The Devastator Index - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 1013Likes
post #361 of 1450 Old 01-31-2020, 11:44 AM - Thread Starter
Red Five's Avatar
Quoted: 1276 Post(s)
Liked: 1196
I think the sim is running lossy inductance in the model and excursion is a little high in the upper 20s. @jujuman200 loves his LFE, we know it works well. I did not finish up the shallow one yet, cut list another round of sanity checks, but it should be close to this. If you want the deep tune, the LFE would most likely be better for that. It is due for a HCR revision....
Name:	BMD Shallow HCR.jpg
Jan3 likes this.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is offline
post #362 of 1450 Old 01-31-2020, 12:04 PM
Quoted: 161 Post(s)
Liked: 79
For placement behind AT screen I´d just turn it upside down and turn 90 degrees so the port looks over the LCR speakers, so no need to be shallow. Or did I miss something?
Would it impact output you think?
Jan3 is offline
post #363 of 1450 Old 01-31-2020, 01:12 PM - Thread Starter
Red Five's Avatar
Liked: 1196
My Minis sound crappy in my space up against the wall. 12 inches of breathing room lets them reach their potential. You can move the mouths in any direction you want. Obstructions in front of the mouth can effect the response. I am not an expert in room design, this is just my experience with my current subs one of these YMMV situations. Bass is very non-directional in nature vs any other frequency range.
Jan3 likes this.
This is the way...
Red Five is offline
post #364 of 1450 Old 01-31-2020, 01:19 PM
jujuman200's Avatar
Quoted: 408 Post(s)
Liked: 423
Originally Posted by Red Five View Post
[snip]... If you want the deep tune, the LFE would most likely be better for that.
@Red Five
Did you get a chance to listen to the music I posted on page 12? I would like your thoughts on how your system handles them.
Juju
Sub List: 1- Red Five Mini V1 Devastator 18" w/PA460, 1- Red Five Devastator LFE 21", 1- Red Five Devastator 21" Finalizer V2 DF , 1- BOSS platform [The Hideaway Theater], 2- 18" "Full Marty" tuned to 17Hz w/RSS460HO
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is online now
post #365 of 1450 Old 01-31-2020, 01:29 PM - Thread Starter
Red Five's Avatar
Liked: 1196
Originally Posted by jujuman200 View Post
@Red Five
Juju
I am suspecting my Nuke DSP is not handling the way I want, I have to do some more testing. The HS12 might be creating artifacts and not pushing my left corner down. I might order the Dayton DSP tomorrow, they cannot answer my question regarding setting filters below 20Hz, but digging around the web, I found algorithm screen shots and noticed a 5 Hz filter. I listened to the second track for a few seconds Bass I Love you is not hitting hard like it use on the bottom note, this is why I am suspecting the amps DSP. Also some bass soundtracks sound strangely distorted.
This is the way...
Red Five is offline
post #366 of 1450 Old 01-31-2020, 01:30 PM - Thread Starter
Red Five's Avatar
Liked: 1196
I updated the OP, a BMD name changed, the Mini 18" assembly guide is on the first page and the HR tutorial was added
jujuman200, Jan3 and a77cj7 like this.
This is the way...
Red Five is offline
post #367 of 1450 Old 01-31-2020, 01:41 PM
jujuman200's Avatar
Quoted: 408 Post(s)
Liked: 423
[SNIP].... Also some bass soundtracks sound strangely distorted.
Well that's no bueno.... always something..... good luck tracking down the issue..
Juju
Red Five likes this.
post #368 of 1450 Old 01-31-2020, 01:45 PM - Thread Starter
Red Five's Avatar
Liked: 1196
Juju
One of the local guys had an issue that sounded like it was something wrong with either cabinet or the HO in the cabinet, it would only happen at 20Hz. Turns out it was an LS filter on the Mini DSP creating an artifact. I think that is what I am hearing or I have to rip the boxes open again..... All I want is a BW 16Hz 4th order HPF.
