Plywood alternatives - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 3 Post By johnson636
  • 3 Post By Boxozaxu
  • 1 Post By notfastenough
  • 1 Post By superkyle
  • 1 Post By Russell Burrows
post #1 of 17 Old 07-16-2019, 08:19 AM - Thread Starter
superkyle's Avatar
Quoted: 803 Post(s)
Liked: 344
Trying a new Horn build and planned to use Aruco plywood except my Home Depot and all the ones within a reasonable driving distance decided to stop carrying the product.
Not a problem I thought I’ll just call all the local lumber places and see what they have. No Baltic birch or Aurcoply anywhere except one place. They want like $46 per 8x4 sheet of aurco and they are about a 45 minute drive for me. Quite the inconvenience to pay $10 per sheet more than I was before
Are there any alternatives that other have as much faith in that the two listed above that can be found at the big box stores? If it comes down to it I don’t mind buying the aurcoply but since I need 8-9 sheets it’s going to get quite expensive.
Always destroying exergy!
superkyle is online now
post #2 of 17 Old 07-16-2019, 08:31 AM
johnson636's Avatar
Quoted: 1205 Post(s)
Liked: 701
Admission into the Rabbit Hole is not cheap
18Hurts, stegen and bebb like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #3 of 17 Old 07-16-2019, 09:10 AM - Thread Starter
superkyle's Avatar
Quoted: 803 Post(s)
Liked: 344
Oh I’ve built a few before. Problem is never had an issue sourcing quality wood
post #4 of 17 Old 07-16-2019, 09:15 AM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
The Araucoply is no longer available here either. But Lowe's does have another brand of Radiata pine available:
https://www.lowes.com/pd/AC-Plus-23-...4-x-8/50100638
Can't speak to how it compares to Araucoply.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #5 of 17 Old 07-16-2019, 09:29 AM - Thread Starter
superkyle's Avatar
Quoted: 803 Post(s)
Liked: 344
Man that actually reads as it is pretty quality stuff. Also not sold in my area though. Kinda crazy there is nothing around here.
post #6 of 17 Old 07-16-2019, 09:33 AM
buggers's Avatar
Quoted: 33 Post(s)
The stores here have the birch plywood for $56. I don't see it getting any cheaper...
buggers is offline
post #7 of 17 Old 07-16-2019, 01:35 PM
Boxozaxu's Avatar
Quoted: 512 Post(s)
Liked: 352
It's a shame if they drop it from inventory. I have two sheets in storage but I might go buy a few more just in case. Seven ply and virtually no voids, it's a great value.
smcmillan2, superkyle and stegen like this.
Boxozaxu is offline
post #8 of 17 Old 07-16-2019, 01:36 PM
Boxozaxu's Avatar
Quoted: 512 Post(s)
Liked: 352
Baltic birch plywood is a different, and better, animal than the 4x8 birch plywood at big box stores.
Boxozaxu is offline
post #9 of 17 Old 07-16-2019, 02:52 PM
notfastenough's Avatar
Quoted: 181 Post(s)
Liked: 209
Lilmike had an OSB suggestion he uses for horns. Depending on how you want the finish to look, it might be an alternative.
https://www.avsforum.com/forum/155-d...l#post58247164
smcmillan2 likes this.
notfastenough is online now
post #10 of 17 Old 07-16-2019, 02:54 PM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
I just recently finished an A/V stand and sealed subs using this: https://www.lowes.com/pd/3-4-in-Laua...X-4/1000068905.
Very happy with it, virtually void- and warp-free. Shame they don't offer it in anything but 2' x 4' locally, but may be available in larger sheets elsewhere?
post #11 of 17 Old 07-16-2019, 03:23 PM - Thread Starter
superkyle's Avatar
Quoted: 803 Post(s)
Liked: 344
That OSB looks promising. Tried to see if any box store around here carries it and it doesn’t. I actually ended up buying the Aruecoply from the place a little drive away. Figured I’ve tested it I know it well and just need to bite the bullet.
notfastenough likes this.
post #12 of 17 Old 07-16-2019, 03:24 PM - Thread Starter
superkyle's Avatar
Quoted: 803 Post(s)
Liked: 344
That stuff looks pretty also but yeah nothing over 2x4 here.
post #13 of 17 Old 07-16-2019, 03:25 PM - Thread Starter
superkyle's Avatar
Quoted: 803 Post(s)
Liked: 344
I’ve purchased the arauco plywood despite the price hike. I know it and I like it. I’ll leave this open for comments to help others if any other known plywood come available.
post #14 of 17 Old 07-17-2019, 04:21 AM
buggers's Avatar
Quoted: 33 Post(s)
Yes I was refering to the 4x8 sheets at Lowes.
buggers is offline
post #15 of 17 Old 07-17-2019, 08:48 AM
noah katz's Avatar
Quoted: 1873 Post(s)
Liked: 660
I'd check out the available OSB.
I once received sub drivers which were shipped attached to OSB boards, which I couldn't help but notice were very stiff, at least equal to plywood.
Noah
noah katz is online now
post #16 of 17 Old 07-17-2019, 01:11 PM
Russell Burrows's Avatar
Quoted: 71 Post(s)
How large a horn?I did a large horn using concrete and concrete cinder blocks and it was awesome till i sold that property.
The buyer said why is the house built so strange then i did a tour and then a sound demo and the house was sold.
Le sigh i am tempted to do a larger horn involving a 40 meter by 70 meter property but wife said haylll nooo ._._._sigh.
bebb likes this.
Yamaha avr, diy l c r surround Behringer nx3000 dsp Fi car audio ib318 v2 310 cubic foot concrete ib lg pf 1500 projector.steren projector mount at diy 135 inch screen triple 15 boss build .
Pending buy fourty 6 inch drivers for some new mains new 4k projector 1240 cubic foot ib for 16 fi car audio ib318 v2 subwoofers 4 nx3000 dsp
Russell Burrows is online now
post #17 of 17 Old 07-20-2019, 09:54 PM
bebb's Avatar
Quoted: 228 Post(s)
Liked: 164
Another inmate in the rabbit hole.
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
