Volt10v2 angles flat pack front face angle, mounting height, and offset from display? - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #1 of 41 Old 08-15-2019, 04:02 PM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
Anyone know what the front face angle is? I want to use a set of these for front height and need to figure out how high to mount. I have a 10 foot high ceiling with a 14 foot listening position. Here is a pic from the listening position. Also, where should I mount these in relation to the display?
My Movie Library - and still growing!
Family Room: Sony XBR-85x900F + Denon x6500h + Oppo 203, Speakers: LCR: DIYSG Elusive 1099's, S & RH: Polk TC60i, FH: Volt10v2's, Sub: 2x LTD02 Designed UM18-22 Subs w/Nx6000d
Considering: DIYSG Volt8v2 for Surround
chiptouz is offline
post #2 of 41 Old 08-15-2019, 04:05 PM
johnson636's Avatar
Quoted: 1369 Post(s)
Liked: 849
I can't answer your question, but I'm liking that table/cabinet
d-rail34, kagtha, kevings and 1 others like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #3 of 41 Old 08-15-2019, 04:39 PM
eriksells916's Avatar
Quoted: 689 Post(s)
Liked: 253
Wow that's a wall of sound. Not sure 14ft is back enough lol!
Those who passed geometry class here ya go! 14w x 14h x 10 1/4dt x 5db
eriksells916 is offline
post #4 of 41 Old 08-15-2019, 04:47 PM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
Lol ... I get that. I just don’t know what angle the flat pack comes with from DIYSG. I can do the math...trust me I’m an engineer lol.
chiptouz is offline
post #5 of 41 Old 08-15-2019, 05:25 PM
Quoted: 689 Post(s)
Liked: 253
@chiptouz ha ha ha got it!
Erich is on here, maybe he will chime in but I believe the flat packs include all of the wood, no binding posts, stuffing, etc.
post #6 of 41 Old 08-15-2019, 06:37 PM
Quoted: 51 Post(s)
Liked: 150
I just measured mine. I got 104 degrees on the bottom and 74 degrees on the top. That's about as precise as I can get with my kids plastic protractor. From one fellow engineer to another...probably close enough.
chiptouz and jevchance like this.
jehlinge is offline
post #7 of 41 Old 08-15-2019, 07:04 PM
Dave in Green's Avatar
Quoted: 3963 Post(s)
Liked: 3132
An engineer can't calculate the angle given the flat pack dimensions of 14" x 14" x 10.25" (top) 5.5" (bottom)?
kagtha likes this.
Dave in Green is offline
post #8 of 41 Old 08-15-2019, 07:52 PM
Quoted: 51 Post(s)
Liked: 150
Lol ... I get that. I just don’️t know what angle the flat pack comes with from DIYSG. I can do the math...trust me I’️m an engineer lol.
An engineer can't calculate the angle given the flat pack dimensions of 14" x 14" x 10.25" (top) 5.5" (bottom)? [IMG class=inlineimg]/forum/images/smilies/eek.gif[/IMG]
This engineer can... But my kids protractor was handy and easier than doing math 😀.
However I did decide to check my measurement with the math. Rounded to the nearest degree that gives 70 for the top angle and 110 degrees for bottom angle. Close to my measured angle.
At any rate use a 20 degree angle for the face of the cabinet in reference to the wall.
jehlinge is offline
post #9 of 41 Old 08-15-2019, 07:57 PM
Liked: 3132
OK, then I will allow products you engineer to be in my home, but I'm still not sure about stuff engineered by @chiptouz .
post #10 of 41 Old 08-15-2019, 08:00 PM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
Didn’t even think about that, but yes I could!
chiptouz is offline
post #11 of 41 Old 08-15-2019, 08:02 PM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
Then I hope you never leave your house...lol.. I design roads, actually I don’t design anymore I manage a team of engineers that do the design. Either way. Good call..feeling kinda a duh moment. Lol
Dave in Green likes this.
chiptouz is offline
post #12 of 41 Old 08-15-2019, 08:05 PM
Quoted: 51 Post(s)
Liked: 150
OK, then I will allow products you engineer to be in my home, but I'm still not sure about stuff engineered by @chiptouz . [IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
Fear not as my products won't end up in your home... Unless of course you happen to have a commercial jetliner parked in it!
jehlinge is offline
post #13 of 41 Old 08-15-2019, 08:06 PM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
@jehlinge what are you using your volt10’s for? Do you like the sound? Would they work well for front heights?
chiptouz is offline
post #14 of 41 Old 08-15-2019, 08:15 PM
Quoted: 51 Post(s)
Liked: 150
@jehlinge what are you using your volt10’️s for? Do you like the sound? Would they work well for front heights?
