HT/HTM HF Pad vs. EQ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-13-2019, 10:00 PM - Thread Starter
Mark Bevier's Avatar
Liked: 1
I see that the HT/HTM series comes with an HF pad to tone down the treble by 1-2db. Is there any reason to engage this if you are going to run Audyssey and EQ it anyway? Would there be any difference to dropping the highs 1-2db through EQ on the AVR vs the HF pad?
I'm mostly curious because I've seen people put in a toggle switch to engage the jumper but am not sure why when EQ is readily available in most home theaters anyway. It just there if you don't have EQ? Some other advantage?
Mark Bevier is offline
post #2 of 3 Old 08-14-2019, 04:06 AM
LTD02's Avatar
Quoted: 2934 Post(s)
Liked: 3652
doing it passively will take down amp noise by the amount of the passive attenuation while eq will not. if amp noise is not a problem, then eq should be fine.
also, many people don't have eq.
Listen. It's All Good.
LTD02 is online now
post #3 of 3 Old 08-14-2019, 07:19 AM - Thread Starter
Liked: 1
Makes sense, good to know - thanks!
