Sub woofers not working - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #91 of 117 Old 08-07-2019, 04:44 AM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
Originally Posted by johnson636 View Post
Disconnect all the speakers from AVR including the sub. You don't want to blow any speakers during this test. You'll need a female to female coupler and a regular rca cable
- Connect one end of th rca cable into the sub out on avr and leave the other end open.
- Connect a rca female to female coupler to the other end. if you don't have a coupler, you can use the male end to check for voltage. It's just more risky of a short
- Dial the master volume all the way to max.
- Put the multimeter in the required measuring mode (Volts) and set appropriate scale.
- Play a test tone (0dBFS 60Hz) you can find this on youtube
- Put the positive prong (red) inside the coupler and then touch the negative prong (black) on the outer rca ring.
- Your meter should read the max output voltage, whatever that is...maybe 2v. The point is to see how much voltage your avr pre-outs is outputting
How much more of a risk is there without a coupler? Where can I get one at? Amazon?
TIV13 is offline
post #92 of 117 Old 08-07-2019, 05:11 AM
Cichlid109's Avatar
Quoted: 271 Post(s)
Liked: 154
They are cheap maybe depending on where you go WalMart etc 6.00 for everything. The coupler as Johhnson suggested will allow you to connect 2 rca together they can either be with female or male ends. You can test w/o but you have the be careful if the probe touches both the gnd and the hot not good.
Denon AVR-4520 LCR BIC PL89ii's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height w/EP-2000, BIC DV84's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #93 of 117 Old 08-07-2019, 06:24 AM
johnson636's Avatar
Quoted: 1205 Post(s)
Liked: 700
As Cichlid stated, you can measure without the coupler, but you run the risk of the pronge slipping and both touching either the hot or ground The you most definely will end up needing another avr
Amazon
If you have a spare rca cable that you don't necessarily need, you can cut the rca connector off one end and use the two wires (one red for + and one black for -) to check for voltage. Just cut the wire back far enough so you can twist each wire to the appropriate meter prong
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #94 of 117 Old 08-07-2019, 08:22 PM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
Amazon
I ordered the coupler. Not worth the risk to just wait a couple more days.
TIV13 is offline
post #95 of 117 Old 08-07-2019, 09:23 PM
Oliver Deplace's Avatar
Quoted: 32 Post(s)
Liked: 40
Quite frankly, there's no need for a coupler. In fact, it'll be easier to just probe the RCA jacks.
Hold the negative probe against the RCA shell and insert the positive probe ½" into the RCA jack. Probe around with it until you see the meter register. For this purpose, an RCA jack is physically the same as a female coupler.
You'll be performing the same procedure with the coupler, only you'll have to hold down the coupler with the negative probe or you'll end up chasing it around the bench.
Really, if you're THAT concerned, then you should cut off the end of a cheap RCA cable, separate the wires, strip off some of their insulation and clip on.
Yo mama so fat, time slow when she near.
I don't wanna grow up, I'm an AVS kid.
Oliver Deplace is offline
post #96 of 117 Old 08-08-2019, 06:04 AM
johnson636's Avatar
Liked: 700
Not if his equipment is in a tight spot like mine. It's easier for me to run a rca from the back to the front so I could comfortably perform this task
I suggested that to him already in my previous post. That is exactly what I do, but some people may not want to waste a rca cable for a task they may only perform once
I use mine for various tasks in my system
post #97 of 117 Old 08-10-2019, 01:31 AM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
This is the multi meter I got.
What setting do I need to turn the dial to?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For this step "Put the positive prong (red) inside the coupler and then touch the negative prong (black) on the outer rca ring"
The negative prong going to the rca ring, is that the rca ring connected to the coupler? Correct?
Thank you for the help.
Edit :max volume on my avr, correct?
TIV13 is offline
post #98 of 117 Old 08-10-2019, 05:41 AM
Cichlid109's Avatar
Quoted: 271 Post(s)
Liked: 154
To measure the voltage turn the dial to the 20V setting 3rd setting to the left of off. Do exactly as suggest with everything disconnected with volume on max. if the sub pre outs are good you will read approx 2 volts if bad close to 0 or nothing. If you should get nothing then very excellent chance the Denon needs repair. Based on the tests so far hopefully the problem is getting narrowed down?
post #99 of 117 Old 08-10-2019, 07:23 AM
johnson636's Avatar
Liked: 700
Since you're only looking for about 2v, set your meter to the lowest AC voltage setting. Positive prong inside the coupler and negative prong outside.
post #100 of 117 Old 08-10-2019, 07:48 AM
Cichlid109's Avatar
Quoted: 271 Post(s)
Liked: 154
Well ok if 20 was too high drop it down, my mistake.
post #101 of 117 Old 08-10-2019, 04:30 PM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
I adjusted the dial to 10 and 200. Both on the right side of the multi meter.
I plugged up my RCA cable to sub output 1 and put the red inside and the black on the outside metal part.
The multi meter registered at 0 on both the 10 and 200.
Does that sound right? Sounds like its got no output.
Edit:
I turned my volume up to max(91) and used this youtube video.
I played the video while touching the coupler. I did this 3 times and got nothing all 3 times.
Did I do anything wrong?
