Surround and Atmos Speakers Inquiry - DIYSOUNDGROUP items only!! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Rcris
post #1 of 12 Old 07-22-2019, 08:45 PM - Thread Starter
Rcris's Avatar
Quoted: 99 Post(s)
Liked: 117
Think time has come to update my surrounds along with addition of atmos if possible.
My current setup:
Room : 22 x 13 ft , have a slanted roof, so it started from 10ft at one end to 8ft on the screen side.
LCR = JBL 4722
Surround back: Bose 201
Surround sides: Def-tech bipole speakers
Subs: PA460's + 2 sealed subs (Updating to 2 lavoce 21s)
I spent a whole lot of time trying to find a thread to convince me make a decision but I keep circling from Volt 8 to HT to Volt 10s and what not.
Which should I go for surrounds and Atmos? what do you recommend based on your experience.
Options: Volt all versions, HT all versions or any other DIYSG sets ( been waiting for vortex price range !!!)
Rcris is offline
post #2 of 12 Old 07-22-2019, 09:20 PM
Sekosche's Avatar
Quoted: 1427 Post(s)
Liked: 3587
What’s your seating distance?
If it’s on the short side of the room, I’d think either the Volt 8 or 10 could potentially be overkill depending on listening levels. Might even get away with the Volt 6 if getting a ported box. I like my Volt 10’s for Atmos, but I haven’t really tried them for anything else. The V6 and 8 don’t dig deep enough for an 80-100Hz crossover in the sealed cabinets, but the V10 does if that matters. Having built the 10’s, I probably could have easily gotten away with the 6 or 8 for my purpose, because these things are beasts for Atmos; compared to my large PSA surrounds, the Volt 10’s definitely look like overkill for overheads...but this is AVS.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #3 of 12 Old 07-22-2019, 09:21 PM
asarose247's Avatar
Quoted: 1229 Post(s)
Liked: 1076
some .02 thoughts
my room isn't much wider, 14.5, usable depth about the same, 8' ceiling
question: 1 or 2 rows of seating?
how close for folks sitting at the end position - i.e. potential hot spotting?
budget range?
solid walls both sides?
any in-wall / in ceiling I.B. possibilities / access
Volt8's are reported as doing well i.b. and you get extra room.
going for 7.2.4?
can you keep good separation for the tops from the bass layer.
can you post a labeled room layout.
HTH
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #4 of 12 Old 07-23-2019, 02:08 AM
mhutchins's Avatar
Quoted: 240 Post(s)
Liked: 229
+1 on the Volt 10's. I have them as surrounds and they match up very well with my Cheap Thrills (15" woof +12" SEOS).
I think your seating distances may be a bit close for good integration with the HTM's.
Mike
mhutchins is offline
post #5 of 12 Old 07-23-2019, 04:32 AM
johnson636's Avatar
Quoted: 1209 Post(s)
Liked: 702
Pics?
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #6 of 12 Old 07-23-2019, 06:08 AM
Sekosche's Avatar
Liked: 3587
Originally Posted by johnson636 View Post
Pics?
Here’s my build thread for them: https://www.avsforum.com/forum/155-d...topics/3056744
post #7 of 12 Old 07-24-2019, 10:23 AM - Thread Starter
Rcris's Avatar
Quoted: 99 Post(s)
Liked: 117
Its only one row seating for now, with a two seater recliner leaving 2-3' from listening position to near by wall.
Rcris is offline
post #8 of 12 Old 07-24-2019, 10:47 AM
asarose247's Avatar
Liked: 1076
very close . . .
think of positioning 10 15 degrees ahead of that seating
positioning is critical for that distance
Volt 6's on full motion mounts gives movement options if watching solo
these are my 88 specials as surrounds, in that 14.5 wide
but the mount , monoprice #3411 , gives me placement / aiming options
the v6's are even more shallow so perhaps better seating coverage
food for thought
this looks like good reach and yet tucks away tight to the wall: https://www.monoprice.com/product?p_id=15867
as the v6's weight much less than these did at 52+ #'s,
less expensive mounts with an extended reach might be considered
Name:	88 on 3411.jpg
ID:	2594104   Click image for larger version
Name:	88 on 3411 swing out.jpg
post #9 of 12 Old 07-24-2019, 11:06 AM
Jedi940's Avatar
Quoted: 283 Post(s)
Liked: 201
I have volt 10s for surround and volt 8's in the ceiling. They do an adequate job. I went with the volt 8's in the ceiling because they had slightly better off axis performance. Current theater is just an open basement with a drop ceiling so they are running IB up there and I don't have a problem with them. Just screwed them in to a sheet of 1/2 OSB and mounted the crossover right next to them. No they don't have quite the reach down low but most atmos content is about ambiance or very fast fly-overs. There isn't much bass in ambient noise and flyovers happen so fast I don't have time to notice the lack of bass before the sound is either in front of me where I have the bass capabilities or long gone behind me where I'm not focused on the sound. I'm sure at some point I'll upgrade to something bigger and better but for now I'm happy.
The volts are nice speakers and do have the dynamic range necessary for a theater system, however, when I first got them, I demoed them as mains briefly and they didn't have quite the presence I had hoped. I will probably upgrade to the HT or HTM series at some point for my surrounds. If you can manage that size, I would suggest those. The HTM-8 flat pack is only 1/2" deeper than the Volt 10 atmos.
Jedi940 is offline
post #10 of 12 Old 07-24-2019, 11:23 AM
Stephen Hopkins's Avatar
Quoted: 424 Post(s)
Liked: 196
I'm usually fairly budget-minded... so with a single listening position, I'd think Cobalt-8s could be a pretty good choice for surround duties. I'd also think Volt-8 or Volt-10 in IB would be the way to go for ATMOS, and since the ceiling slants down toward the screen wall, a flat ceiling mounting shouldn't be problematic either.
BenQ TK800 | Silver Ticket 106" 16:9 1.0 Grey | Marantz SR6011 | B&W P6 | B&W CDMC SE | Sonance .5 THX SUR | MCM In-Ceiling Atmos | Ascendant Avalanche 12" in 6 ft^3 @ 18Hz w/ BASH 500w Plate Amp | Sony X800 | NVidia Shield TV Pro | XBox One 500gb | Nintendo Switch | Harmony Smart Control | SmartThings Hub | Google Home | AT&T Fiber 300 | YouTube TV | Netflix | HBO Now | Spotify
Stephen Hopkins is offline
post #11 of 12 Old 08-11-2019, 08:31 PM - Thread Starter
Rcris's Avatar
Quoted: 99 Post(s)
Liked: 117
Just gotta review your build, great build .
Sekosche likes this.
Rcris is offline
post #12 of 12 Old 08-14-2019, 10:34 AM
Quoted: 119 Post(s)
Liked: 131
I prefer the look of sealed Volt 8s to ported Volt 6s, my $0.02.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is online now
