The Devastator Index - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 473Likes
post #421 of 808 Old 02-05-2020, 07:12 PM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
Originally Posted by Red Five View Post
I would knock the left corner down so it is 6db less than 20Hz room gain...
I guess you did say a full 6db down from 20...
8.4hz tune
37.5m/s
Chris
Nalleh likes this.
a77cj7 is offline
post #422 of 808 Old 02-05-2020, 07:19 PM - Thread Starter
Red Five's Avatar
Quoted: 1135 Post(s)
Liked: 1008
8.4hz tune
37.5m/s
Chris
I would keep the tune around 10Hz drop the volume and area first then start leaning on the port length untill acceptable curve and velocity are achieved. We only need to get up around where the Micro MBM can take over on the pass band
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is offline
post #423 of 808 Old 02-05-2020, 07:20 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
Challenge accepted.
I present Omega LLT
HS24. 2500w input power. 30w x 85.5h x 50d.
Tune 11.8hz
11hz 3rd order HPF.
40mm excursion.
34 m/s port velocity.
Hows THAT left corner Juju?
Chris
Love It..... just WAY too big for my place...... I have attached the 19Hz LFE chart..... not too far behind.... I'm rocking the 16Hz version.... Oh... it stomps the LFE @10Hz.... after that it's game on.....
That's slightly larger than two LFE.....
Juju
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20Hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #424 of 808 Old 02-05-2020, 07:21 PM
tarponater's Avatar
Quoted: 213 Post(s)
Liked: 764
That might be too large for even @tarponater lol
Yes, Tarponater will have to pass on the LLT. However, I just secured a couple builds that should bring the BMD Omega to life soon.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii 11cuft sealed, Behringer NU-12000, Crown XLS-2502, MINIDSP 2X4
tarponater is offline
post #425 of 808 Old 02-05-2020, 07:22 PM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
Excellent!!! I’ve been hoping you’d build that one.
Chris
chadsmith013 likes this.
a77cj7 is offline
post #426 of 808 Old 02-05-2020, 07:34 PM
tarponater's Avatar
Quoted: 213 Post(s)
Liked: 764
Chris
A friend is having a set of Helix MTs sent to my house for assembly and piano black finish. Once I knock that out I'll start on the Omega. @chadsmith013 has some work for me too. Living down the road from him is like taking candy from a baby.
post #427 of 808 Old 02-05-2020, 07:35 PM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
OK, one more for the night.
HS24
30w x 83h x 40d
2500w input power
10hz 3rd order HPF
40mm excursion
40m/s port velocity
Chris
a77cj7 is offline
post #428 of 808 Old 02-05-2020, 07:36 PM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
Hope you’ve got a good respirator.
Its good to be busy.
Chris
a77cj7 is offline
post #429 of 808 Old 02-05-2020, 07:39 PM - Thread Starter
Red Five's Avatar
Liked: 1008
HS24
30w x 83h x 40d
2500w input power
10hz 3rd order HPF
40mm excursion
40m/s port velocity
Chris
We could get it into something manageable. I would do some digging on average room gain from 20Hz to 10Hz, it might be closer to a 9db boost, maybe a little more. If that be the case shrinking things is more of an option...
This is the way...
Red Five is offline
post #430 of 808 Old 02-05-2020, 07:40 PM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
Gonna have port velocity go off the rails if it shrinks much more. Better off playing with crossovers to knock down the response and get port velocity back in check.
Chris
a77cj7 is offline
post #431 of 808 Old 02-05-2020, 07:41 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
HS24
30w x 83h x 40d
2500w input power
10hz 3rd order HPF
40mm excursion
40m/s port velocity
Chris
TWO of these in your place and you are all set... one front and one rear for the complete EXPERIENCE...
Juju
post #432 of 808 Old 02-05-2020, 07:43 PM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
Juju
If only I had a spot for even one of them, lol. Or money for the HS24’s.
I guess I’ll just have to destroy my house more slowly with a v3 in the front and an Alpha in the rear.
Chris
jujuman200 likes this.
a77cj7 is offline
post #433 of 808 Old 02-05-2020, 07:47 PM - Thread Starter
Red Five's Avatar
Liked: 1008
@jujuman200 I still want to figure out what will be called the sidewinder with dual 21"
This is the way...
Red Five is offline
post #434 of 808 Old 02-05-2020, 08:14 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
Since we are going GREEK with the names..... maybe Devastator Pi based on the two QW slots...
Juju
post #435 of 808 Old 02-05-2020, 08:17 PM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
Juju
Too bad the 21 is not called the SAN314.16
Chris
a77cj7 is offline
post #436 of 808 Old 02-05-2020, 08:19 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
Chris
Well played sir......
