Vented Sub: how much lining? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Shadowed
  • 1 Post By buggers
  • 1 Post By head_unit
post #1 of 15 Old 08-13-2019, 10:05 AM - Thread Starter
Mark Bevier's Avatar
Liked: 1
Hey all,
I'm in the process of building a very narrow variation of the VBSS and was curious what people's thoughts are on how much lining to use. Based on what I read at data-bass on their test (https://www.data-bass.com/data?page=content&id=79), it looks like the lining helps smooth out response issues with enclosure / port resonance. Granted, they were stuffing pillows in rather than lining. The trade-off was efficiency, where it looks like SPL and especially port contribution dropped quite a bit.
That said, this is a fairly atypical box. Akin to the stonehenge, but even more narrow at only 10" deep. Total dimensions are 31"x49"x10" and will be right up against the back of a couch.
Given all that, does this look like overkill lining, just right, or is lining not something worth the loss in SPL? This is lined with UltraTouch R6.7 (~1.8")
Mark Bevier is offline
post #2 of 15 Old 08-13-2019, 11:34 AM
CrusherW9's Avatar
Quoted: 211 Post(s)
Liked: 122
Looks like an amount I'd strive for.
"Becoming educated is more than just acquiring knowledge. It involves the ability to see the world in ways never before conceived."
CrusherW9 is offline
post #3 of 15 Old 08-13-2019, 11:43 AM
Shadowed's Avatar
Quoted: 941 Post(s)
Liked: 911
None is required for ported boxes.
N8DOGG likes this.
Shadowed is offline
post #4 of 15 Old 08-13-2019, 12:10 PM - Thread Starter
Liked: 1
I was curious if there would be a vote for none - in the VBSS thread and some others I've seen it recommended to line the walls. Have you not noticed any improvement by lining the walls? Interested to know more!
I'm also somewhat curious on the effect on efficiency / SPL when lining. The experience I linked was basically stuffing a vented sub with pillows which might have a more profound effect?
post #5 of 15 Old 08-13-2019, 12:24 PM
Shadowed's Avatar
Quoted: 941 Post(s)
Liked: 911
There was one member who used a couple of pillows in the center of a very long box to help alleviate standing waves.
Higher frequency boxes ie: non-subs can benefit from lining is my understanding. Box fill is beneficial for sealed cabs.
Shadowed is offline
post #6 of 15 Old 08-13-2019, 01:49 PM
Quoted: 422 Post(s)
Liked: 348
Fill isn’t even required for sealed. Lining to help with standing waves if there are any. I have two MBM’s with no lining and there isn’t an issue.
Trimlock is offline
post #7 of 15 Old 08-13-2019, 01:51 PM
lknhomeaudio's Avatar
Quoted: 249 Post(s)
Liked: 123
Ported here, with no lining. If there are any problems, I can't hear them. 3dB variance from tune frequency up to 100hz. Sounds good to me!
lknhomeaudio is offline
post #8 of 15 Old 08-13-2019, 02:00 PM - Thread Starter
Liked: 1
I've read that if any interior dimension of the box is 1/4 of a wavelength in pass band, it can cause a standing wave (citation needed). Since this thing is pretty long in two dimensions, the height would put it around 1/4 wavelength of 100hz and the width around 70hz. Could be an interesting problem that the lining might help address (or pillows as mentioned earlier).
Given the long dimensions of this box, lining may be appropriate where it might otherwise not be? If so, then the next question would be - how much does it take to kill 70-100hz standing waves?
post #9 of 15 Old 08-13-2019, 02:31 PM
johnson636's Avatar
Quoted: 1209 Post(s)
Liked: 702
But you already have it lined I have two ported boxes 48x32x24 and no lining
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #10 of 15 Old 08-13-2019, 02:37 PM - Thread Starter
Liked: 1
Ha, yeah - I'm about to attach the baffle and wanted to get some thoughts on it before changes become difficult. Easy enough to take out some lining right now, later it will be more annoying. I'm most wary of over lining it for no benefit and losing spl as a result. If there's no real detriment to this lining, then I'll just leave it and continue on till I stump myself with another design decision
post #11 of 15 Old 08-13-2019, 02:45 PM
Chris Popovich's Avatar
Quoted: 164 Post(s)
Liked: 147
Chris Popovich is offline
post #12 of 15 Old 08-13-2019, 02:52 PM
lawdogx's Avatar
Quoted: 118 Post(s)
Liked: 118
This topic has always confounded me. Go on Facebook and check out pages of respected builders like JTR and PSA and you’ll see them lining their vented subs. I changed an amp on one of my Hsu subs and it was lined. And guys on here like Bill Fitzmaurice says do line them. On the other hand, other guys who definitely know a thing or two about subs say don’t bother. Check out the GSG site. Those guys are pros and they say not to line them.
On my four mini marty’s I lined two and didn’t line the other two. By ear and by REW I can’t detect a lick of difference. On the VBSS’s I just built I lined them (pretty much like yours). Why? Because it’s Matt’s design and the instructions say to line them.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's (and always building, currently working on VBSS's).
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d.
lawdogx is online now
post #13 of 15 Old 08-13-2019, 03:36 PM - Thread Starter
Liked: 1
I'm also fuzzy on the length a dimension needs to be to cause issues. If it's the full wavelength, then it's way up in the 280hz range and well beyond the pass band of a subwoofer. At 1/2 wavelength it's 140hz, conceivable some up here, but with 80-100hz crossover likely not much? I recall 1/4 wavelength being about the shortest to cause issues, which the 48" would definitely bring into play.
Based on what I've been reading today, the best case scenario would have been to not have a dimension at or greater than 1/4 wavelength of anything in the pass band - but I'm space constrained and this was purpose built to a location, couldn't be avoided. Good to know as a general guideline though.
Now it's a matter of whether trying to address that issue is worth it or not. I'd imagine the most effective area to try and control the standing wave along the 48" width would be on the left and right sides of the box and maybe even on the left and right sides of the braces around the driver.
Or maybe I just close it up and measure later, haha. Stuff a pillow in if it bothers me
post #14 of 15 Old 08-14-2019, 04:50 AM
buggers's Avatar
Quoted: 33 Post(s)
Liked: 24
Leave the lining as is, seal it up and let's get rocking. No need to over think it...
Heide264 likes this.
buggers is offline
post #15 of 15 Old 08-15-2019, 10:59 PM
head_unit's Avatar
Quoted: 560 Post(s)
Liked: 291
Stuffing causes the heat exchange when the air is compressed to change from adiabatic to isothermal (or maybe vice versa, I always forget). This can make the box appear effectively larger, in theory like 40%. Nice for sealed boxes!
For ported, trickier. You don't want to block airflow around the ports, and if the box appears larger it will throw off the tuning unless you compensate. Stuffing by itself cannot cause loss of SPL, however a lowered tuning will lose some SPL at higher bass and gain some lower down.
Lining can be viewed as a layer of stuffing, but more to absorb high frequencies inside the box so they don't transmit out through the box walls or cones or ports. What you have looks good, according to science, the gods of acoustics, and the tea leaves I'm looking at
head_unit is offline
