TM vs MTM for 2-channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-19-2019, 12:12 PM - Thread Starter
_tk
Quoted: 466 Post(s)
Liked: 186
I've read a bit about this but wanted to hear from folks who've built some of the DIY MTM's.
Simple question...does the MTM configuration work ok for a 2-channel setup or would I notice the "narrowness" when not in my ideal sitting position? They won't be nearfield...they will be about 8'-10' away and 6'-8' apart. I don't want to get myself into a "sweet spot" only type of deal.
Only reason why I'm debating an MTM configuration is due to the extra low-end they provide. But in reality, I'd probably be fine with a TM as I'm not going to listen at high levels. I also really want to build an MTM though for one reason or another...maybe I should just pick a cheap one like the OS or S2000 (to get it out of my system, lol).
_tk is offline
post #2 of 12 Old 07-19-2019, 12:34 PM
asarose247's Avatar
Quoted: 1229 Post(s)
Liked: 1076
I had a similar question wrt 2.0
given the performance of my F15's at a recent GTG
so I asked @mtg90 about the HTM12's and tuning lower, specifically with an eye on and an ear bent to being a 2.0 system.
his reply:
'If the HTM-12 was built as 18"w x 25"h x 18"d it will give an F3 in the upper 40's and in room should give decent extension and output down to the low 40's upper 30's. Ports for this modification do not need to be changed from the 3" stock length."
If your budget and DIY ability or other cab building resources are up for it,
you won't be "jonesing" about up-grade-itis.
go to the head of the class . .
the stereo image of those 15" SEOS horns IS going to put a smile on your face and in your ears-every time
you would of course do some REW and REQ , room treatment work . . .
HTH
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #3 of 12 Old 07-19-2019, 12:38 PM
Quoted: 119 Post(s)
Liked: 131
his reply:
HTH
Ha, I made the same mistake when reading OP the first time. MTM != HTM.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is offline
post #4 of 12 Old 07-19-2019, 12:56 PM - Thread Starter
_tk
Quoted: 466 Post(s)
Liked: 186
Yeah, not the "HTM-X" speaker specifically. The configuration of the 2-way TM design vs. the 2-way MTM design.
_tk is offline
post #5 of 12 Old 07-19-2019, 01:04 PM
asarose247's Avatar
Liked: 1076
the F15's, 11' away
and about 6.5', +/- C2C for the horns depending on toe-in,
toe-in more for larger stereo sweep spot
for the record . .
Name:	3 x 15's.jpg
post #6 of 12 Old 07-19-2019, 01:50 PM
Quoted: 1616 Post(s)
Liked: 1231
@_tk
The “narrowness” you describe from an MTM is usually only present when the MTM is horizontal and all the drivers are on the same plane. That’s when cancellation occurs when you go off axis.
I have MTM CMT340’s from ascend and I find their soundstage to be very wide with no “narrowness” compared to a standard TM speaker.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #7 of 12 Old 07-19-2019, 03:22 PM - Thread Starter
_tk
Quoted: 466 Post(s)
Liked: 186
So then...why shouldn't I go MTM over MT in a 2-channel environment? There must be a reason why 90% of the bookshelfs made today are all MT configuration?
_tk is offline
post #8 of 12 Old 07-19-2019, 04:05 PM
Liked: 1231
It’s cheaper...?
Smaller form factor is more attractive?
post #9 of 12 Old 07-19-2019, 05:34 PM - Thread Starter
_tk
Quoted: 466 Post(s)
Liked: 186
Originally Posted by Russdawg1 View Post
It’s cheaper...?
Sure, but not by too much. Not like it's double the price.
Short squatty speakers were never attractive IMO. A slender MTM would look a lot better.
Although, I was specifically referring to sound and if the MTM's have some characteristic that makes designers stay away.
_tk is offline
post #10 of 12 Old 07-19-2019, 05:48 PM
aarons915's Avatar
Quoted: 676 Post(s)
Liked: 610
MTM gives you more sensitivity, something like 3 db because of the extra driver, or in other words the MTM will take a half of watt of power to rock out and your TM will take 1 Watt. Amplifier power is cheap these days so I don't worry too much about sensitivity.
The bigger difference to me is that a TM sounds more natural because the midbass/midrange is all coming from 1 speaker instead of 2. Vocals coming from a line as in an MTM layout just doesn't sound as natural as coming from a single source because voices in real life come from 1 source.
There is also the lobing due to the driver spacing, basically there will be nulls at a certain vertical angle, you won't notice it on-axis but they will be ceiling reflections and they won't match the direct sound and therefore will make the sound not as clean.
aarons915 is online now
post #11 of 12 Old 07-20-2019, 11:57 AM - Thread Starter
_tk
Quoted: 466 Post(s)
Liked: 186
Thanks. That makes sense and would explain why MTM is more popular for home theater than it is for 2-channel.
_tk is offline
post #12 of 12 Old 07-20-2019, 02:24 PM
Quoted: 422 Post(s)
Liked: 348
Unless the 1/4 wave spacing is off or the listener is sitting 5 mm's away from the speaker, it should act as a point source with a good combination at the cross over. The MTM will add spl, but most OEM's use it to add additional range. The centers that use smaller speakers in a set, but they use 4 instead of 2, give them additional sensitivity down low to compete with the bigger towers.
MTM's are almost always going to be better, except if you are listening near field. They are also not always necessary, so people can still chose cheaper/smaller options.
Trimlock is offline