Juju
post #437 of 808 Old 02-05-2020, 08:25 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
We might have to take it to 25.5 x 60 wide x 48 deep or larger to get it to tune in the 16-17 range...
Juju
post #438 of 808 Old 02-06-2020, 06:07 AM
Kothoga's Avatar
Quoted: 169 Post(s)
Liked: 218
Question
For anyone keeping score.... ONLY 3 of these DEVS beat the LFE on the left side of the charts.....The ALPHA, BMD MAX & OMEGA... The 16Hz version [add 13" to the port board] is a wicked thing to behold.....
Will I be the ONLY one with an LFE? That form factor works best for me in my space.... plus I really don't want a sub that looks like a refrigerator in my LR.... lol
Come on guys.... show that LFE some love..... LOL
Juju
I'm way late to the game as I've been, and still am, fighting my HOA over adding a workshop. Did you follow these cuts or did I read somewhere that you changed the port length?: https://www.avsforum.com/forum/155-d...l#post58074988
I have everything; two DS115s, NX6000D, two 24"x36" sheets of poly, etc to build twin clear fronts, just trying to decide which model to build once I get my HOA to F off.
Theater: JVC RS540U, 2.35:1 142" screen, Onkyo RZ1100, Panasonic UB820, Outlaw Audio M2200 Monoblock x3, Klipsch RF7II, RC64II, RS62II, 5800CII x4 Atmos, PSA V3611 Subwoofer x2.
2 Channel: Parasound P6, Parasound A23+, Rega Planar 6 with Ortofon 2M Bronze, Klispch La Scala II.
Kothoga is offline
post #439 of 808 Old 02-06-2020, 06:17 AM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
From the link you posted: “I am adding the 16Hz tune version because massive extension, just add 12.75" to the port!”
The rest of the cutlist remains the same. You can make the extended port-board one piece, or add in a removable extension to have both tune options.
Juju @jujuman200 added in the extension later. I don’t think he’s ever going to switch it back though.
Chris
jujuman200 and Jan3 like this.
a77cj7 is offline
post #440 of 808 Old 02-06-2020, 06:58 AM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
Chris
@a77cj7
You would be correct sir..... not switching back. You do lose a touch of the top end with the lower tune BUT the sound is SO MUCH FATTER that I think that it is well worth it. I also have a Mini and two VBSS 31hz [bass section of my mains] to give me plenty of midbass. I only notice the lower top end output if I play the LFE alone which I have no reason to ever do. Therefore, the 2-3Db loss is not noticeable at all.
@Kothoga
IF you have the space.... go for the 16Hz tune.... you won't regret it.... BUT you will have to get used to their super clean tone.
Juju
Jan3 and a77cj7 like this.
post #441 of 808 Old 02-06-2020, 09:22 AM
Quoted: 31 Post(s)
Liked: 3
PM me your email, I can send the CAD file over. It opens up in metric by default when you first install FreeCAD. You would be modifying the data in the left pane. Select the part on the left, change the dimensions to something that works in mm in the data fields below. Then align the panels in the XYZ space. I would recommend the wire frame view, since you can clearly see if a panel is misaligned.
I would like this as well. Is this for a 18” or 15” drivers? I have a Dayton Audio TIT400C-4 15'' Titanic Mk III Subwoofer 4 Ohm
I’d like to build a box that I could lay on it’s side and use it as a stand for my tv and audio gear. I also have two Dayton 12” HO sub drivers
hessc50 is offline
post #442 of 808 Old 02-06-2020, 09:52 AM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
First, you need to decide which Devastator variant you want.
I modeled the titanic in three variants last time you asked. Up to you which best meets your needs and space requirements.
Any of them can be run on their sides.
Once you decide which variant you want to build, John can send you the CAD file so you can convert dimensions to metric.
Chris
a77cj7 is offline
post #443 of 808 Old 02-06-2020, 10:05 AM
Audiophile75's Avatar
Quoted: 208 Post(s)
Liked: 121
HS24
30w x 83h x 40d
2500w input power
10hz 3rd order HPF
40mm excursion
40m/s port velocity
Chris
Gee, I am so bored I think I will just put four sheets of wood in a square put a top and a bottom on it and throw in a speaker somewhere..... ya that sounds cool.
edit: I guess I should clarify.
You all make it look so easy (we know it is not) and now you came up with something bigger than a refrigerator LITERALLY.
