Dual Anarchy 558 bookshelf speaker build- box size and porting? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Erich H
post #1 of 2 Old 08-04-2019, 04:15 PM - Thread Starter
rr14's Avatar
Quoted: 130 Post(s)
Liked: 32
Hi all,
a while back I did a sealed center channel speaker in the form of a sound bar above my tv. It's now time to do the L and R channel speakers. I have more flexibility as far as dimensions, so I was thinking of making a set of bookshelf speakers that are ported.
Any idea what size box I'd be looking at and port specs? These will be used with a subwoofer and driven by a denon x4400 which gives me the ability to throw a little eq at them if needed.
edit, i saw .5 cu ft tuned to 42 hz for what i assume is 1 woofer. What would a 42 hz port look like for these if I do a 1 cu ft box?
http://techtalk.parts-express.com/fo...ns-apollo-ares
specs are here on post 30
http://techtalk.parts-express.com/fo...llo-ares/page2
rr14 is offline
post #2 of 2 Old 08-05-2019, 02:56 PM
Erich H's Avatar
Quoted: 1882 Post(s)
Liked: 2696
For a pair:
1cf cabinet with a 7" wide by 1" high by 8.5" deep slot port or a pair of 2" ports, 8" long.
F3: 38Hz
SPL @ 30m/s port velocity: 95W delivers [email protected]
eriksells916 likes this.
_______________________
The SEOS Waveguide Project
Erich H is offline
