Titan 630’s, clone power ;) - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #1 of 129 Old 07-18-2019, 07:56 PM - Thread Starter
Jk7.2's Avatar
Quoted: 1488 Post(s)
Liked: 2685
I decided to pull the trigger on an Xbs 10,000q amp for my mains. Reason: diysg says the stock titan can take 2000 Watts, and I have the added woofer, so it should take more, yeah? I get my mains are only a 6 ohm load stock, right? So less with the added woofer? This thread will contain before and after measuring of the setup, and questions along the way. I need this added power so I can crossover to the mains at 40-60 hz, and boost the midbass they can hurl out. 6 of the 15” woofers my mains have should be awoken by the 1350 watts rms from the amp. It’s a 4 channel amp so I plan on using the open channel for my buttkicker setup. That gives me an inuke to sell. A plus plus. @mtg90 how much power can the dual woofer titan take? I plan on keeping the stock (now modified) crossover in place. Good or bad idea? Should I use the power and extra channels to bi-amp the mains? I’m open to suggestion, but I can’t wait to see what these woofers can do.
Jk7.2 is offline
post #2 of 129 Old 07-18-2019, 08:00 PM
eng-399's Avatar
Quoted: 2424 Post(s)
Liked: 4976
eng-399 is offline
post #3 of 129 Old 07-19-2019, 12:18 AM
Quoted: 1613 Post(s)
Liked: 1226
I don’t know what’s going on but read lots of power and large woofers.
What good can’t come from this??
chadsmith013, Jk7.2 and ian#77 like this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4 of 129 Old 07-19-2019, 12:59 AM
Quoted: 422 Post(s)
Liked: 348
Were you using an iNuke for your mains? was it the 4 channel inuke 6000?
Trimlock is online now
post #5 of 129 Old 07-19-2019, 03:27 AM - Thread Starter
Jk7.2's Avatar
Liked: 2685
Originally Posted by eng-399 View Post
Love this thread clone to the Titan 630’s
I knew you would be on board. Thanks Mike
corradizo and eng-399 like this.
Jk7.2 is offline
post #6 of 129 Old 07-19-2019, 03:28 AM - Thread Starter
Jk7.2's Avatar
Liked: 2685
No, the mains are on an emotiva xpa 7. So this will be a lot more power.
Jk7.2 is offline
post #7 of 129 Old 07-19-2019, 03:35 AM - Thread Starter
Jk7.2's Avatar
Liked: 2685
I think I also forgot to add, this amp will be on its own dedicated 20A circuit. It’s already available in my amp room. I’m also planning on adding a MiniDSP 10X10 to take care of the mains and subs. I’m just waiting until I make sure the 10x10 hd works with the WiFi adapter because that is so sweet to not have to hook up a wire to make changes. I hope I don’t blow up my speakers. I like them a lot.
Kevin4730, Trimlock and ian#77 like this.
Jk7.2 is offline
post #8 of 129 Old 07-19-2019, 06:23 AM
Quoted: 119 Post(s)
Liked: 131
No way it arrives in time. NO WAY. Unless you order it today.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is online now
post #9 of 129 Old 07-19-2019, 09:32 AM
hd0823's Avatar
Quoted: 783 Post(s)
Liked: 1518
lol There actually super fast with delivery usually less than a week we had ours in 5 days last time and when needing a replacement board I believe they had it air shipped and delivered in 3 days.
Sent from my SM-N950U using Tapatalk
Jk7.2 likes this.
hd0823 is online now
post #10 of 129 Old 07-19-2019, 10:15 AM
mtg90's Avatar
Quoted: 777 Post(s)
Liked: 1605
The woofers themselves are good for 600w continuous, 1200w program each. The limiting point in the design is the main low frequency inductor on the crossover, I don't recommend long term power of over 1000w unless you have the crossover placed in a way so that you can monitor the temperature of that inductor. Short bursts during normal movie/music content should be fine assuming you are not bouncing off the limiter the whole time.
mtg90 is offline
post #11 of 129 Old 07-19-2019, 12:41 PM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 902
Wouldn’t be too hard to up the inductor gauge if you can be sure the resistance doesn’t muck things up.
