Upgrade to GSG devastators from DTS-10’s? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By notfastenough
  • 1 Post By noah katz
  • 1 Post By mcallister
  • 1 Post By trilkb
post #1 of 6 Old 08-14-2019, 04:28 AM - Thread Starter
mcallister's Avatar
Quoted: 210 Post(s)
Liked: 82
I currently use 4 Danley DTS-10’s in a dedicated room and two VNF DIYSoundgroup MBM-12’s.
Two of the DTS-10 are in the front corners behind a screen wall and the other two are back of room near the corners. I have a very good response with house curve (using two minidsp 2x4 HD’s). However the VNF MBM-12’s interfere with the second row seating and the wife would like to see them go.
I’m considering four Devastators from GSG audio but I would have to put them all behind the screen wall and selling the MBM’s and DTS’s. Is this a good idea, bad idea, indifferent? I wonder how it will effect frequency response since all subs will be up front?
Any thoughts welcome.
mcallister is offline
post #2 of 6 Old 08-14-2019, 06:30 AM
lawdogx's Avatar
Quoted: 134 Post(s)
Liked: 161
Have you REWed the available sub locations in your room? What response does REW say the front locations give you?
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's (and always building, currently working on VBSS's).
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d.
lawdogx is online now
post #3 of 6 Old 08-14-2019, 07:50 AM
notfastenough's Avatar
Quoted: 185 Post(s)
Liked: 215
If I had 4 DTS-10's in a single room, I'm not sure I'd ever change that setup for anything other than an engineered SBA or DBA. If you're room response is good and output levels are good, does that mean the MBM situation is the only concern?
Do you have room behind the screen wall for a larger far-field MBM solution?
If dead set on the GSG option, are you planning on keeping the two rear DTS-10's and trying to integrate? Also, where do you stand on ULF (below 18hz)?
trilkb likes this.
notfastenough is offline
post #4 of 6 Old 08-14-2019, 10:42 AM
noah katz's Avatar
Quoted: 1925 Post(s)
Liked: 686
Your current sub locations inherently give strong output and low spatial variation in response, and you've got 4 DTS10's!
I'd leave them and solve your issue another way.
notfastenough likes this.
Noah
noah katz is offline
post #5 of 6 Old 08-15-2019, 02:07 AM - Thread Starter
mcallister's Avatar
Quoted: 210 Post(s)
Liked: 82
Thanks guys. I’m very happy with everything now honestly and love the DTS-10’s. I’ve had them for 10 heads now probably and was mainly wondering if the Devastators would be an upgrade.
I do have room behind my screen wall and have been considering just adding 2 or 4 of the MBM-21’s from GSG. (I’m not handy enough to build from scratch). When the Devastators came out I thought just 4 of those may be best.
Think I’ll go that route adding the 21’s up front and moving out the mbm-12’s VNF.
post #6 of 6 Old 08-15-2019, 05:15 AM
trilkb's Avatar
Quoted: 655 Post(s)
Liked: 333
If those DTS 10's are the super spud things im thinking of with dual 10" drivers in each and something crazy stupid high like 99db+/ef...I dunno what you could gain lol. 10hz on the low end. Those things are a dream.
Maybe add a nearfield setup? of 4 12's?
mcallister likes this.
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is online now
