Can I (or should I) power 4 18" DIY subs with an EP4000 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By markmon1
  • 1 Post By FOH
post #1 of 28 Old 07-29-2019, 01:33 PM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
I'm currently running 2 sealed 18" SI drivers off of a Behringer EP4000. I have the opportunity to buy 2 more sealed 18" (same drivers) and was wondering if I can power them using my existing EP4000 or if I need to get another amp?
Sorry if this is a dumb question.
toothboy is offline
post #2 of 28 Old 07-29-2019, 01:38 PM
Kpilk's Avatar
Quoted: 89 Post(s)
Liked: 91
Yes....yes you should.
Edit....I know where you can get two more.
Kpilk is offline
post #3 of 28 Old 07-29-2019, 01:57 PM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
So how would I go about doing this safely? Do the 4 get wired in parallel to the amp? Should the amp run bridged?
I'm really hesitant to proceed with purchasing the other 2 subs before I know for sure how to wire these things up properly.
toothboy is offline
post #4 of 28 Old 07-29-2019, 02:45 PM
smcmillan2's Avatar
Quoted: 1032 Post(s)
Liked: 881
Which SI drivers? VC and ohm configuration?
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 28 Old 07-29-2019, 02:49 PM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
Not sure which SI drivers (although I can probably find out). These were probably built when the first SI 18" were being used in DIY subs. They are wired 4 ohms each. Previous owner was running all 4 off of the EP4000. I wasn't sure I wanted 4 new subs (already have 4 others) so initially I just bought the amp and 2 subs, but now of course I'm going back and buying the other 2.
toothboy is offline
post #6 of 28 Old 07-29-2019, 03:05 PM
smcmillan2's Avatar
Liked: 881
Sure. Wire pairs of them up in parallel for 2 ohm loads, one pair on each channel.
post #7 of 28 Old 07-29-2019, 03:44 PM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
Awesome. Thank you.
toothboy is offline
post #8 of 28 Old 07-29-2019, 06:53 PM
Kpilk's Avatar
Quoted: 89 Post(s)
Liked: 91
You should be set as they are. Those are dual 2 ohm subs and currently all 4 are set up at 4 ohm loads. Two 4 ohm loads per channel will get you two 2 ohm loads to the amp.
Kpilk is offline
post #9 of 28 Old 07-29-2019, 11:11 PM
BassThatHz's Avatar
Quoted: 3923 Post(s)
Liked: 4435
Can you?
Yes.
Should you?
No.
An fp20k is about 8 times more powerful at this task.
It's about the same weight and slightly deeper.
90's efficient vs 50's efficient.
When you need to power 4 subs in 2RU, it's pretty much the best-value going right now.
Perfect fit for a x4 miniDSP
The next best-value would be two NUDSP-4k's, it's twice the RU but the price savings on the integrated DSP is substantial; hence why it is the most popular DIY amp around.
Since you already have an EP4k that sort of changes the dynamics a bit, but the general principle still holds.
BassThatHz is offline
post #10 of 28 Old 07-29-2019, 11:45 PM
noah katz's Avatar
Quoted: 2307 Post(s)
Liked: 851
Originally Posted by BassThatHz View Post
Can you?
Yes.
Should you?
No....
Sure more power and DSP is better but you can't argue that he's not better off by adding two drivers - he gets lower distortion and power compression for the same SPL, higher efficiency, and higher SPL capability.
Actually if no DSP/EQ now, I'd spend less money to get that, unless OP is blessed with flat response w/o EQ.
Noah
noah katz is online now
post #11 of 28 Old 07-29-2019, 11:46 PM
noah katz's Avatar
Liked: 851
Can you?
Yes.
Should you?
No....
Actually if no DSP/EQ now, I'd spend less money to get that (MiniDSP or inuke w/DSP), unless OP is blessed with flat response w/o EQ.
Noah
post #12 of 28 Old 07-30-2019, 05:57 AM
FOH
FOH's Avatar
Quoted: 54 Post(s)
Liked: 266
Under the original premise of dual 2ohm loads across an EP4K, why wouldn't he be better off 4ohm bridged to mitigate bus pumping?
FOH is offline
post #13 of 28 Old 07-30-2019, 06:04 AM
markmon1's Avatar
Quoted: 5865 Post(s)
Liked: 3936
I run 4 4-ohm subs off the EP4000. I prefer the amp bridged and all 4 subs wired in series / parallel to present a single 4 ohm load to the amp. Of the 6 EP4000's I've had, I've never once had the same performance on both channels but they perform great bridged.
lknhomeaudio likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #14 of 28 Old 07-30-2019, 08:24 AM
FOH
FOH's Avatar
Quoted: 54 Post(s)
Liked: 266
My experience is similar.
It's been sometime, however as I've explored all my powering options with two EP4K amps on hand, and four 4ohm Fi-IB3-18 drivers in an IB manifold, the best config is a single amp bridged mono.
My IB is easily 10xVAS, with an entire sprawling ranch home attic. The drivers achieve full stroke at somewhere around 200-300 watts.
Initially I thought two 8ohm loads on each side of the amp would be great. After more testing, I repeatedly saw the odd channel inconsistency, which I'm guessing originates from some type of high current rail dump.
The huge amounts of energy being exchanged between the power supply and the load, during worst case scenario single digit freqs approaching full power, oftentimes exhibited an odd lack of uniformity.
Yeah this is torturous for the budget amp, but bridged config alleviated these issues. Similiar results can be had inverting polarity on one channel (and then obviously switching it back afterward). However that establishes somewhat different power levels that may or may not align with your needs.