This is the way...
Red Five is offline
post #369 of 1450 Old 01-31-2020, 03:43 PM
tarponater's Avatar
Quoted: 223 Post(s)
Liked: 776
The BMD Omega will take 7 sheets of plywood, 5 tubes of PL, 400-500 screws (if you're a screwer) a few 2x4s and just under a half gallon of DuraTex. Looks like I'm going to have to drum up some business to fund this experiment.
jujuman200, Nalleh, hd0823 and 2 others like this.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii 11cuft sealed, Behringer NU-12000, Crown XLS-2502, MINIDSP 2X4
tarponater is offline
post #370 of 1450 Old 01-31-2020, 04:33 PM
a77cj7's Avatar
Quoted: 969 Post(s)
Liked: 1040
You must put on duratex a whole bunch lighter than I do. I’d use at least a gallon.
Otherwise sounds like a reasonable build, lol.
Chris
tarponater and Red Five like this.
a77cj7 is online now
post #371 of 1450 Old 01-31-2020, 06:56 PM
smcmillan2's Avatar
Quoted: 1121 Post(s)
Liked: 944
Chris
Yep, that's reasonable in this neck of the woods.
tarponater likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #372 of 1450 Old 01-31-2020, 07:24 PM
tarponater's Avatar
Quoted: 223 Post(s)
Liked: 776
Chris
Lol, painting is kinda my specialty. I was the production painter at an automotive paint shop for 22 years. I painted those four ported HS24 cabinets with just over a gallon of DuraTex. I'm going to take some measurements in my theater tomorrow. If I can find a place to fit two of these cabinets and not mess up the theme of the room, I'll move forward. There's also a chance I can fit one in the living room. Can the cabinet be laid on it's side? If oi, maybe I can hide it behind the couch in the living room as a table.
a77cj7 likes this.
post #373 of 1450 Old 01-31-2020, 07:40 PM - Thread Starter
Red Five's Avatar
Liked: 1196
On the side is not a problem
This is the way...
Red Five is offline
post #374 of 1450 Old 01-31-2020, 09:36 PM
a77cj7's Avatar
Quoted: 969 Post(s)
Liked: 1040
Wow, cost-savings there. I would have to be stingy to do those 4 cabs with a 5gal bucket. I thought the point of duratex was to put it in thick to resist impact and abrasions?
I bet your finish looks much nicer though.
Chris
post #375 of 1450 Old 02-01-2020, 12:10 AM
Nalleh's Avatar
Quoted: 3199 Post(s)
Liked: 4880
Originally Posted by Nalleh View Post
Regarding the JBL’s, i guess using 4 in one box in a 2x2 mounting would not be doable as it would make the lenghts of both the port and horn "incompatible" ?
If so, either a single driver or possible a dual driver(side by side). More like a mini-micro Dev, LOL.
A multi driver Devastator is something you would have to PM me about, I am not too interested in attempting to design something like that at the moment.
My wife saw the JBL and I mentioned I could probably take 4 of these and have them stick with 18". I got the "Why did you not do that to begin?" I did not think of sticking four of them in a horn then and was told this is not happening soon. I am cool with that, I need something to replace the towers so I have space for more subs anyways.
I guess you came around, huh?
I did some more max spl comparison. This was with different chart limits, so it was a nightmare to align, LOL, but you get the picture.
Pretty impressive that the 9 JBL can hang with the 3 UM18, with more up top!! All 9 JBL’s are cheaper than 1 UM18"!!!!
Vs the Mini Dev HCR with San184. Not sure if this was max spl on the San?
And vs Mini Dev with my Si18.
For the future could you "standardize" the chart limits to 95dB-145dB and 1hz-2k hz?
