Specs for old H18? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By EndersShadow
  • 1 Post By Augerhandle
  • 1 Post By lemonslush
post #1 of 15 Old 08-20-2019, 04:35 AM - Thread Starter
lemonslush's Avatar
Quoted: 871 Post(s)
Liked: 444
Talking Wiring question 2 + 2 = 4? right
Currently have two subs DVC4 = 2 ohm load each. They get hooked up to 1 channel on a inuke 3k each. Issue is I want to consolidate amps on my rack due to space. Taking the subs out of the box is a huge PIA so my question. Can I take the subs as they sit now DVC4 = 2 ohms to show a total load of 4ohms with both subs hooked up to a single channel. The inuke 6k wants a 4ohm load to get full power out of it.
I was thinking I take the (-) and (+) from sub box together than connect the remaining (-) (+) lines one from each box and hook that up to a single channel on the amp. Image attached for reference
and also does anyone have the specs handy from the SI Ht18's DVC4 I want to compare it to a new sub I was debating on using ?
ID:	2605044   Click image for larger version
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #2 of 15 Old 08-20-2019, 12:49 PM
EndersShadow's Avatar
Quoted: 1229 Post(s)
Liked: 1510
I think I’ve got em in WinISD. Will check when I get home.
lemonslush likes this.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #3 of 15 Old 08-20-2019, 02:18 PM
Augerhandle's Avatar
Quoted: 1215 Post(s)
Liked: 1201
Originally Posted by lemonslush View Post
...also does anyone have the specs handy from the SI Ht18's DVC4 I want to compare it to a new sub I was debating on using ?
This?
SI HT-18 specs.pdf
SI18-Without-Gasket-v2.pdf
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #4 of 15 Old 08-20-2019, 02:43 PM
wlhungdude's Avatar
Quoted: 211 Post(s)
Liked: 269
not those....
the D4 version had different t/s parameters than the D2. I remember a thread about it , and did get the specs emailed to me from nick. I did a quick search through my email but couldn't find it. I seem to remember the gist of it all was the D4 liked a bigger box than the D2.
Sorry I couldn't be of more help. I'll try to look some more.
Joseph
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #5 of 15 Old 08-20-2019, 04:06 PM
Liked: 1201
You're right.
[ATTACH][/ATTACH]
wlhungdude likes this.
post #6 of 15 Old 08-20-2019, 05:08 PM
wlhungdude's Avatar
Quoted: 211 Post(s)
Liked: 269
awesome... thanks Auger !
Joseph
post #7 of 15 Old 08-21-2019, 05:20 AM - Thread Starter
lemonslush's Avatar
Quoted: 871 Post(s)
Liked: 444
Originally Posted by Augerhandle View Post
You're right.
[ATTACH][/ATTACH]
Fantastic ! Thank you kind sir
post #8 of 15 Old 08-21-2019, 06:20 AM - Thread Starter
lemonslush's Avatar
Quoted: 871 Post(s)
Liked: 444
Man for the money those old HT18 subs were the best bang for the buck...I think to make it worth upgrading I may need to move over to a 21 Pro style sub. Im thinking do a nearfield ported 21" in 16 cube box. Ill need to play with it more.
Purenv likes this.
post #9 of 15 Old 08-21-2019, 06:29 AM
Purenv's Avatar
Quoted: 192 Post(s)
Liked: 127
Or a 21” in a BMD(Beast Mode Devastator).
Purenv is offline
post #10 of 15 Old 08-21-2019, 06:40 AM - Thread Starter
lemonslush's Avatar
Quoted: 871 Post(s)
Liked: 444
Interesting that almost seems like a bandpass design. the 60' dimension may be a tad large for the location I had in mind. It would fit in the kids tv room though
post #11 of 15 Old 08-21-2019, 08:50 AM
Purenv's Avatar
Quoted: 192 Post(s)
Liked: 127
It basically is a bandpass design with one major exception that instead of 2 standard ports, the larger port is actually a quarter wave guide. Making it a hybrid horn.
Purenv is offline
post #12 of 15 Old 08-24-2019, 04:41 AM - Thread Starter
lemonslush's Avatar
Quoted: 871 Post(s)
Liked: 444
anyone tried a sealed PA style 21" build lately? I was thinking of smaller boxes like small as I can go and down firing so little hands can damage stuff.
and for the records its me who wants small boxes my wife said "put those 4' dual subs down here".
post #13 of 15 Old 08-24-2019, 05:07 AM
Purenv's Avatar
Quoted: 192 Post(s)
Liked: 127
The small sealed PA style enclosure is great for rock concert style sound 40Hz and up. But it will start rolling off around 70-80Hz. Try modeling it in WinISD. IMO, better if you stick with ported.
Purenv is offline
post #14 of 15 Old 08-24-2019, 05:14 AM - Thread Starter
lemonslush's Avatar
Quoted: 871 Post(s)
Liked: 444
ahh yea... Maybe a sealed dual opposed ht18 build. I totally forgot i no longer own Pc's so no WinISD for me. Tried to get my old HP running but its long dead. Looking for a different online software thats halfway decent.
post #15 of 15 Old 08-28-2019, 10:55 AM - Thread Starter
lemonslush's Avatar
Quoted: 871 Post(s)
Liked: 444
Man finally got WinISD and those old HT18s look sooo much better on paper than all these PA subwoofers in a 16 cubed box. Even the 21 has less low end. granted it has way more about 15 db or so at like 45 hz and up.but at 15-20 its a 5 db gain over the 21. Maybe I could mix and match. do a few of one and a few of another? Get some more mid range cause I will say the ht18s dont really come awake until its a low bass note.