I am using them for side and surround duty. They are paired with 1299s for the main and center as well as 4 18 inch ported subs.
They seem to keep with the mains although I do have the gain turned up a bit on them. I am happy with them and will probably use them as my Atmos heights when the day comes for that equipment.
jehlinge is offline
post #15 of 41 Old 08-15-2019, 08:27 PM
Quoted: 14 Post(s)
Liked: 7
Chiptouz - It looks like 70/20 is close enough. Doing a big cheat and using internet triangle calculators it comes to 71.259/18.741.
Doing a rough estimate (assuming 4 ft head height at LP) and subtracting 6 inches for mid-point of Volt for 13.5 feet away, I come up with 8.6 feet to place mid-point of 10 inch Volt on the wall which puts it pretty high up to the 10 foot ceiling. Again used internet triangle calculators and some Geometry that the Mr. Stevens taught us in high school. Of course YMMV. I'm not always right - just ask my wife!
chiptouz likes this.
bac2040 is offline
post #16 of 41 Old 08-17-2019, 09:58 AM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
redesigned volt10v2 with a 26 degree front face.
since Dave in Green called me out I decided to do some math....
Looks like the best I can do with regards to my listening position is to get a 26 degree angle to the front heights if I have the top 2 inches from the ceiling. I designed the front face to be 26 degrees (yes more math lol) and this is what I settled on. I have sent this off to a cnc place to get an estimate of the costs. If I had a table saw I would consider doing this myself. Adding in a few peeps to get their opinion too. @blister64 @Archaea , @BCRSS
Name:	volt10v2 w 26 degree front face.JPG
chiptouz is offline
post #17 of 41 Old 08-17-2019, 10:22 AM
BCRSS's Avatar
Quoted: 544 Post(s)
Liked: 527
Looks like the best I can do with regards to my listening position is to get a 26 degree angle to the front heights if I have the top 2 inches from the ceiling. I designed the front face to be 26 degrees (yes more math lol) and this is what I settled on. I have sent this off to a cnc place to get an estimate of the costs. If I had a table saw I would consider doing this myself. Adding in a few peeps to get their opinion too. @blister64 @Archaea, @BCRSS
I think they look good. Straight edge and power saw will get you the same results. Here are my volt 6's for Atmos. Had to make the baffle also and used a router with power saw for cuts.
ID:	2603830   Click image for larger version
ID:	2603832   Click image for larger version
chadsmith013 likes this.
BCRSS is offline
post #18 of 41 Old 08-17-2019, 11:51 AM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
@BCRSS looks great! How did you attach to the ceiling?
For the front heights I am going to use a French cleat system with some small rubber bumpers on the bottom for the wall.
Wish I had a table saw. I would easily do it myself. But who knows? Maybe I will or I’ll drive to @blister64 house. He has all the awesome tools!
chiptouz is offline
post #19 of 41 Old 08-17-2019, 12:26 PM
Quoted: 51 Post(s)
Liked: 150
That's how I hung mine. Hangman cleats that were french cleats style from the home improvement store and some bumpers on the bottom. Hangs pretty close to the wall.
jehlinge is offline
post #20 of 41 Old 08-17-2019, 03:53 PM
BCRSS's Avatar
Quoted: 544 Post(s)
Liked: 527
When I mounted on walls I used z plates,. I found these were pretty nice and installed fast.
For my ceiling mounts of the Volt6 I drilled hole through my top and used 1/4x2 1/2 inch lag screw. Screwed directly into ceiling joist. Top of my box I mounted 1/4 inch felt furniture pad Used a rubber washer inside to seal hole I drilled and called it a day.
BCRSS is offline
post #21 of 41 Old 08-17-2019, 04:01 PM
asarose247's Avatar
Quoted: 1291 Post(s)
Liked: 1131
late to the party
but all the heavy geometry has been done
so you have some options wrt getting a good placement / aiming
hangman cleats, great stuff
by using a full motion mount, a #3411 from monoprice, holds about 55 pounds and has an extended reach
that 88 Special weighs 52- no sag issues
i've been able to get FH's out from the wall in the same vertical plane as the LCR,
postioned over the LR for the same stage width
and still adjust angles slightly more wrt MLP
for some bookshelves I add an angled block to the back of the cab and then the hangman.
when I have an angle range to work with . .