ID:	2678684   Click image for larger version
ID:	2678686   Click image for larger version
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 6x Crowsons - 4xBK-LFE - 2x12"BB - 2x "4DX" fans- 6xNU6K - Minidsp 10x10HD - Oppo UDP203 - XB1X - ATV4K - JVC RS600 Dreamscreen V2 120"- Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #376 of 1450 Old 02-01-2020, 01:06 AM
hd0823's Avatar
Quoted: 945 Post(s)
Liked: 1792
Man 2 of the omegas in your size room would be ridiculous. Please proceed or not your results might push me to end up building them for the basement at the moment I'm leaning towards multiples of the quad 12 devastors because the setup is mainly for music but keep getting pulled back in to the omega. I'll definitely be following that build
Sent from my SM-N975U using Tapatalk
hd0823 is offline
post #377 of 1450 Old 02-01-2020, 02:52 AM
Nalleh's Avatar
Liked: 4880
Back to the 21" Devastators, I punched the port up .75" and took an inch off recalculated displacement and we get this. Tune is just under 16hz, power input is 1000 watts, velocity sits right around 24m/s. NSW6021-6.
Is this a updated Dev V1 then?
If so, vs quad12 Dev, which is actually a bit smaller in size:
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #378 of 1450 Old 02-01-2020, 04:40 AM
tarponater's Avatar
Quoted: 223 Post(s)
Liked: 776
Chris
Duratex was designed for protection of road gear for sure. However, we use it for cosmetic finishing on household cabinets no different than lacquer or oils. I think most people use it because it does such a good job hiding imperfections and not soaking into MDF end grain.
post #379 of 1450 Old 02-01-2020, 05:36 AM - Thread Starter
Red Five's Avatar
Liked: 1196
HR moves the SPL range for amplitude as it sees fit lol. It defaults to 10-20khz, the low tune stuff I usually move it down. Chris has wood, so we will see know if the model is accurate!
This is the way...
Red Five is offline
post #380 of 1450 Old 02-01-2020, 05:39 AM - Thread Starter
Red Five's Avatar
Liked: 1196
That one is an updated 16Hz tuned Devastator running 1000 watts with a HPF on. Max SPL it would show the 2Hz lower tune extension advantage more.
This is the way...
Red Five is offline
post #381 of 1450 Old 02-01-2020, 06:02 AM
Nalleh's Avatar
Liked: 4880
Bummer
Yeah, it will be exciting for sure to see if it models correct
Ok.
But you can block a port on the Quad Dev too?
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #382 of 1450 Old 02-01-2020, 06:33 AM - Thread Starter
Red Five's Avatar
Liked: 1196
Bummer
Ok.
Yes, you can block one on there, tune would probably drop into the 15Hz range. 1200 watts is modeling around 23m/s, so there is some headroom there.
Nalleh likes this.
This is the way...
Red Five is offline
post #383 of 1450 Old 02-01-2020, 06:52 AM
a77cj7's Avatar
Quoted: 969 Post(s)
Liked: 1040
Maybe I ‘m just clumsy, but I like my boxes to be resilient. My HT is inconveniently the main route into my house too.
Honestly, I haven’t been impressed by the imperfection-hiding. It shows seams super easily, even with my heavy application. I’ve moved to priming/sanding till imperfections are gone before spraying duratex.
Chris
post #384 of 1450 Old 02-01-2020, 06:56 AM
a77cj7's Avatar
Quoted: 969 Post(s)
Liked: 1040
Phrasing!
As soon as I finish my second coffee, I’ll go start chopping panels for the quad and a BMD Alpha.
I don’t have drivers for the quad though. My BOSS drivers are soldered on, and I don’t want to dismantle it/break them.
Chris
Nalleh and Red Five like this.
post #385 of 1450 Old 02-01-2020, 07:25 AM
Nalleh's Avatar
Liked: 4880
^^ HAH, i would give you my speakers easily if i was nearby, but sending them from Norway would not be logical, LOL.
PLEASE ANYBODY??
@LastButNotLeast ?
@Chris Popovich ?
