Tapped horn or i.b. Garage audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-21-2019, 07:28 PM - Thread Starter
kgveteran's Avatar
Quoted: 754 Post(s)
Liked: 222
Im toying with a tapped horn idea for my garage. My garage is all drywall, i just installed a pulldown ladder to access the attic area. I can lay down a tall thin cab inbetween the trusses i have up there, or try an i.b. An i.b. Would be super simple, i can put a 15” in all four corners, or colocated..
My mains are little JBL 520’s, i measured a real nice 85-90db using my iphone db meter while listening to music, so 120db sub would be way over kill....
Thoughts
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is offline
post #2 of 10 Old 07-21-2019, 08:14 PM
VegaMan's Avatar
Quoted: 103 Post(s)
Liked: 79
IB would be way more simple to integrate than a TH. wont need a minidsp or similar to tame the TH, unless you already have an inuke laying around. trade-off is going to be output. a single th with a half decent driver may approach output of 4 or 6 inexpensive IB drivers
VegaMan is offline
post #3 of 10 Old 07-21-2019, 08:19 PM
FOH
FOH's Avatar
Quoted: 52 Post(s)
Liked: 263
If you go IB, go dual opposed to avoid the reactive motion imparted to the baffle.
FOH is offline
post #4 of 10 Old 07-21-2019, 08:46 PM
Audiophile75's Avatar
Quoted: 97 Post(s)
Liked: 48
I can’t really “recommend” but i am going to put four ceiling speakers in my garage myself pretty soon and I also will be needing a sub. I do like the idea of a manifold IB style over a box of any kind. I also won’t be needing huge amounts of bass so I’m thinking a smaller size (not 15”) speaker would be just fine. Maybe someone could direct us to a couple of cheeper 8”-10” (?) IB subs to do four manifolds, or just do two big manifolds on low/high power??
Audiophile75 is offline
post #5 of 10 Old 07-21-2019, 09:20 PM
kbclamper's Avatar
Quoted: 110 Post(s)
Liked: 33
I have a f20 in my garage and I can say my neighbors hate me but I love it paired with volt 10lx ported
kbclamper is offline
post #6 of 10 Old 07-22-2019, 05:32 AM - Thread Starter
kgveteran's Avatar
Quoted: 754 Post(s)
Liked: 222
Do you think its worth building a little 8” sealed sub to find a location that energizes the room/garage the best ?????
post #7 of 10 Old 07-22-2019, 09:29 AM
buggers's Avatar
Quoted: 33 Post(s)
Liked: 24
Definitely, especially with a cement floor.
buggers is online now
post #8 of 10 Old 07-22-2019, 09:39 AM
notfastenough's Avatar
Quoted: 181 Post(s)
Liked: 209
If you're using the garage as a garage (large objects changing locations often and any kind of listening position) I'd go for maximum coverage and use multiple higher tuned THs. Maybe 4 of the Anarchy THs corner loaded, should be more than adequate for keeping up with the JBLs. That and the Anarchy horns are small enough to be constructed on the ground and brought up an attic ladder.
If you have doubts about output, grab 2 or 4 picowreckers with the Alpine drivers.
notfastenough is offline
post #9 of 10 Old 07-23-2019, 06:27 AM
doodoobutter's Avatar
Quoted: 60 Post(s)
Liked: 27
I almost did this but I backed out from fear of my neighbors hating me. Instead I retired the old F20 to the basement gym for some extreme workouts lol. My basement is almost completely under ground, I was surprised when I cranked it up and you can't hear it 10ft from the house! Also, it really loses it's presence when it's on concrete. I now understand people's complaints about basement theaters.
doodoobutter is offline
post #10 of 10 Old 07-23-2019, 10:44 AM - Thread Starter
kgveteran's Avatar
Quoted: 754 Post(s)
Liked: 222
My basement is where i keep my spiders
