The Devastator Index - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 100Likes
post #31 of 202 Old 10-22-2019, 09:57 PM
Rcris's Avatar
Quoted: 121 Post(s)
Liked: 144
We have designs for 21s, 18s and 15s , 12s? I have plenty of jbl's brought from bestbuys thanksgiving sale and a couple of infinity 1262's if I can make better use of them in a small enclosures.
I had to settle with ported boxed for my lavoces 21s due to available space especially in depth, couldn't go beyond 20". I may squeeze in mini with 24" but sure they can't be near with just ported lavoces 21s. But sure I will build the minis or mbm 30 to utilize my pa460s on hand for study room.
Rcris is offline
post #32 of 202 Old 10-23-2019, 06:33 AM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
I looked into a full range Dev for 15"s and it is down about 7db at 20Hz vs the 18"s, which is down about 4db at 20Hz from the 21"s. The PA460s in the Minis will have a lot more mid bass than the VBSS, if you do not mind the added complexity of the enclosure.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #33 of 202 Old 10-24-2019, 08:54 AM
Rcris's Avatar
Quoted: 121 Post(s)
Liked: 144
Dayton Audio PN470-8 18 is on sale today, would this fit in any of these designs.
Rcris is offline
post #34 of 202 Old 10-24-2019, 01:41 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
I haven't simmed it, but looking at the specs yeah it would do just fine. The mini would most likely be the most ideal. The SAF is not expected in till 11/26 now
post #35 of 202 Old 10-28-2019, 02:58 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
Two builds have been added to the OP of the Index
a77cj7 likes this.
post #36 of 202 Old 11-05-2019, 02:07 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
Narrow Mini Devastator 18"
Another addition to the Devastator family the Narrow Mini Devastator has been designed to work in @Audiophile75's space The tune comes out to a calculated 20Hz and the length of the front resonator is very close to that of the standard Mini Devastator, just a little was taken off for added port height. Note that the panel overlap is not standard, it is close to the Micro Devastator. Sim is calculated using the SAF184.03, port velocity is down slightly.
Note panel alignment
SPL graph about 1300 watts 20Hz 2nd order HPF
Name:	Narrow Dev mini side shot open.jpg
ID:	2636820   Click image for larger version
Name:	Narrow Mini Dev rear hatch view.jpg
ID:	2636822   Click image for larger version
Name:	Narrow Mini Dev front view note panel alignment.jpg
ID:	2636824   Click image for larger version
Name:	Narrow Mini Dev SAF 2ndO HPF 20Hz 86 volts Particle Velocity .jpg
ID:	2636826   Click image for larger version
Name:	Narrow Mini Dev SAF 86 volts 20Hz 2ndOHPF.jpg
Name:	Narrow Mini Dev final input.jpg
ID:	2636830   Click image for larger version
Name:	Narrow Mini Dev cut list.jpg
ID:	2636832   Click image for larger version
Name:	Narrow Dev PA460.jpg
post #37 of 202 Old 11-05-2019, 02:35 PM
Audiophile75's Avatar
Quoted: 168 Post(s)
Liked: 93
Thank you @redfive for working on this for me.
So, what's cool about this design besides the 21” width? Well for starters this design was also though of for the pa460 as I have two just laying around with the intentions to upgrade at a later day. As discussed by us the pa460 will take 300w at max excursion which will be at a 10db loss at 20hz compared to the SAF184.03 at 1300w. So, when do the SAF’s go on sale? Lol.
I guess I know what at I’m doing this weekend.
Audiophile75 is online now
post #38 of 202 Old 11-05-2019, 02:40 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
Originally Posted by Audiophile75 View Post
Thank you @redfive for working on this with me.
So, what cool about this design besides the 21” width? Well for starters this design was also though of for the pa460 as I have two just laying around with the intentions to upgrade at a later day. As discussed by us the pa460 will take 300w at max excursion which will be at a 10db loss at 20hz compared to the SAF184.03 at 1300w. So, when do the SAF’s go on sale? Lol.
I guess I know wh at I’m doing this weekend.
I did a quick edit, the PA460 chart is in the attachments. Looking forward to seeing the build
post #39 of 202 Old 11-11-2019, 08:35 AM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
Two more builds have been added to the OP!
EndersShadow and a77cj7 like this.
post #40 of 202 Old 11-20-2019, 01:54 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
Mini Devastator 21" Version
This is a slightly beefed up version of the Mini for 21" subs, such as the SAN214.50 This gives the sub a little more breathing room than the standard Mini. The simulation is done with 91 volts/1600 watts going into the Lavoce SAN214.50 with the standard inductance model. A 20Hz 2nd order HPF is active. Port velocity is under Eminence recommendation of 34m/s and considering the output is over 117db when it is at the highest point I doubt that is what you will be hearing 91 volts is the expected power output of a NX3000 bridged at 20Hz for longer than just a fraction of a second. The point of resonance is moved up a little vs the v1 since quarter wave resonator is shorter.