EDIT: never mind, it is sorted, LOL!!
a77cj7 likes this.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #386 of 1450 Old 02-03-2020, 08:03 AM - Thread Starter
Red Five's Avatar
Liked: 1196
This is the next thing in the development pipeline. Sub is a DS chugging along at a 1000 watts, tune 17Hz with a velocity right around 24m/s with a 17Hz 2nd order HPF active.
Name:	Devastator 48x30x24 DS 1000 watts 17H2ndOHPF SPL.jpg
jujuman200, Nalleh, Jan3 and 1 others like this.
This is the way...
Red Five is offline
post #387 of 1450 Old 02-03-2020, 11:32 AM
jujuman200's Avatar
Quoted: 408 Post(s)
Liked: 423
For anyone keeping score.... ONLY 3 of these DEVS beat the LFE on the left side of the charts.....The ALPHA, BMD MAX & OMEGA... The 16Hz version [add 13" to the port board] is a wicked thing to behold.....
Will I be the ONLY one with an LFE? That form factor works best for me in my space.... plus I really don't want a sub that looks like a refrigerator in my LR.... lol
Come on guys.... show that LFE some love..... LOL
Juju
post #388 of 1450 Old 02-04-2020, 07:54 AM - Thread Starter
Red Five's Avatar
Liked: 1196
Devastator 21" Version 4 HCR 24" Deep
This Devastator versions is designed for areas where depth is a concern. Volume is 20cuft external, only slightly smaller than the V1. Tune is lower on this box, 17Hz is the calculated tune for this Devastator. Charts are simulated with the 21DS115 running 1000 watts and 2000 watts, check the attachments, HPF is a 17Hz 2nd order BW. There is also a slight bracing change just to make assembly easier. Assembly is very close to the Mini Devastator.
V1 vs the V4 1w1m
Name:	Dev V4 front shot.jpg
ID:	2680180   Click image for larger version
Name:	Devastator v4 input.jpg
ID:	2680182   Click image for larger version
Name:	Dev v4 side open.jpg
ID:	2680184   Click image for larger version
Name:	Dev v4 1000 watts 17Hz2ndOHPF SPL.jpg
ID:	2680186   Click image for larger version
Name:	Dev v4 1000 watts 17Hz2ndOHPF Excursion.jpg
Name:	Dev v4 1000 watts 17Hz2ndOHPF velocity.jpg
ID:	2680190   Click image for larger version
Name:	Dev v4 2000 watts 17Hz2ndOHPF SPL.jpg
ID:	2680192   Click image for larger version
Name:	Dev v4 2000 watts 17Hz2ndOHPF Velocity.jpg
ID:	2680194   Click image for larger version
Name:	Dev v4 2000 watts 17Hz2ndOHPF Excursion.jpg
ID:	2680196   Click image for larger version
Name:	Bracing revision .jpg
Name:	bracing revision1.jpg
ID:	2680200   Click image for larger version
Name:	Dev v4 cutlist.jpg
Jan3 likes this.
This is the way...
Red Five is offline
post #389 of 1450 Old 02-04-2020, 08:34 AM
Quoted: 161 Post(s)
Liked: 79
[QUOTE=Red Five;59197914]This Devastator versions is designed for areas where depth is a concern. Volume is 20cuft external, only slightly smaller than the V1. Tune is lower on this box, 17Hz is the calculated tune for this Devastator. Charts are simulated with the 21DS115 running 1000 watts and 2000 watts, check the attachments, HPF is a 17Hz 2nd order BW. There is also a slight bracing change just to make assembly easier. Assembly is very close to the Mini Devastator.
I love it. Might build 2 of these for behind my screen.
I may have missed it in this thread, but will there be a cut list in the future and/or more details? I still have time while my house is being constructed, but at one time I won´t know how to start without a cut list or file I can work on.
Jan3 is offline
post #390 of 1450 Old 02-04-2020, 08:35 AM
johnson636's Avatar
Quoted: 1725 Post(s)
Liked: 1227
Cutlist is at the very bottom
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
devastator