Audiophile75 is offline
post #444 of 808 Old 02-06-2020, 10:10 AM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
Originally Posted by Audiophile75 View Post
Gee, I’m so bored I think I will just put four sheets of wood in a square put a top and a bottom on it and throw in a speaker somewhere..... ya that sounds cool.
Sounds like quite a few “installs” I remember from high school. Bonus points for freehand cutting and copious leaks.
a77cj7 is offline
post #445 of 808 Old 02-06-2020, 10:18 AM
Quoted: 31 Post(s)
Liked: 3
Chris
I’m sorry that I’ve asked many times, I have some health issues and my meds make me forget what’s up , lol
It’s all in me
I’m basically open the options I just want something that I can use this 15 inch driver to get down at least 17 hurts I don’t need to go crazy low and I’d like it to be something large so I could put my center channel on TV on it and some of my Audio Gear I have as much as 20 feet wide that I can go with it and his highest three or 4 feet in three or 4 feet deep so my options are really open on that I’m just looking for a good sound quality and efficiency I don’t want to have to use a 2-3- 4000 W amp for it and I do t need to break the windows in my house. My tv room is 20’ by 36’ and opens up to my kitchen and a hallway to the front door
I want to get this unit out of my setup. See pic, the other pics show the room empty, and shows how it goes into the breakfast room with the little flower planter divider wall and then it opens up into the kitchen off to the side and then has French doors on one side leading out to the Florida room
I have the option to use two different center speakers, a large horn type Yamaha or the 1of 200 made svsound center speaker
I need to get my Klipsch H1’s out of that tv unit shelves, it’s killing the sound. And I want to remove the svs and Klipsch subs that are on the right and left sides
hessc50 is offline
post #446 of 808 Old 02-06-2020, 10:38 AM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
It’s all in me
The titanic is not an ideal driver for Devastator usage. It gets peaky on the top end.
That said, @jujuman200 uses a Dayton HO in a mini dev, and is quite happy with it. It also has a peaky response.
Titanic 15 in micro dev FR:
36h x 18w x 24d
Mini dev v2:
40h x 25.5w x 24d
Mini dev 21 HCR:
40h x 30w x 26d.
I remember the micro port velocity being high, and the mini being very high. The mini 21 was much more reasonable.
The mini21 rear chamber models a bit oversize, so it might model nicely with a lower tune by plugging one port. Port velocity will increase though. I can try it tonight if you’d like.
Chris
hessc50 likes this.
a77cj7 is offline
post #447 of 808 Old 02-06-2020, 10:47 AM
a77cj7's Avatar
Quoted: 776 Post(s)
Liked: 809
Lol, the Omega LLT was kind of a joke between John and I. I never expected it to be built, was just proving a point.
John claimed the drivers lost too much efficiency at very low tunes.
I bet the HS24 wouldn’t given enough volume.
John told me to prove it.
I modded the Omega design for volume, and simmed it in hr.
Then we went back and forth with refinements.
The hard work was already done, since John has the omega design nicely finished.
I just extended the back of the cab, and adjusted port area as needed. Bit of napkin math for volume and good to go.
Chris
a77cj7 is offline
post #448 of 808 Old 02-06-2020, 01:28 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
[snip]......
Chris
As @a77cj7 stated, yes I am quite happy with the HO in my Mini. The KEY POINT is that since the driver is so peaky, you MUST chop off that mountain at about 60Hz -ish so that it doesn't start to muck up the midbass. Not that it sounds horrid or anything like that but you must really dial this beast in for your room. Each room is different so take the time to find your happy place...
**IT WILL BE A PITA.... PERIOD FULL STOP. BUT, when you get it right.... man is it right.**
Hope this helps...
Juju
post #449 of 808 Old 02-07-2020, 03:47 AM
Quoted: 13 Post(s)
These are the paramaters for the original adire audio tempest. I have two of these sitting around. Do you think they can be used in any of the devastator plans?
Fs 18.8 Hz
Qts .39
Vas 317 liters
Re 3.5 W
Le 2.9 mH
Znom 4 W
Qes 0.40
Qms 6.7
Mms 195 grams
Cms 0.374 mm/N
Rms 3.44 N*s/m
Sd 779 cm2
BL 14.2 N/A
EBP 47
No 0.51%
SPL 89.1 [email protected],1m
92.1 [email protected] Vrms
Xmax ±16.4 mm
Pmax 375W/coil;
750W total
rykerjen is offline
post #450 of 808 Old 02-07-2020, 06:42 AM - Thread Starter
Red Five's Avatar
Liked: 1008
I will not have much access to anything sub related until sometime next week...
This is the way...
Red Five is offline
devastator