@johnson636
SAN 214.50 v1 vs the Mini (v1 is in dark)
Name:	Mini Dev 21 Side Open.jpg
ID:	2643464   Click image for larger version
Name:	Mini Dev 21 Front shot 91 volt SPL 20H2ndOHPF.jpg
ID:	2643466   Click image for larger version
Name:	Mini Dev 21 input.jpg
ID:	2643468   Click image for larger version
Name:	Mini Dev 21 Excursion 91v20H2ndOHPF.jpg
ID:	2643470   Click image for larger version
Name:	Mini Dev 21 Particle Velocity vent-horn 91v20H2ndOHPF.jpg
johnson636 and jujuman200 like this.
post #41 of 202 Old 11-20-2019, 05:23 PM
johnson636's Avatar
Quoted: 1346 Post(s)
Liked: 825
That is just great!
Red Five likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #42 of 202 Old 11-22-2019, 01:38 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
Another build thread has been added to the OP, Devastators and other fun stuff...
post #43 of 202 Old 12-01-2019, 03:04 PM
Quoted: 44 Post(s)
Liked: 52
Red Five, can you post a plot of the mini dev vs mini MBM dev for PA460?
Racerryan is offline
post #44 of 202 Old 12-01-2019, 04:23 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
It is under the attachments for the MBM. You can see 1w1m sensitivity is pretty close. Excursion should be a little less on the MBM with the higher tune.
post #45 of 202 Old 12-09-2019, 09:55 AM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
Micro Devastator Full Range 15"
This is the Micro Devastator Full Range, for when you are tight on space and still want a good punch! Sub mounting - 8.5in from the top of the baffle and centered on the baffle. The cutout for the rear hatch assembly is 8in. Panel overlap is not standard, pay close attention, matches the MBM version cabinet. Port routing is the same as the Mini Devastator. Models are done on the Lavoce WAF154.00. The PA380 should be another budget option for this sub. I would also image the 15TBW100 will also work fine. The input information is in the attachments along with a few more shots of the CAD.
1000 watts for this and the other sims. 20Hz 2nd Order HPF is active.
Name:	Micro Dev FR cutlist.jpg
ID:	2651602   Click image for larger version
Name:	Micro Dev FR 1000 watts 20H2ndOHPF Velocity.jpg
ID:	2651604   Click image for larger version
Name:	Micro Dev FR Input.jpg
ID:	2651606   Click image for larger version
Name:	Micro Dev side shot open.jpg
ID:	2651608   Click image for larger version
Name:	Micro Dev FR front shot.jpg
Name:	Micro Dev side shot closed.jpg
ID:	2651612   Click image for larger version
Name:	Micro Dev FR no hatch.jpg
ID:	2651614   Click image for larger version
Name:	Micro Dev FR back shot no lower panel and upper.jpg
ID:	2651616   Click image for larger version
Name:	Micro Dev FR excursion 1000 watts 20Hz2ndOHPF.jpg
ID:	2651618   Click image for larger version
Name:	Micro Dev FR 1000 watts 20Hz2ndOHPF SPL.jpg
Rcris likes this.
post #46 of 202 Old 12-10-2019, 09:49 AM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
Bmd omega v1 24"
BMD OMEGA!!! Designed for the HS 24MKIII this is the low end beast no one really needs, but this is AVS! 5000 watts peak is what the box is designed for. Graphs are all calculated based on 5000 watts with a 15Hz 2nd Order HPF enabled. Cut out 3 inches of material from the front rail, no chance of the sub hitting the rail. The cutout diameter is 22.5 for the sub with 1.5 inches between the top of the cutout and the top of the rear chamber. Tune is estimated around 16Hz. NOTE: THIS BOX VARIANT REQUIRES THE HS24 TO BE SPECIFICALLY MADE FOR FRONT MOUNTING WHEN YOU PURCHASE IT.
Name:	BMD Omega input.jpg
ID:	2652058   Click image for larger version
Name:	BMD Omega Back shot.jpg
ID:	2652060   Click image for larger version
Name:	BMD Omega side shot open.jpg
ID:	2652062   Click image for larger version
Name:	BMD Omega front shot.jpg
ID:	2652064   Click image for larger version
Name:	BMD Omega Rail cutout .jpg
Name:	BMD Omega cut list.jpg
ID:	2652068   Click image for larger version
Name:	BMD Omega SPL 5000 watts 15Hz2ndOHPF.jpg
ID:	2652070   Click image for larger version
Name:	BMD Omega Particle Velocity Horn-Port 5000-15Hz2ndOHPF.jpg
ID:	2652072   Click image for larger version
Name:	BMD Omega excursion .jpg
DigiWega, femi and tarponater like this.
post #47 of 202 Old 12-10-2019, 11:56 AM
EndersShadow's Avatar
Quoted: 1282 Post(s)
Liked: 1546
^Whats port velocity look like on that bad boy with 5k on it?