I may get better (?) results
HTH
ID:	2604000   Click image for larger version
ID:	2604002   Click image for larger version
ID:	2604004   Click image for larger version
Name:	88 on 3411 swing out.jpg
ID:	2604006   Click image for larger version
Name:	2 monoprice #3411 mounts.jpg
BCRSS likes this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #22 of 41 Old 08-18-2019, 10:00 AM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
@Erich H can you confirm that the inner and outer diameters for the volt 10v2's is still 9-1/8" and 10-1/8" as shown on the HiFi Circuit forum? For some reason I am not getting an email to confirm my account.
chiptouz is offline
post #23 of 41 Old 08-18-2019, 10:07 AM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
Cnc'ing for the cabinets is going to be $200-$250. Seems like money well spent for me. Just need to confirm the info above and I will get the ball rolling. Looks like about 1 week lag before milling.
chiptouz is offline
post #24 of 41 Old 08-18-2019, 07:41 PM
mhutchins's Avatar
Quoted: 290 Post(s)
Liked: 262
You engineers are overthinking this just a bit. The Volt10v2 is very linear the first 10-20 degrees off axis. Just mount it square either horizontal or vertical, whichever minimizes the off axis angle and call it good. Use the money saved on CNC boxes for other / better components that will make a difference in the theater. How about some black velvet for the walls and ceiling near the screen?
Mike
mhutchins is offline
post #25 of 41 Old 08-19-2019, 10:30 AM
Quoted: 51 Post(s)
Liked: 150
Mike
^^This^^
I was just answering the original posters question. My engineering method for determine the mounting location of my angled volt 10's was as follows:
A) Determine a few suitable locations for mounting
B) had my wife hold them against the wall while I listened to them.
In my case the mounting locations I tried were all well within the previously stated 10 -20 degrees of the speaker at the main listening position. My untrained ears didn't notice a whole lot of difference.
I agree with @mhutchins ... Save the money on CNC and just buy the flat packs.
jehlinge is offline
post #26 of 41 Old 08-19-2019, 02:02 PM
Luke Kamp's Avatar
Quoted: 189 Post(s)
Liked: 268
I agree with the two above to just go with the flat packs and save your $. They are coaxials and good off axis and mounted up top of front 10ft wall sitting 14 ft back with the angled flat pack will have you just a few degrees off axis.
Luke Kamp is offline
post #27 of 41 Old 08-19-2019, 06:43 PM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
Thanks all! Well then F it. I’ll just go with the flat packs when the volt10v2’s get back in stock.
@Luke Kamp you need to stop by and hear these. @Archaea was over on Sat and liked the setup.
chiptouz is offline
post #28 of 41 Old 08-20-2019, 06:16 AM - Thread Starter
chiptouz's Avatar
Quoted: 281 Post(s)
Liked: 348
Mike
@mhutchins the off axis angle is approximately 7.2 degrees so it looks like I’m good to go. Looks like the angled face flat pack is the right decision. Thanks!
Chip
chiptouz is offline
post #29 of 41 Old 08-20-2019, 03:30 PM
Quoted: 3121 Post(s)
Liked: 13352
I wanted to mount my Volt-6s at 45 up and 45 over, so I went through the trouble of designing and building mine to natively face both angles perfectly, but I agree in this case 7 degrees isn't worth the trouble.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #30 of 41 Old 08-20-2019, 09:07 PM
Luke Kamp's Avatar
Quoted: 189 Post(s)
Liked: 268
I use french cleats and did not use rubber bumpers on bottom of my volt 8lx side surround speakers with no issue. This puts the top out ~3/8 inch out, further decreasing your off axis angle. Might try without bumpers first and decide if needed.
As far as where to mount them. Dolby guidelines is 20-30 degrees for front heights on the 7.1.6 on page 41. (first speaker placement utilizing front heights)
https://www.dolby.com/us/en/technolo...guidelines.pdf
Looks like top of your ceiling with seating distance would put you right in the middle of that range. Both Atmos and Dolby 9.1 speaker setup guide say best placement is directly above the front left and right speakers.
https://www.dolby.com/us/en/guide/su...9-1-setup.html
I would be happy to stop by sometime and check out the room.
