD comparison to BMD MDF.jpg
ID:	2592474   Click image for larger version
Name:	Rcris BMDversion vs Ported box selection.jpg
Rcris likes this.
post #38 of 117 Old 07-19-2019, 10:40 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
@superkyle I think the conversion looks good as far as panels and fitting go. I will tinker with the Hornresp model and see what it looks like, I would not expect anything too drastic. Just again not there top window frame is the same length as the upper front to back braces. The middle brace maintains the upper brace dimensions I saw in the sheet. Looks good!
Edit: They model so closely, I cannot tell what is what on the SPL graph lol.
Name:	BMD Plywood calculation.jpg
post #39 of 117 Old 07-20-2019, 10:09 PM
bebb's Avatar
Quoted: 228 Post(s)
Liked: 164
BMD vs Devastator 1w1m
BMD vs Stormbreaker (11cuft, 18Hz tune) 1w1m
Is the BMD represented in black?
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #40 of 117 Old 07-20-2019, 10:12 PM
bebb's Avatar
Quoted: 228 Post(s)
Liked: 164
bebb is offline
post #41 of 117 Old 07-21-2019, 03:48 AM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
Yes
This was answered a few posts up.
post #42 of 117 Old 07-25-2019, 03:07 AM
Purenv's Avatar
Quoted: 181 Post(s)
Liked: 122
I would have to play with it, but the resonator needs to be about 225in2, that would be 10 inches deep on 25.5in wide and the driver is 10 inches deep, so that would be 20 inches right there not counting cabinet material. When the resonator gets less cross sectional area the response flattens out and it becomes less efficient. Minimum is around 25.5in wide and 24in deep with that width.
How long would the enclosure have to be to achieve the same volume as your design of the 28” deep version?
Purenv is offline
post #43 of 117 Old 07-25-2019, 04:05 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
In which direction are you trying to trim it down? Just width?
post #44 of 117 Old 07-25-2019, 05:16 AM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
I’ll be waiting for this^^^^^. I am planning on using Baltic birch to build my 2.
Plywood cutlist posted in POST 3
Purenv and Red Five like this.
post #45 of 117 Old 07-25-2019, 06:15 AM
Purenv's Avatar
Quoted: 181 Post(s)
Liked: 122
I was just thinking out loud for those of us that may want or need to increase the height or length if laying it down on it’s side and reducing the other 2 dimensions.
So in the view you are used to using, I was trying to cut down both width and depth and increase height. I don’t care how “ugly” it may look with where the “ports” exit on the front to maintain the cross sectional area and length. Please pay no attention to the dimensions in the picture. It’s for an example of layout.
Purenv is offline
post #46 of 117 Old 07-25-2019, 06:19 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
The original version has an external displacement of 29.4 cuft. The dimensions you have up there come in at 30.1 cuft, so it will be very close to the original with displacement.
Edit: @Purenv
The depth of the resonator should be 10.25inches, that should bring it very close to the original version. Then just calculate your rear displacement based off that depth. You could probably use vertical standing window frame for support around the vent on the bottom.
post #47 of 117 Old 07-25-2019, 06:22 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
You are really tempting me to go with ply on this https://www.menards.com/main/buildin...4768265&ipos=6
post #48 of 117 Old 07-25-2019, 08:23 AM
Purenv's Avatar
Quoted: 181 Post(s)
Liked: 122
Edit: @Purenv
Those dimensions are not really what I would use. I was thinking, in stand up view, “y” height x 25.5 wide x 25.5 deep and solving for “y”. So 29.4 ft3 = 50803.2 in3
25.5 * 25.5 = 650.25
50803.2/650.25 = 78.28” in height = y
Unfortunately too tall, or if laying it on it’s side like I am, too long.
I’ll try and work the numbers a bit.
I might just stick with your dimensions and switch back to the 893s.
Purenv is offline
post #49 of 117 Old 07-25-2019, 12:54 PM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
Plywood is the way to go IMO. 33% lighter pocket or brad nails easier. Less dust. Only thing MDF has Is price and smooth finishing. After my last MDF build I needed 2 people struggling to move it. Not worth it.
lknhomeaudio and Rcris like this.
post #50 of 117 Old 07-25-2019, 07:07 PM
K9woofer's Avatar
Quoted: 184 Post(s)
Liked: 119
Only 13 cubic feet smaller than Submaximus,
K9woofer is offline
post #51 of 117 Old 07-25-2019, 08:43 PM
Purenv's Avatar
Quoted: 181 Post(s)
Liked: 122
That’s still a lot of box size reduction.
Purenv is offline
post #52 of 117 Old 07-26-2019, 05:04 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
It is looking like each one is up to 5 sheets of ply. The added dimensions of panels and the shrinking of material were just enough so it would not fit on four.
post #53 of 117 Old 07-26-2019, 08:55 AM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
Well damn that sucks. I only ordered 8. I’m prob not going to end up ordering another. Maybe I can just pick up some other brand local from Lowe’s and just use it for the window bracing or something. What piece ends up left out?
post #54 of 117 Old 08-06-2019, 11:13 AM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
Back in the states. Going to try and work out a cutlist to see what can be done or what I need to buy.
post #55 of 117 Old 08-06-2019, 06:31 PM
tarponater's Avatar
Quoted: 107 Post(s)
Liked: 467
How many of these horn loaded subs do you have? Wish someone would design one for me, around the SP1804...nudge nudge wink wink.
Receiver: Onkyo TX-RZ730 (7.2.4) Crown XLS1000 (Atmos)
Front Wall: DIYSG Fusion10 L&R, Hybrid DIYSG Fusion10 center
Atmos/Surround: 4 Polk TSX 150C(DIY) 4 Yamaha NS-333
Subwoofers: 4 UM18 Full Marties 16Hz tune NU6000DSP x2, HS-24 Nearfield 11.5 ft^3 sealed NU12000, MINIDSP
tarponater is online now
post #56 of 117 Old 08-07-2019, 04:18 AM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
Use the parameters he has posted above and just change the driver specifics. I would venture to guess the drive would work just fine in the BDM but I’m not sure familiar so modeling it is always recommended.
post #57 of 117 Old 08-07-2019, 05:01 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
1w1m with the SP1804. That is using MDF with the 8.25 port extension, tune is a little under 19Hz.
Name:	BMD Port Ext SP1804.jpg
chadsmith013 and tarponater like this.
post #58 of 117 Old 08-09-2019, 09:33 AM
Rcris's Avatar
Quoted: 99 Post(s)
Liked: 117
I think I can fit in two of these with ports facing sideways .Is there any preference in which direction the port faces behind AT screen?
Rcris is offline
post #59 of 117 Old 08-09-2019, 10:39 AM - Thread Starter
Red Five's Avatar
Quoted: 431 Post(s)
Liked: 473
The nice thing about low frequencies they are not all that directional, pointing it sideways should have little effect if any. Exceptions, pointing it at the wall and then placing it one or two inches from that wall. You could see an effect in the response form that.
post #60 of 117 Old 08-10-2019, 05:53 AM
superkyle's Avatar
Quoted: 802 Post(s)
Liked: 341
Going to break ground today cutting up the plywood. My previous builds I had the plywood ripped to smaller cuts before bringing it home so it was easy to cut to size on my table saw. This however I’m not quite sure. Thinking about building a diy rip guide or even buying a tracksaw. What do you guys use to rip down the full sheets?
Red Five likes this.
