The Devastator Index - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 1125Likes
post #601 of 1650 Old 02-28-2020, 07:36 AM
tarponater's Avatar
Quoted: 227 Post(s)
Liked: 795
Originally Posted by Red Five View Post
If I punch the height it will have lower peak/dome in the response, it would be more close to 70Hz. I can blow up velocity some and lower the tune to say in the form factor. Efficiency really picks up once you are a little above the Fs of the sub, in this case 30Hz. The extension would be worth it if you plan on running just the MBMs for music purposes. If you area always running the 24"s you will probably be crossing over between subs somewhere between 40Hz and 50Hz.
This will be exclusively HT use. I only use the back 24s for music. I'll differ to your judgement on this. These will be crossed with my 24s, probably in the 50-60Hz range. As for cabinet complexity, I'm not worried about it. I'm sure I can figure a way to build whatever you come up with.
chadsmith013 likes this.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii sealed, Dual SAN 214.5 Devastators, Dual Crowson actuators, NU12000, NX6000, XLS-2502, MINIDSP 2X4
tarponater is online now
post #602 of 1650 Old 02-28-2020, 07:39 AM
tarponater's Avatar
Quoted: 227 Post(s)
Liked: 795
Also, the 21s are a done deal. I'm trading some work for @chadsmith013 LaVoce.
post #603 of 1650 Old 02-28-2020, 08:15 AM - Thread Starter
Red Five's Avatar
Quoted: 1328 Post(s)
Liked: 1245
The 20Hz to 30Hz range is just an awkward place. You can a little efficiency with a high 20s tune, but not much of anything. Once you get north of 30Hz the efficiency becomes much more apparent. I would run the short Mini horn in a box and then tune the back to 17 or 18Hz so it runs full range or just go for a true PA/MBM tune. 60x25.5x24 using most of that for low end should work well. The port might reach the hatch sooner than ideal. What kind of power do you plan on running?
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | CTS 2000 | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #604 of 1650 Old 02-28-2020, 09:15 AM
tarponater's Avatar
Quoted: 227 Post(s)
Liked: 795
They will be on a bridged XLS2502
post #605 of 1650 Old 02-28-2020, 09:30 AM - Thread Starter
Red Five's Avatar
Liked: 1245
Based on the spec sheet it looks like the XLS2502 runs out of voltage around 111 volts and current at 24.5amps. The SAN is 5.2 Ohms so the amp at 111 volts should be pushing 21.35 amps in to the sub or 2370 in watts. I am assuming one amp per sub on this.
Back to cabinets, I would A: doing something full range, what is the tune on the 24" cabinets? B: go with a Mini MBM tuned to the mid to upper 30s. If you look at the Mini MBM notice it only gains 2db in efficiency with a 28Hz tune vs a 20Hz tune. Go under 20Hz or go over 30Hz would be my suggestion. Running subs with much different tunes in the same frequency domain can be done, but it is a lot of measuring tweaking and back and forth.
This is the way...
post #606 of 1650 Old 02-28-2020, 10:33 AM
Llamas's Avatar
Quoted: 81 Post(s)
When it comes to sustained versus power ratings and SPL, what kind of numbers usually apply in actual use? I know this is a matter of personal preference, but should I be planning/modeling around power required for sustained 120dB output when I'm going to be listening at 80dB with ~100dB peaks?
Llamas is offline
post #607 of 1650 Old 02-28-2020, 11:39 AM - Thread Starter
Red Five's Avatar
Liked: 1245
Content is for the most part very dynamic, unlike sinewaves that will push a power forever. Most of the time the subs might only be running at 10s of watts if that. Music can push things more consistently than movie content. The dynamics in movies can require a good amount of firepower, but a lot of that is based on how the room is working for or against you. Space considerations should be taken into account. A couple TBW100s in Mini V3s should be more than enough for most people... If you are a core bass head just go straight to LFEs or V4s.
jujuman200 likes this.
This is the way...
post #608 of 1650 Old 02-28-2020, 11:39 AM
tarponater's Avatar
Quoted: 227 Post(s)
Liked: 795
I only have one XLS2502. I'll cross that bridge later.