With an IB, it's been my experience without that acoustic high pass filter of small sealed, you really need to get the power levels correct as to be between bottoming the coil or have an anemic response.
The high excursion low power operation excels at minimizing thermal compression and minimizing flux modulation current distortion.
That said, this is but one of many ways to achieve that same goal.
markmon1 likes this.
FOH is offline
post #15 of 28 Old 07-30-2019, 09:00 AM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
All great info. I have a miniDSP btw.
toothboy is offline
post #16 of 28 Old 07-30-2019, 10:20 AM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
So would this be the correct way to wire them to the EP4000 bridged?
toothboy is offline
post #17 of 28 Old 07-30-2019, 12:41 PM
FOH
FOH's Avatar
Quoted: 54 Post(s)
Liked: 266
Yes, as long as all four of the drivers are identical.
Are your drivers dual 2ohm coils,... as represented in this graphic?
FOH is offline
post #18 of 28 Old 07-30-2019, 12:47 PM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
yes
toothboy is offline
post #19 of 28 Old 07-30-2019, 12:49 PM
FOH
FOH's Avatar
Quoted: 54 Post(s)
Liked: 266
Additionally, I'd ask the previous owner what impedance configs they successfully employed.
Be mindful of the proper amp settings, ie., dip switches, and front gain pots.
FOH is offline
post #20 of 28 Old 07-30-2019, 12:49 PM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
I know there has been some past confusion on how to properly set the EP4000's switches to properly do bridged mode...if anyone has any pointers on how to set the switches I'd appreciate it.
toothboy is offline
post #21 of 28 Old 07-30-2019, 12:50 PM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
Previous owner was running a pair off of each amp channel.
toothboy is offline
post #22 of 28 Old 07-30-2019, 12:53 PM
FOH
FOH's Avatar
Quoted: 54 Post(s)
Liked: 266
Stereo 2ohm, or stereo 8ohm?
FOH is offline
post #23 of 28 Old 07-30-2019, 12:56 PM - Thread Starter
toothboy's Avatar
Quoted: 47 Post(s)
Liked: 54
Stereo 2 ohm
toothboy is offline
post #24 of 28 Old 07-30-2019, 01:54 PM
Kpilk's Avatar
Quoted: 89 Post(s)
Liked: 91
I'm previous owner. Started with 8 ohm loads in the very beginning just to compare to 2 ohm loads. Certainly more output at 2 ohm.
Kpilk is offline
post #25 of 28 Old 07-31-2019, 01:24 AM
markmon1's Avatar
Liked: 3936
Yes if each is a 4ohm driver.
markmon1 is offline
post #26 of 28 Old 07-31-2019, 06:37 PM
BassThatHz's Avatar
Liked: 4435
front gain pots.
They aren't gains, they are input attenuators.
Fully CW means no loss.
Fully CCW means maximum loss.
post #27 of 28 Old 08-02-2019, 05:01 PM
FOH
FOH's Avatar
Quoted: 54 Post(s)
Liked: 266
Brother, good point that is what they do, they attenuate the input.
However, as to what they are, ...I know what they are, you know what they are, Behringer knows what they are...
They're gain pots. They are potentiometers,... the point of access for gain staging adjustments. As to what they're called, myself I like gain pots. In the pro realm as a FOH engineer, that's what they're called as a trade name.
But yep; Pendant = BTH & FOH
Well, you may be too young to remember SNL's debut season; New Shimmer, "it's a floor wax", "it's a desert topping", "Hey you two, It's both"!
FOH is offline
post #28 of 28 Old 08-02-2019, 07:01 PM
BassThatHz's Avatar
Liked: 4435
We know that we know.
Yes they are resistive "potentiometers", but they don't "gain" anything.
-0db is no loss of input voltage and -Infinity basically means 100% loss of input voltage.
To me "gain" means: the ability to take something and make it louder. Which they don't\can't do.
Amplifiers have a fixed gain, and input attentuators, and fancier amps (like the FP's) have input sensitivity adjustment;
and fancier amplifiers still, such as the crowns, inukes, powersoft etc have onboard DSP that have true "static gain" adjustment in the software(only), and often input sensitivity adjustment and load monitoring and EQ, limiters (and a bunch of other junk) in the software too.
I like calling them what they are: input attentuators, that way the noobs don't get confused as to their purpose/function. hehe!
The master volume knob and trims and level-sliders on your AVR/preamp/mixing-board are true "gains" or level controls (at least as far as the external-facing implementation it is...), they boost and output more voltage that what went in.
"gain structure optimization" I'll let pass, because their isn't a better phrase for it.
The goal of that being: to be able to output max-power without early-clipping any inputs or outputs in the system (digital and analog inclusive).
Often it is a battle between:
"how loud can the system get without electrically clipping"
vs
"how many acoustical db's can the system safely generate"
vs
"how loud does the user actually desire/want it to be"
vs
"a realistic/achievable/tolerable average(or maximum) SPL level with say 20db of dynamics headroom i.e. standard THX calibration / recording studio mixing standards".
Which are 4 entirely-different things and often inter-competing things.
A 20db swing takes a lot of horses, that's a 100x increase in power (beyond the average-level) without clipping or melting or bottoming out.
Few systems can actually achieve that, and that's just THX-level, not even factoring in a hot or aggressive playback level yet.
It is problem I've been terrorized with for years. It took like 32 subwoofers and 100kW of FP amplification to have sufficient headroom to meet the demands I was desiring/placing on the system. 16 subs and 8 "normal" pro-amplifiers simply wasn't enough.
I could still use another 5 24's and another 2 FP20k's to fill in the <20hz.
Never-enough <20hz.
