Dayton Audio UM18-22 18 Sealed sub enclosure built help - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 3 Post By LTD02
  • 1 Post By Mustafa Jaleel
  • 1 Post By LTD02
  • 1 Post By smcmillan2
  • 1 Post By michael hurd
  • 2 Post By LTD02
post #1 of 12 Old 07-18-2019, 12:53 AM - Thread Starter
Liked: 1
Angry Dayton Audio UM18-22 18 Sealed sub enclosure built help
I am totally new to building DIY subs. I have order Dayton Audio UM18-22 18 and iNukeNX6000D. Can anyone please guide me about the box dimensions and the internal bracing. Where i live it was pretty hard to get these alone so cannot get the box kit form parts-express /
Mustafa Jaleel is offline
post #2 of 12 Old 07-18-2019, 03:09 AM
LTD02's Avatar
Quoted: 2934 Post(s)
Liked: 3651
this one would be about 4.75 cubic feet net.
if those dimensions are no good, then they can be adjusted. anything from about 3 c.f. to as large as you want to go can work with your driver and amp.
4.75 c.f. is small enough that you most likely won't be able to overdrive the um18 on the low end with too much excursion. watch your power though and no sine waves. :-)
good luck with your project.
you are the second guy in pakistan that i put a cab design together for this week. his was a big marty though. :-)
ID:	2592100   Click image for larger version
ID:	2592102   Click image for larger version
ID:	2592104   Click image for larger version
ID:	2592106   Click image for larger version
Listen. It's All Good.
LTD02 is offline
post #3 of 12 Old 07-18-2019, 03:33 AM - Thread Starter
Liked: 1
Thanks a lot .... Actually the project if for a friend of mines... i am stuck off with Klipsch spl-15... very had to get these bad boys... but will defiantly get it some day
LTD02 likes this.
post #4 of 12 Old 07-18-2019, 05:48 AM
smcmillan2's Avatar
Quoted: 851 Post(s)
Liked: 757
I just built a pair of sealed UM18s in dimensions very similar to those John provided you (a touch larger) - They pound. Your friend should be very happy with them.
I did set the limiter on my NX3kD to ~550 watts for each driver, as modeling showed I would be over xmax at about 450 if I recall correctly.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #5 of 12 Old 07-18-2019, 07:04 AM
LTD02's Avatar
Liked: 3651
xmax on that driver is overhang.
real xmax is up around 28mm. i'm not sure where the damage point is, but is likely way up in the 30's or so.
you can probably up your limiter somewhat. modeling for 28mm excursion at 10hz would be safe, though even higher should be fine.
also, the rest of the chain may have some rolloff, so excursion under 10hz probably won't be as high as models show.
smcmillan2 likes this.
LTD02 is offline
post #6 of 12 Old 07-18-2019, 07:12 AM
smcmillan2's Avatar
Quoted: 851 Post(s)
Liked: 757
Excellent! I will re-model and bump up the limiter then.
Thanks for the info John!
LTD02 likes this.
post #7 of 12 Old 07-18-2019, 07:22 AM
michael hurd's Avatar
Quoted: 635 Post(s)
Liked: 673
Keep in mind, once the coil leaves the gap, there is still some fringe magnetic field. ( more for wider gap widths ) I'd expect the impedance to drop significantly ( regardless of frequency ) when the coil leaves the gap, towards the DCR of the driver.
Be careful approaching the limits.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #8 of 12 Old 07-18-2019, 12:46 PM
LTD02's Avatar
Liked: 3651
ah, found it:
so...
overhang = 22mm
gap height = 12mm
coil height = 56mm
therefore, xmax as calculated as overhang + 1/3 gap = 22 + 4 = 26mm
usable is typically at about overhang + 2/3 of gap or so = 22 + 8 = 30mm
coil leaves the gap at 22 + 12mm = 34mm (this is typically what is referred to as xdam or xmech, but i don't think this driver hard bottoms at that point)
winisd is "small signal" and in reality excursion doesn't go quite as high as model, so modeling for 28-30mm in your box with your power is probably aok.
"Our listed Xmax spec is "geometric" Xmax - the coil extends above and below the top plate by this amount (22mm).Because acceptance of Klippel specs isn't quite universal yet (but getting there), we give geometric Xmax instead of BL-limited Xmax to keep out of trouble, and it's also the most conservative measure. So coil height = top plate thickness + (2*22mm).
The top plate thickness for the UM18-22 is 12mm. So the overall coil height is 56mm, or just over 2.2"."
https://www.avsforum.com/forum/155-d...l#post26312977
@smcmillan2
smcmillan2 and bebb like this.
LTD02 is offline
post #9 of 12 Old 07-18-2019, 01:43 PM
Mike Butny's Avatar
Quoted: 1055 Post(s)
Liked: 2347
I'm running 1200 watts into each of my UM18-22 drivers without any issues. I also do have 2 other subs so 4 subs sharing the load. See the Thread below as it breaks down the power numbers in a 6000DSP. I know you are using a NX3KD but the info in that thread is very useful.
https://www.avsforum.com/forum/155-d...rundown-8.html
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7013 Receiver, 3-Marantz Ma700 and 2-Ma6100 monoblocks, 7.4.2 Atmos, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, Volt 6 Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, 2 LaVoce 21inch Neo DIY subs and 2 PSA 3600I'S.
Mike Butny is offline
post #10 of 12 Old 07-18-2019, 01:47 PM
MKtheater's Avatar
Quoted: 2427 Post(s)
Liked: 2407
Are you keeping them?
Nothing right now
MKtheater is offline
post #11 of 12 Old 07-18-2019, 01:54 PM
Mike Butny's Avatar
Liked: 2347
No. PM sent.
post #12 of 12 Old 07-20-2019, 09:58 PM
bebb's Avatar
Quoted: 228 Post(s)
Liked: 164
Yes. Don't ask me how I know....
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
