Sho-10 ribbon upgrade/conversion HELP - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By buggers
post #1 of 17 Old 07-22-2019, 04:57 PM - Thread Starter
frankie2075's Avatar
Quoted: 472 Post(s)
Liked: 115
Hey guys I have sho-10 speakers they are great for there price and there Day but I feel like they can be much better. I know there are many different options available from DIYSG but I’m looking for something fun to do and have different. So I don’t know if it’s possible I’m sure it is. I want to change it from what it is to a ribbon upgrade maybe keep the 10in woofer or change it if need be. Im looking to get smoother top end maybe warmer and more accurate sound. I have no experience of designing a speaker. I looking to keep the speaker enclosure. I can post pics of the inside of crossovers woofers CDs. I looking to make this as simplified as possible.
I got this idea after going to Dolby aroma theater when I went to see the lion king. They had ribbons in the speakers. I have a sho speaker that might or might not be blown or something in it messed up figure I start with that one and see how I sounds. Also if possible get the speaker to play lower. Thanks
System:
Two-way monitor system
High efficiency
Vented enclosure with slotted vent on front baffle
Frequency Response: 72 Hz – 18 kHz +/- 3 dB Drivers:
1” compression driver tweeter feeding a 90 x 90 degree controlled dispersion waveguide
10” Woofer
Crossover Point: 1600 Hz
Impedance: 8 Ohms nominal Sensitivity: 97 dB (2.83 Volts @ one meter, anechoic) Enclosure:
3/4" MDF
Slightly textured, matte black finish
Full length cloth grille
Dimensions: 19" H x 11.5" W x 9.6" D (including grille)
frankie2075 is offline
post #2 of 17 Old 07-22-2019, 08:42 PM
MKtheater's Avatar
Quoted: 2433 Post(s)
Liked: 2427
Don’t bother, a ribbon will cost so much to keep up with that 10 in sensitivity. The Sho-10 is still a great small speaker, I compared the Sho-10 with the pure 10 and it was close, very close, the pure 10 was just a bit smoother. The proper ribbon would cost more than the whole speaker alone.
MKtheater is offline
post #3 of 17 Old 07-22-2019, 11:03 PM
SpinMonster's Avatar
Quoted: 491 Post(s)
Liked: 301
You could change the compression driver out for a radian beryllium 1" which is really good HQ up top. It will bolt in easy and just leave you with crossover changes
SpinMonster is offline
post #4 of 17 Old 07-23-2019, 04:16 AM - Thread Starter
Quoted: 472 Post(s)
Liked: 115
Really? I went on parts express and they range from 50 to 150ish. I saw. What if I change out the woofer for something more “hifi” like a morel or sea drivers? Or just switch out the CD for something better?
Edit: just found this
But would this keep up?
https://www.madisoundspeakerstore.com/ribbon-tweeters/raal-original-140-15d-ribbon-tweeter-with-amorphous-core/
post #5 of 17 Old 07-23-2019, 04:18 AM - Thread Starter
Quoted: 472 Post(s)
Liked: 115
I see BE tweeters but then again what MK said he don’t think the ribbon will keep up with the woofer so I’m thinking the BE won’t keep up either?
post #6 of 17 Old 07-23-2019, 04:40 AM
buggers's Avatar
Quoted: 32 Post(s)
Changing out any of the drivers means you will have to design a new crossover.
buggers is offline
post #7 of 17 Old 07-23-2019, 07:25 AM - Thread Starter
Quoted: 472 Post(s)
Liked: 115
Yes I know.
post #8 of 17 Old 07-23-2019, 10:20 AM
buggers's Avatar
Quoted: 32 Post(s)
I see. Your statement "I have no experience of designing a speaker" threw me off...
buggers is offline
post #9 of 17 Old 07-23-2019, 10:37 AM
Quoted: 491 Post(s)
Liked: 301
I'm suggesting you use a Be compression driver. You already have a compression driver. Yes it can keep up
http://www.usspeaker.com/radian%20475bEpb-1.htm
post #10 of 17 Old 07-23-2019, 01:01 PM - Thread Starter
Quoted: 472 Post(s)
Liked: 115
Yea I don’t know The real technical stuff about designing a cross over I never made one on my own other the diysg kit. but I know the basics.
post #11 of 17 Old 07-23-2019, 01:03 PM - Thread Starter
Quoted: 472 Post(s)
Liked: 115
Yes but those are crazy expensive for me to play around with I just thought the ribbons I was seeing on parts express might work and weren’t crazy expensive. But for 500$ plus for the driver I would be afraid I would mess it up just starting out. But I would love to use something like that one day.
post #12 of 17 Old 07-23-2019, 04:19 PM
Quoted: 491 Post(s)
Liked: 301
I understand. Good ribbons are pretty expensive too.
post #13 of 17 Old 07-23-2019, 06:01 PM - Thread Starter
Quoted: 472 Post(s)
Liked: 115
Yea I’m seeing that now. Raal crazy expensive too.
post #14 of 17 Old 07-23-2019, 07:25 PM
MKtheater's Avatar
Liked: 2427
Yes, the ribbons that would keep up and match better in sensitivity are the expensive ones. All that work, extra cost, and hoping a different crossover will work is not worth it IMHO. I would start over.
post #15 of 17 Old 07-24-2019, 04:34 AM - Thread Starter
Quoted: 472 Post(s)
Liked: 115
Maybe just go with the titans from DIYSG with dual woofers instead of spending 500+ ea on raal tweeter it’s like 600 for the whole speaker
post #16 of 17 Old 07-24-2019, 05:25 AM
buggers's Avatar
Quoted: 32 Post(s)
That would be good idea
asarose247 likes this.
buggers is offline
post #17 of 17 Old 07-24-2019, 12:25 PM
MKtheater's Avatar
Liked: 2427
I just built my own for half as much as a titan, I went through lots of prebuilt crossovers to find one that works. Now If I want to build another there is no tinkering. Of course I could have gone active and just used digital dsp but I want them plug and play.
Nothing right now
