2 More VBSS on the Way - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #31 of 49 Old 10-26-2019, 07:03 PM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #32 of 49 Old 10-27-2019, 04:49 PM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
I have one up and running, corner loaded. I can’t believe I’m saying this, but it might be too much bass. Going to see how they sound behind the screen because damn.
tjambro likes this.
DIY 110" AT Screen
post #33 of 49 Old 10-28-2019, 05:41 AM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Both drivers up and running. These things are totally destroying my end tables. I only had a few minutes to play but curtain shaker literally sends waves through the floor upstairs. Dedicated detached theater room is definitely necessary.
Build is officially complete, now the tweaking begins.
DIY 110" AT Screen
post #34 of 49 Old 10-28-2019, 06:14 AM
elusiveis's Avatar
Quoted: 41 Post(s)
Build looks really good! Any particular reason why these 2 are destroying the end tables? Location?
Slowly building/upgrading the HT
Projector, Marantz NR1607, Emotiva T1/C2, B652-AIR, SUB-1000
*coming soon* NX3000D, DIY: (2) 20hz VBSS
elusiveis is offline
post #35 of 49 Old 10-28-2019, 06:59 AM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Great question. There are two factors I can think of, both likely factor in. First, the new boxes are corner loaded. Second, the end tables are running off a bridged 1000DSP and the new subs are running off separate channels on a 3000DSP. On paper the power is similar...
I’m going to try to move the new subs behind the screen so it will be interesting to see how they perform back there.
DIY 110" AT Screen
post #36 of 49 Old 10-28-2019, 01:15 PM
Quoted: 174 Post(s)
Liked: 177
Originally Posted by jevchance View Post
Good news, bad news, and good news.
Good news: took the router apart, cleaned the contactor, and it’s working again!
Bad news: the round over kinda chewed up the outer ply and it looks like ****.
Good news: I don’t care! I finished the first box anyway, and should have the second completed tomorrow. The Waterlox is pretty awesome stuff.
Yeah, sad but plywood doesn't play well with roundovers. Had the same experience this summer. Other than that your build is looking great!
Last edited by darknite9099; 10-28-2019 at 01:17 PM. Reason: auto-incorrect changed roundovers to rounders.
darknite9099 is offline
post #37 of 49 Old 10-28-2019, 01:26 PM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Thank you! The second box went perfectly. I set the router on the slowest speed and advanced very slowly, that did the trick.
darknite9099 likes this.
DIY 110" AT Screen
post #38 of 49 Old 10-29-2019, 09:54 AM
elusiveis's Avatar
Quoted: 41 Post(s)
BTW, did you end up using the 1/4"-20 Speaker Mounting Kit? Any tips on how to install these properly? Did you also use gasket to seal the sub/terminal?
post #39 of 49 Old 10-29-2019, 10:23 AM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Yup I used these: https://www.parts-express.com/parts-...g-kit--260-778
To install:
1) put speaker in place and mark holes.
2) pull speaker and drill 1/4 hole in center of each mark.
3) take a 5/16 drill bit and wrap tape around the bit at the depth of the t-nut.
4) drill out the back of each hole to the depth of the tape.
5) insert t-nut into back of hole and tap into place with a hammer.
6) when installing the speaker, tightening the bolt will draw the t-nut into the hole.
I'm putting together a full build video but here's the segment where I talk about the t-nuts.
The speaker comes with a gasket pre-installed that I find to be adequate.
elusiveis likes this.
DIY 110" AT Screen
post #40 of 49 Old 10-29-2019, 01:03 PM
elusiveis's Avatar
Quoted: 41 Post(s)
Yup I used these: [url]https://www.parts-
Thanks for documenting everything! Looking forward to the whole video.
jevchance likes this.
post #41 of 49 Old 10-30-2019, 06:07 PM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Oh boy.
Wife came downstairs and said are you cutting more holes in the wall? Yup.
Haven’t had a chance to run it through the paces yet but at low volumes it sounds pretty good. Unfortunately the kids were in bed when I finished up. More testing to come tomorrow.
DIY 110" AT Screen
post #42 of 49 Old 10-30-2019, 06:08 PM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Like it never happened.
DIY 110" AT Screen
post #43 of 49 Old 10-30-2019, 06:18 PM
dasa2131's Avatar
Quoted: 107 Post(s)
Liked: 115
Beautiful work! I'm glad you like the VBSS's. It looks like you've got room for more of them when the need arises.
Dave
dasa2131 is offline
post #44 of 49 Old 10-31-2019, 05:26 AM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Dave
The thought never crossed my mind.
DIY 110" AT Screen
post #45 of 49 Old 05-22-2020, 10:24 PM
SRTpusher's Avatar
Quoted: 32 Post(s)
Liked: 25
So happy to find a slotted VBSS cut list!
You rock! Thanks!
SRTpusher is online now
post #46 of 49 Old 05-23-2020, 07:24 AM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
Glad it was helpful!
DIY 110" AT Screen
post #47 of 49 Old 05-23-2020, 10:30 AM
BassThatHz's Avatar
Quoted: 4015 Post(s)
Liked: 4532
Stop swearing.
You are slowly starting to realize the amount of bass some of us crackheads like to deploy.
120db... at idle RPM / ghost power.
125db at signal-detected!
jujuman200 likes this.
BassThatHz is online now
post #48 of 49 Old 05-24-2020, 07:37 AM - Thread Starter
Quoted: 245 Post(s)
Liked: 235
I’m definitely slipping down the rabbit hole. I’m highly budget-limited due to my other expensive hobby, but I just picked up a used Fusion-12 LCR. The mains aren’t much of an improvement over my previous mains (Eosone RSF-1000), but the center channel is a huge improvement. Next on my list is a receiver upgrade, hoping to snag a deal on a used Marantz SR-6010 or Denon AVR-3600H/4100/4200/4300. After that, Volt 6 front heights!
4fit? likes this.
DIY 110" AT Screen
post #49 of 49 Old 05-25-2020, 08:52 AM
motorxtreme@sbcglobal.net's Avatar
Quoted: 29 Post(s)
Oh and I picked up a used router off Facebook. I wasn’️t confident my little trim Makita could handle 3/4â€Â round overs.
Exact same router I have. Pretty good consumer level one with variable speed. Don't rely on the lock pin tho. They are mostly for looks. They snap right off with medium torque.
[email protected] is offline