TIV13 is offline
post #102 of 117 Old 08-10-2019, 05:54 PM
johnson636's Avatar
Liked: 700
Edit:
https://www.youtube.com/watch?v=GqwFimG3X3w
Check the center channel rca the same way. If you register 2v from the center channel rca, then your sub out rca is bad.
post #103 of 117 Old 08-10-2019, 09:57 PM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
Does it matter which color I check? Do I need to use the rca cable or regular speaker one? Donno if that matters but want to ask.
Sent from my SM-N910V using Tapatalk
TIV13 is offline
post #104 of 117 Old 08-11-2019, 12:38 AM
johnson636's Avatar
Liked: 700
Check the RCA for the center channel just as you check Ed the RCA for the subwoofer channel.
post #105 of 117 Old 08-11-2019, 03:15 AM
Cichlid109's Avatar
Quoted: 271 Post(s)
Liked: 154
So far its looking like sub pre outs not good if when you check a known good one and you get 2V now you know where the problem lies and at least you know your set up for the mini was good along with subs and amp. If indeed it is the Denon hope its still under warranty?
post #106 of 117 Old 08-11-2019, 10:38 PM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
I did the test as above with the rca cable, and wiggled it around inside the black center slot and got 0.00 too.
So now I'm wondering if I did the original test correct.
My center channel is traditional speaker cable wire(red black). The RCA cable won't plug into the center slot on the back of my AVR.
Can I touch the multimeter straight to the speaker wire cable(black) and not worry about my AVR blowing up?
Edit: The coupler wont fit on the cable end of the speaker wire.
TIV13 is offline
post #107 of 117 Old 08-12-2019, 06:00 AM
johnson636's Avatar
Liked: 700
What What do you mean the the rca won't plug into the center slot? What model denon do you have The reason I suggested testing the center channel rca was to compare you subwoofer channel to a none working channel.
post #108 of 117 Old 08-12-2019, 06:03 AM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
Denon 4400.
The plug is made for banana plugs and not rca cables. There is a piece of plastic blocking the rca cable from being plugged in.
TIV13 is offline
post #109 of 117 Old 08-12-2019, 06:07 AM
johnson636's Avatar
Liked: 700
Denon 4400.
I'm not sure what you're talking about, but you should have a rca pre out for the center channel right about the subwoofer 1 rca pre out.
post #110 of 117 Old 08-12-2019, 06:13 AM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
You are correct. I just checked a picture.
I'll do the test later today and hopefully this will be the last of it.
Thank you so much for your help.
TIV13 is offline
post #111 of 117 Old 08-13-2019, 01:19 AM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
Just did the test.
I had to use the 200 on the right side.
The center pre out had 1.5. The sub had 0.
I did the test 3 different times and got basically the same result.
Looks like the pre out is bad. Does that sound right to anyone else?
TIV13 is offline
post #112 of 117 Old 08-13-2019, 05:17 AM
johnson636's Avatar
Liked: 700
Just did the test.
Are you sure your speakers are set to small? It is odd that the sub out is not registering any voltage at all. If you're up to it, try measuring the voltage of the sub out while playing the internal avr test tone. You did say you get sound from the subwoofer while playing the internal avr test tone correct?
post #113 of 117 Old 08-13-2019, 05:18 AM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
Yes that was one of the first things I found in my online research.
I did get sound correct. Just very quite.
I will do that later this afternoon.
TIV13 is offline
post #114 of 117 Old 08-13-2019, 06:31 AM
Cichlid109's Avatar
Quoted: 271 Post(s)
Liked: 154
Not implying what you did is wrong but based on everything I know and have read it seems you have something set wrong? If it were me I would start over and go step by step. I am sure your Denon has a setup menu. In my opinion you have something set wrong if the sub preouts were shot then there would be no sound but in your case some but quiet. You really need to follow directions and read the manual my best guess and its only guess if you were to send the Denon back and get it replaced odds are the next one would give you the same issues. We can suggest but in the end you have to do your part as well.
post #115 of 117 Old 08-13-2019, 07:09 AM
johnson636's Avatar
Liked: 700
That is a concern I have as well. OP, have you run a setup Audyssey calibration. If I'm not mistaken, you have to run the calibration while the subwoofer is present and active. In other words, you can't run the calibration without a sub, then add a sub later without rerunning another calibration... doesn't work that way. I think
Cichlid109 likes this.
post #116 of 117 Old 08-13-2019, 01:36 PM - Thread Starter
Quoted: 62 Post(s)
Liked: 2
Yea I definitely don't want to waste money on sending it off and not have the issue resolved.
I did re run x32 when I plugged up my subs. It was actually one of the first things I did.
TIV13 is offline
post #117 of 117 Old 08-13-2019, 01:54 PM
Cichlid109's Avatar
Quoted: 271 Post(s)
Liked: 154
Considering everything also knowing Denon makes a good product I find it hard to believe that a brand new Denon is not working its possible but not likely. I stand by my previous post if it were me I would disconnect everything follow the Audyessy set up. On my Denon I go the set up assistant yours should be about the same. Provided you follow it properly you should get sound out of subs. As many questions as you have asked it just seems whether I am right or wrong you missed something as far as setup goes. I could be wrong but before you return the Denon if it were me I would redo but that is me and I am not you.
up the spkrs then adding a sub