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #48 of 202 Old 12-10-2019, 12:00 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
I like hiding things in the attachments.... I noticed HR has the same velocity calculation for a bass reflex box as this sixth order bandpass. Excursion is a little lower on the bandpass, I would guess velocity would be a little lower too. Originally it peaked at 34m/s and I could not be happier, but the sub would not fit so I had to add more volume which pushed it up over 35m/s. The horn has a good velocity on it too, I would image TR is going to be impressive on this one.
post #49 of 202 Old 12-10-2019, 12:09 PM
Liked: 1546
My bad, I missed that. I normally just assume any pictures in the post are the same as in the attachments.......
post #50 of 202 Old 12-10-2019, 12:14 PM
Liked: 1546
Not sure where this was asked (so I'm cross posting it in a few diff threads)....
Regarding the SI 24" driver and "back mounting it", while possible, not sure I'd take the gamble. This is taken from Ricci's SHS-24 review (link)
The surround is glued and clamped to the frame lip with a set of 8 aluminum clamps. These give the front of the driver frame a distinctive look. It is recommended not to remove these but if they were it would be possible to back mount the driver, if the application required it.
post #51 of 202 Old 12-10-2019, 12:21 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
The little dips in the front of the frame are going to be fun to seal. Yeah not recommended to remove that front piece... Does Si have a different front surround kit for front mounting?
post #52 of 202 Old 12-10-2019, 12:36 PM
Liked: 1546
If there is one, I've never heard it discussed or seen it. That said, I'm by no means the expert on Nicks stuff, just an avid fan of large high performance drivers in general, so I do a lot of reading.....
I'm sure one could be fabbed up by someone somewhere if they were given the proper spec's, but no idea on cost.
post #53 of 202 Old 12-10-2019, 01:16 PM
jujuman200's Avatar
Quoted: 202 Post(s)
Liked: 196
STOP being a baby @Red Five and just ONE WAY the thing..... put it in before the rails and be done with it .....LOL. Trust me.... you are NOT going to blow this woofer in a domestic setting... I promise you... so there will be no need to ever take it out......
P.S. You do know that I'm just ribbing you
Juju
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #54 of 202 Old 12-10-2019, 01:30 PM
Liked: 1546
Originally Posted by jujuman200 View Post
.....there will be no need to ever take it out......
I disagree..... what happens when BMD OMEGA v2.0 comes out
post #55 of 202 Old 12-10-2019, 01:39 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
jujuman200 likes this.
post #56 of 202 Old 12-10-2019, 02:21 PM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
This might be a viable work around solution. Keeps the driver flush with the horn, so it should stay closer to the simulation since it will be recessed about 1.5 inches or flush with the front chamber wall. Spacer and chamber wall are cut out 25"s, outside diameter is said to be 24.5". A crap ton of screws will be used on the removable baffle to hold the woofer to the spacer and the chamber wall. This way the woofer is mounted on the rear flange and that makes sealing it a lot easier.... Thoughts? Since I moved the woofer down, it will have a steeper roll off on the right side.
Name:	Omega Baffle work around.jpg
ID:	2652172   Click image for larger version
Name:	Omega Baffle work around ang2.jpg
ID:	2652174   Click image for larger version
Name:	Omega Baffle work around ang3.jpg
jujuman200 and a77cj7 like this.
post #57 of 202 Old 12-10-2019, 05:24 PM
tarponater's Avatar
Quoted: 163 Post(s)
Liked: 657
Nick has a 24 front mounted in a VW, IB manifold. I'll ask him what he did. Although it may be back mounted onto a baffle then bolted to the manifold.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii 11cuft sealed, Behringer NU-12000, Crown XLS-2502, MINIDSP 2X4
tarponater is offline
post #58 of 202 Old 12-11-2019, 03:17 AM
hd0823's Avatar
Quoted: 891 Post(s)
Liked: 1692
You thinking of building a pair to . These really will be easy to work into the basement. I'm finishing 2000sq ft next year and am going to hide these so they wont be visible. It will just be a suprise to people getting blasted with a wall of bass.
Sent from my SM-N975U using Tapatalk
tarponater likes this.
hd0823 is online now
post #59 of 202 Old 12-11-2019, 07:33 AM
tarponater's Avatar
Quoted: 163 Post(s)
Liked: 657
Just one to what it's like. I don't really have a place to put one so I'll likely just scrap it after the newness wears off.
chadsmith013 likes this.
post #60 of 202 Old 12-11-2019, 08:13 AM - Thread Starter
Red Five's Avatar
Quoted: 908 Post(s)
Liked: 710
If you can get that info that would be great for choosing which path to take. I have the CAD file updated with the spacer and removable manifold, but I have to do the math again to see what it looks like in HR and make a new cut list.
