Sub build in electric fireplace - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-10-2019, 09:52 PM - Thread Starter
Liked: 0
I’m looking to build 2 possible 3 subwoofers.
Living room is 12x14x12 high with an a frame and open to kitchen on one side. It’s a condo so I can’t have volume too high but I want good base down to 20-25 hz.
First, I found a Bic f-12 for $75 on offer up. Should I get that just bc it’s so cheap?
I was considering building a corner sub and still am, but I found a space behind my electric fireplace that is about 40”x16”x8” but I could extend the depth of 8” a little. So it’s about 3’ cubed. It’s under the TV, but 2’ off the floor and the speaker would point towards the wall.
Would this be a good spot? If so could you recommend a good sub to put in it?
John Wigginton is offline
post #2 of 3 Old 08-12-2019, 04:08 AM
kagtha's Avatar
Quoted: 105 Post(s)
Liked: 121
Try a VBSS.
Sent from my Pixel 3a using Tapatalk
Bedroom Audio: Two Shallow Under Bed PA310-8 12's energized by an SPA250DSP Plate Amp. Two BST-1s. 75 Watt 7.1 Onkyo AVR with Five Martin Logan MLT-2 LCR & Surrounds.
Living Room Audio: One Behringer NX6000D flexing four PA460-8's in a contemporary VBSS credenza build, 100 Watt 5.1 Sony AVR zapping Three horizontal Elusive 1099s LCRs and Two Martin Logan MLT-2 Surrounds. Two BST-1 Bass Shakers charged by the MLT-2 Sub Amp.
kagtha is offline
post #3 of 3 Old 08-14-2019, 10:36 AM
Quoted: 119 Post(s)
Liked: 131
That's a good deal on the F12, might be worth grabbing it and using it while you figure out a good DIY option.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is offline