Is that a possibility?
@mtg90
Samps is offline
post #12 of 129 Old 07-19-2019, 01:10 PM
luv2fly3's Avatar
Quoted: 113 Post(s)
Liked: 228
Is that the same amp I now have? Be anxious to hear how that plays with your Titans. I'll also be anxious to hear your thoughts of the MiniDSP 10x10. Been thinking that would sure be a good way for me to really dial in my system.
Sent from my SM-N960U using Tapatalk
Jk7.2 likes this.
Spartans' Theater Build
7.2.4, 7 Seat Dedicated Theater
luv2fly3 is online now
post #13 of 129 Old 07-19-2019, 02:12 PM - Thread Starter
Jk7.2's Avatar
Liked: 2685
Not exactly the same. But yes. Pretty close.
luv2fly3 likes this.
Jk7.2 is offline
post #14 of 129 Old 07-19-2019, 02:13 PM - Thread Starter
Jk7.2's Avatar
Liked: 2685
Thanks Matt. So I plan on using the crossover as designed with the tweaks you prescribed before. Is that a good idea?
Jk7.2 is offline
post #15 of 129 Old 07-19-2019, 05:27 PM - Thread Starter
Jk7.2's Avatar
Liked: 2685
I ordered the MiniDSP 10x10. Man I hope I can keep all the hum issues at bay when I hook up all this stuff. As of right now, I have zero hums. But I’m always nervous changing things will cause hums. Well I’m all in now. I’ll post my graphs that kinda put me down this path soon. It shows how much bass I loose when I change my mains from small, crossover at 80, to large. This way with the amp and dsp I can boost the bass from 40 to 100ish in the mains and get things where I want them. It will take experimentation and measuring to get things right. And a few conversations with @eng-399 and @mtg90 thanks in advance guys you are both very helpful!
eng-399 and Mahuzz13 like this.
Jk7.2 is offline
post #16 of 129 Old 07-20-2019, 07:35 AM
BassThatHz's Avatar
Quoted: 3710 Post(s)
Liked: 4219
I'd recommend bypassing the crossover for the woofers entirely, which of course will require that the upper section still be powered with the Emotiva.
Generally the first thing to blow is the tweeter, especially so if you clip an amplifier.
However if you are boosting the woofers and playing bass-heavy content, then it is "possible" to blow those first I suppose.
The difference in power will be night and day, the amount of extra mid-bass you'll be able to kick out will be a tremendous difference.
If the woofers are truly rated for that much power then it "should be" okay...
If at any point in time the woofers drops towards 4-ohms, the wattage will only increase.
I ran quad 4-ohm LMS-18's on my Sanway 10k for 7 years, and all of that gear is just-fine to this day...
The 10k is flat from 7hz to 24khz I believe.
90% of my system is XBS powered now, and I have no hums. If you get hums it isn't the amps fault.
Worst-case: you need to upgrade to quad Emotiva monoblocks per speaker instead.
That said, higher-powered amps do tend to produce a bit more hiss, which is noticable on zillion-db/w/m tweeters, but IMO it's well worth putting up with given the increased power available on-tap...
Some people have said they can't stand the amount of hiss that the miniDSP's produce on mains. That was one of several reasons why I chose Motu 24's instead for that task.
Jk7.2 likes this.
BassThatHz is offline
post #17 of 129 Old 07-20-2019, 07:41 AM
BassThatHz's Avatar
Liked: 4219
Once XBS got my amps on a plane, FedEx got it here in like 2-3days. It didn't take long.
and that wasn't even next-day air shipping (if you really desire impatience.)
The lead time for DHL does seem to be faster in China though, which is what some of the other AVS'ers used...
Jk7.2 likes this.
post #18 of 129 Old 07-20-2019, 07:58 AM
johnson636's Avatar
Quoted: 1205 Post(s)
Liked: 701
Your idea is great! For the very same reason, I'll be going down this very same road soon. Audyssey set my 2180s to small and you do lose a lot while the speakers are set to small. I have my MF/HF running off AVR power and my PA460s running through a minidsp and then into a FP10k. When I set them to large, it's night and day. My center channel is not complete, so I only tinkered with the LR listening to two channel music. I suspect things will be more intense while watching a movie Really looking forward to your impressions of your final results.
