What to use to solder crossovers - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Trimlock
  • 1 Post By jevchance
post #1 of 14 Old 10-01-2019, 08:05 AM - Thread Starter
Purenv's Avatar
Quoted: 235 Post(s)
Liked: 148
Hey guys. I am looking for advice in regards to a soldering iron station and solder to use for the crossovers for the (3)1099s and (2)Volt8s I have ordered from DIYSG. I am not wanting to spend a lot of money on a iron/station as I am only going to use it most likely just for the crossovers and then it will get tossed into a toolbox for the foreseeable future.
Also what heat settings do you guys use for soldering using the PCB boards from DIYSG.
Any advice is greatly appreciated.
Thank you all in advance.
Purenv is offline
post #2 of 14 Old 10-01-2019, 08:39 AM
Quoted: 247 Post(s)
Liked: 238
FWIW I don't use a soldering station, just an iron that came with a little stand. Fits in the toolbox a lot better.
Nothing special is needed, any cheap soldering iron off Amazon will do. The PCBs and pads are large and very easy to solder.
Denon X1300W/DIYSG Fusion 12 LCR/Volt-10 Rears/Micca M-8C Heights
2 @ VBSS End Tables - 2 More VBSS complete!
Epson 2030/DIY 110" AT Screen
Eosone RSF1000 for Enjoying Music
jevchance is offline
post #3 of 14 Old 10-01-2019, 08:50 AM - Thread Starter
Purenv's Avatar
Quoted: 235 Post(s)
Liked: 148
I probably didn’t use the right terminology. Yes I am looking at what you are describing. Just a simple iron and stand. What solder do you use? 60/40 or 63/37? Lead or no lead? Silver added or no?
Purenv is offline
post #4 of 14 Old 10-01-2019, 11:47 AM
Quoted: 625 Post(s)
Liked: 559
This is a nice one for not too much $$
https://www.parts-express.com/weller...ation--372-120
Either solder would work that you listed.
https://www.parts-express.com/electr...spool--370-032
cocrh is online now
post #5 of 14 Old 10-01-2019, 12:01 PM
Quoted: 247 Post(s)
Liked: 238
I think I'm using 60/40 leaded flux core. Works good.
post #6 of 14 Old 10-01-2019, 12:10 PM
smcmillan2's Avatar
Quoted: 1148 Post(s)
Liked: 968
I've used https://www.truevalue.com/shop/tools...ctrical-solder on all the crossovers I've assembled, no issues.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #7 of 14 Old 10-01-2019, 01:38 PM
Liked: 2
I've used not the same thing, but also led-free and with some silver content to do my own interconnects. Worked great!
Dave Grohl is offline
post #8 of 14 Old 10-01-2019, 02:40 PM
Quoted: 72 Post(s)
I just used 60/40 flux core on mine and they turned out great.
spshultz is offline
post #9 of 14 Old 10-01-2019, 03:35 PM
Quoted: 570 Post(s)
Liked: 474
A 45 watt iron, 60/40 flux core and some practice.
The best thing to do in my opinion than to fret about the solder and cheap iron is to set up a damp sponge to clean the iron with.
Heide264 likes this.
Trimlock is offline
post #10 of 14 Old 10-02-2019, 03:29 AM - Thread Starter
Purenv's Avatar
Quoted: 235 Post(s)
Liked: 148
Thank you all for your advice. It’s been 22 years since I last soldered anything. So I was unsure if anything has changed.... that Weller iron looks like a solid bet with 60/40 leaded solder. Thanks again guys!
Purenv is offline
post #11 of 14 Old 10-02-2019, 07:24 AM
Quoted: 247 Post(s)
Liked: 238
FWIW this video shows you everything you could ever want to know about assembling DIYSG crossovers. @mtg90 makes it look easy, and it really is as easy as he makes it look.
HTH.
post #12 of 14 Old 10-02-2019, 07:26 AM
Quoted: 247 Post(s)
Liked: 238
On and one more thing to note. You'll notice he has a crossover assembly jig setup. This is a GREAT idea, helped me a lot assembling my boards. But, you don't need to make a jig out of wood. In fact as I recall, I used a couple of stacks of old DVDs. You could use some books, whatever, but making a little channel to set the edges of the board on and elevate it a few inches is very helpful.
post #13 of 14 Old 10-04-2019, 12:51 PM
JohnDean's Avatar
Quoted: 579 Post(s)
Liked: 269
Half the price and works just fine. I've run through a bunch of solder with this one.
https://www.parts-express.com/stahl-...ation--374-100
JohnDean is offline
post #14 of 14 Old 10-04-2019, 08:55 PM
Bigus's Avatar
Quoted: 713 Post(s)
Liked: 625
Two suggestion. The Stahl above for budget, works great, reliable. If you want something really nice but before wandering into industrial type stations, the Hakko fx88d is hard to beat.
Bigus is offline
