MicroWreaker or Devastator 21? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By notfastenough
post #1 of 16 Old 07-21-2019, 01:48 PM - Thread Starter
Kothoga's Avatar
Quoted: 80 Post(s)
Liked: 132
Question MicroWreaker or Devastator 21?
Looking to build a horn sub to add to my La Scala IIs and I think I've narrowed it down to these two. The MicroWreaker is more along the lines of a true tapped horn where as the Devastator is more of a ported horn, one's a 15", the other a 21". The main use will be in a 2.1 music setting.
Input?
Comments?
Insults?
Theater: JVC RS540U, 2.35:1 142" screen, Onkyo RZ1100, Panasonic UB820, Outlaw Audio M2200 Monoblock x3, Klipsch RF7II, RC64II, RS62II, 5800CII x4 Atmos, PSA V3611 Subwoofer x2.
2 Channel: Parasound P6, Parasound A23+, Rega Planar 6 with Ortofon 2M Bronze, Klispch La Scala II.
Kothoga is offline
post #2 of 16 Old 07-21-2019, 02:46 PM
corradizo's Avatar
Quoted: 1532 Post(s)
Liked: 1589
corradizo is online now
post #3 of 16 Old 07-21-2019, 03:48 PM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 904
For music only, look at the skhorn or skram if you want to go really loud. A simple ported box with a good 18 or 21 will be enough for normal people loud.
Samps is offline
post #4 of 16 Old 07-21-2019, 03:55 PM - Thread Starter
Kothoga's Avatar
Quoted: 80 Post(s)
Liked: 132
Do you know this from experience?
Already paired quad 18"s with them and found there is no way to make a direct radiating subwoofer integrate with an all horn system.
Kothoga is offline
post #5 of 16 Old 07-21-2019, 04:00 PM
superkyle's Avatar
Quoted: 864 Post(s)
Liked: 407
Not sure if this helps but I went seeking something very similar. I ended up deciding on 2 beast mode versions of the devastator. It seems to have an excellent balance between the benefits of the horn and low end output for home theater and music.
Always destroying exergy!
superkyle is online now
post #6 of 16 Old 07-21-2019, 04:03 PM - Thread Starter
Kothoga's Avatar
Quoted: 80 Post(s)
Liked: 132
What exactly is the beast mode version of the Devastator? Dual B&C 21" ipals?
Kothoga is offline
post #7 of 16 Old 07-21-2019, 04:07 PM
superkyle's Avatar
Quoted: 864 Post(s)
Liked: 407
B.M.D. - Beast Mode Devastator
https://r.tapatalk.com/shareLink?sha...0&share_type=t
post #8 of 16 Old 07-21-2019, 04:20 PM
Samps's Avatar
Liked: 904
Sealed or ported would be the easiest to integrate. Just need a mic, REW and some time.
Taped horns would be the hardest due to their top end getting a little wild.
I’d give those quad 18s another try with a little more time spent on setup.
Samps is offline
post #9 of 16 Old 07-21-2019, 07:10 PM
notfastenough's Avatar
Quoted: 185 Post(s)
Liked: 215
Howdy neighbor!
Along the lines of what @Samps is saying, if 4 18s aren't integrating then something is amiss. Not claiming to speak for him, but I'd wager the intention is to say that whatever is lacking with the 18s setup possibly won't be fixed with a sub alignment change.
Have you done any measurements? Also what kind of space are you working with? Open space, closed, rough cubic feet? Also, what frequency are you wanting to set the HPF to the La Scalas?
notfastenough is offline
post #10 of 16 Old 07-22-2019, 01:35 PM
Red Five's Avatar
Quoted: 477 Post(s)
Liked: 315
What frequency range are you targeting?
Stormbreaker (For Sale) | Wisconsin Home Theater Meet Thread
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #11 of 16 Old 07-22-2019, 02:29 PM - Thread Starter
Kothoga's Avatar
Quoted: 80 Post(s)
Liked: 132
You're right, I didn't try too hard with the dual V3611s as they are setup perfectly for theater. They are staying put there.
Originally Posted by notfastenough View Post
Howdy neighbor!
The Colony huh? What's in your avatar? I cruise a C7Z, ordered a C8, thinking of swapping the Z for a ZR1.
See above, I didn't feel like removing the dual PSAs from the HT so I'm looking for options for the dedicated 2 channel system. Been reading every sub thread on the Klipsch forums and everyone eventually moves to a folded horn design to match the Scalas and jokes about the time and money spent on trying countless DR subs. Their favorite is the good old BF THT. Working with a 5,550 cubic foot room. I considered a sealed PSA S3611, hell, even a silly overpriced SB16, but then found this thread: https://www.avsforum.com/forum/155-d...ld-thread.html It got me thinking I should just skip to a horn and be done. Price doesn't matter much so when I tripped across the Devastator I got the idea of tossing a B&C 21iPal. I'd love to do a Skhorn but like the idea of a flat pack as my time is extremely limited and valuable.
The La Scalas really lack any true chest slam. The system sees anything from the wife's Wynton Marsalis to my TOOL and APC, the kid's Marshmello to the Fallout 4 soundtrack. Not looking for single digits but something to fill the void for the Scalas.
Kothoga is offline
post #12 of 16 Old 07-22-2019, 03:03 PM
Red Five's Avatar
Quoted: 477 Post(s)
Liked: 315
Mixed duty a Devastator will fill that void well without any resonance in the passband. Two of them will offer good extension and all sorts of chest slam
Edit: I have one 21DS115 in about 6000ft³ vented and it is still fun in that space. The iPal21 has a higher resonant frequency, if I remember it is 37Hz, so the response might look a bit different. Amps stable into 1Ohm is the other challenge, but it sounds like you can afford a Speaker Power SP1-6000.
post #13 of 16 Old 07-22-2019, 07:19 PM
Quoted: 185 Post(s)
Liked: 215
Avatar is a La Ferrari Aperta. Not mine, but I've driven and worked on them. C7 ZR1 is super cool, tons of torque and can be fairly reasonable to cruise around in. Great way to hang with the supercars! The C8 looks like it'll be awesome, like a modern De Tomaso Pantera.
If you're interested in hearing a pair of THTs, shoot me a PM. I don't have Klipsch mains, but it'll give you an idea for the low frequencies.
post #14 of 16 Old 07-23-2019, 12:14 PM
drewp29's Avatar
Quoted: 63 Post(s)
Liked: 56
I believe that is the 458th time someone thought your avatar was a 'vette. Lol, both are cool cars though, the Ferrari and Corvette.
drewp29 is offline
post #15 of 16 Old 07-23-2019, 01:31 PM
Quoted: 185 Post(s)
Liked: 215
I see what you did there
This is the same car at the dealer car show.
Muphasta likes this.
post #16 of 16 Old 07-25-2019, 01:56 PM - Thread Starter
Kothoga's Avatar
Quoted: 80 Post(s)
Liked: 132
Question
Never said it was a Vette, it obviously isn't.
Kothoga is offline