Jk7.2 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #19 of 129 Old 07-20-2019, 11:22 AM
tential's Avatar
Quoted: 413 Post(s)
Liked: 276
After blowing 2 tweeters, I found myself here on the DIY section learning about amps. That was my introduction to DIY.
tential is offline
post #20 of 129 Old 07-20-2019, 03:59 PM - Thread Starter
Jk7.2's Avatar
Liked: 2685
Ok guys. Sounds like I’ll need to just bypass the crossover and run the woofers right off the amp! That way I’ll keep the mid/high on the emotiva, and not risk blowing anything. I’ll keep the woofers under control with a high pass and low pass in the dsp.
Question:
How high up should I run the woofers?
Oh, and should I worry that the timing could be off between the lows and the mid/highs?
Jk7.2 is offline
post #21 of 129 Old 07-20-2019, 04:09 PM
johnson636's Avatar
Liked: 701
Question:
Great idea running the woofers active...That's how I have mine. I'd run the woofers at the same crossover point as the original crossover. Use REW to measure and align until the response looks clean
Jk7.2 likes this.
post #22 of 129 Old 07-20-2019, 04:10 PM
eng-399's Avatar
Liked: 4976
Question:
Your going to have to level match the waveguide to the dual 15’s. Let me see how mine are set.
eng-399 is offline
post #23 of 129 Old 07-20-2019, 04:20 PM
eng-399's Avatar
Liked: 4976
eng-399 is offline
post #24 of 129 Old 07-20-2019, 04:28 PM
Nalleh's Avatar
Quoted: 2446 Post(s)
Liked: 3276
The WI-DG will work with the 10x10. I use on mine, and it makes adjustments a breeze from your comfy seat, so go for it
Compability list a bit down the page:
https://www.minidsp.com/products/accessories/wi-dg
Jk7.2 likes this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is offline
post #25 of 129 Old 07-20-2019, 04:53 PM - Thread Starter
Jk7.2's Avatar
Liked: 2685
Thanks! I’ll dig up the original titan crossover points. For some reason I think the 15 runs up to 500hz. (It’s 350hz)
And the woofers active idea is credited to mike, yourself, and BTH. And mtg 90, of course. I’m just trying to hang on! I don’t know what all you guys know. Thanks again for all the help!
Jk7.2 is offline
post #26 of 129 Old 07-20-2019, 04:54 PM - Thread Starter
Jk7.2's Avatar
Liked: 2685
Thanks Mike for posting all those screen shots! You know I need the help this close to the gtg!
Jk7.2 is offline
post #27 of 129 Old 07-20-2019, 04:56 PM - Thread Starter
Jk7.2's Avatar
Liked: 2685
Thanks for that! I did assume the 10x10 will work wirelessly, they list the Wi-dg for sale on the 10x10 page. I’m running all my bass through the WiFi connected 2x4 and it’s so awesome not having to connect a wire.
Nalleh likes this.
Jk7.2 is offline
post #28 of 129 Old 07-20-2019, 05:10 PM
corradizo's Avatar
Quoted: 1530 Post(s)
Liked: 1587
Devil's advocate: How loud would 1000w get one your Titans? If it's far beyond what your ears could ever stand or way above reference, it might not be worth going active on the woofers.
Jk7.2 likes this.
corradizo is offline
post #29 of 129 Old 07-20-2019, 05:13 PM - Thread Starter
Jk7.2's Avatar
Liked: 2685
Pete that was my original thought. Just power them with enough headroom, and boost the 40 or 60 up to 150 or whatever I end up liking. But honestly I don’t even know the sensitivity of these with the added woofer. I’m the complete opposite of a speaker designer. Lol
corradizo likes this.
Jk7.2 is offline
post #30 of 129 Old 07-20-2019, 05:18 PM
johnson636's Avatar
Liked: 701
Once you get these dialed in and set to large, don't be surprised if it sounds like you just upgraded your speakers. I suspect it will be some ear bleeding awesomeness at the gtg
Jk7.2 likes this.
