NX3000D - Remove Rack Mounts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-15-2019, 06:01 PM - Thread Starter
bejoykr's Avatar
Has any one removed the rack mounts of NX3000D? Is this even possible?
This one is like a turbine and I'm trying to see if I can put it in a cabinet, instead of the fan mod.
bejoykr is offline
post #2 of 6 Old 07-15-2019, 06:05 PM
smcmillan2's Avatar
Quoted: 892 Post(s)
Liked: 787
The rack ears are part of the body. You would have to cut them off (angle grinder, hacksaw, etc.).
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #3 of 6 Old 07-15-2019, 06:18 PM
asarose247's Avatar
Quoted: 1243 Post(s)
Liked: 1090
there are many fan mods . . .
As my nx3 is only 7ish feet away , even behind the TV on a shelf, OEM fan was unacceptable
room can be as quiet as 38-39 db, OEM fan boosted that to 50-51
this , on Low , excellent cooling and quiet
AC Infinity MULTIFAN S1, Quiet 80mm USB Fan for Receiver DVR Playstation Xbox Computer Cabinet Cooling
HTH
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #4 of 6 Old 07-15-2019, 07:27 PM - Thread Starter
bejoykr's Avatar
Ok, so fan mod it is then.
Wasnt really looking forward to opening up the brand new amp and voiding the warranty
bejoykr is offline
post #5 of 6 Old 07-15-2019, 07:39 PM
smcmillan2's Avatar
Quoted: 892 Post(s)
Liked: 787
When I replaced the fans on my iNukes/NX I removed the hot-melt glue with needle nose pliers, removed the original fan, pulled the plastic connector off the connector pins (just pull straight up with pliers, with a little wiggling) and put those in the box. If I need to send it in I'll just reverse the process. There were no "voids warranty" stickers on the 3 I've worked on.
post #6 of 6 Old 07-16-2019, 07:23 AM - Thread Starter
bejoykr's Avatar
Thats true. Didnt see any 'warranty' stickers on it.
Thanks guys, on to getting this one fixed.
bejoykr is offline