The 24s are sealed, 11ft^3 net on an NU12000
post #609 of 1650 Old 02-28-2020, 11:52 AM - Thread Starter
Red Five's Avatar
Liked: 1245
That is a tough call, to get the 24"s to work with vented subs a 10Hz 8th order filter might be required if running them in a shared range. That would be a shame with those 24"s cutting off that hard and quick. If you can look at Chris's adventure with his HT18s sealed trying to get them to play nice with the vented Mini Devs. If you are running crossovers at 50 or 60Hz smaller boxes optimized for the range look good. On that sim with 2000 watts they were only pushing 10.6mm of excursion, there is a lot more left in the tank.
This is the way...
post #610 of 1650 Old 02-28-2020, 12:36 PM
a77cj7's Avatar
Quoted: 1018 Post(s)
Liked: 1070
He might be able to cross the 21’s 10hz or so over port tune as well. In my case, I was trying to maximize use of the dev’s as they were far more powerful than the sealed.
His case looks opposite.
@tarponater , have you integrated sealed and ported designs before?
Chris
a77cj7 is online now
post #611 of 1650 Old 02-28-2020, 12:43 PM
tarponater's Avatar
Quoted: 227 Post(s)
Liked: 795
I do not plan on running them in a shared range. The plan is roll the 24s off around 60Hz or lower, then let the Devastators take over from there. However, ported 24s is not an option in my theater, so if something like that wouldn't result in a good response then I'll just stick with the three 24s. As much as I want those Devastators, I'm definitely not going to take a step back doing this.
post #612 of 1650 Old 02-28-2020, 12:53 PM - Thread Starter
Red Five's Avatar
Liked: 1245
If you have been to a concert where your body is just getting beat into submission the frequencies at play are a lot higher than you think. I know it seems like a waste using 21"s for mid bass, but that is really what they are designed to do. They will add a lot more than you might suspect. @Jk7.2 has first hand experience here and a great thread - https://www.avsforum.com/forum/155-d...cro-build.html
Edit: you also have to factor in particles being pushed around the room. The QW on the MBM will add a lot in that department, especially if the BR chamber vent is resonating near the crossover point.
Jk7.2 likes this.
This is the way...
post #613 of 1650 Old 02-28-2020, 12:59 PM - Thread Starter
Red Five's Avatar
Liked: 1245
This is another interesting read - https://www.avsforum.com/forum/113-s...-response.html
This is the way...
post #614 of 1650 Old 02-28-2020, 01:14 PM
tarponater's Avatar
Quoted: 227 Post(s)
Liked: 795
Chris
I have mixed ported and sealed before and really haven't had much problem with integration. I have a nasty mountain range around 80-120Hz that is always there, no matter what kind of subs I have. So far, the smoothest response has been with five UM18 Full Marties tuned to 15 Hz.
post #615 of 1650 Old 02-28-2020, 02:26 PM
Llamas's Avatar
Quoted: 81 Post(s)
My question was less about the choice of sub design, and more about how much amplification is needed to support one in my use case. I'm talking about changing the SPL variable instead of the wattage in order to match my listening level. But to switch back to modelling based on amplification power, what's the output look like when you halve the power from 2000 W to 1000 W? 3 dB drop?
Llamas is offline
post #616 of 1650 Old 02-28-2020, 03:15 PM - Thread Starter
Red Five's Avatar
Liked: 1245
Yep, keep dropping 3db for each time power is cut in half.
This is the way...
post #617 of 1650 Old 02-28-2020, 03:31 PM
tarponater's Avatar
Quoted: 227 Post(s)
Liked: 795
Chris
If I can't figure out a way to make ported 24s, then it looks like there is another option. Like you said, the 24s will be handling ULF leaving mid and upper bass to the Devastators. @Red Five said to either tune the Devastators to under 20Hz or over 30Hz. Your suggestion was to cut the Devastators off about 10Hz over tune. What if I did an 18-19Hz tune and cut them off at 30Hz? Then cut the 24s off around 40Hz. Or I could do a 30Hz tune, cut them off at 40Hz and cut the 24s off around 50Hz.
post #618 of 1650 Old 02-28-2020, 03:40 PM
Llamas's Avatar
Quoted: 81 Post(s)
I can probably start out with the XLS-202 and XLS-602 I've got sitting around, and evaluate that before buying more amps.
Red Five likes this.
Llamas is offline
post #619 of 1650 Old 02-28-2020, 03:43 PM
a77cj7's Avatar
Liked: 1070
Making ported 24’s will take some space, lol. I don’t know that its necessary, though COULD make integration easier. I’d base that more on whether they have enough output sealed, or you want more. A LLT hs24 is going to be a massive box though.
Imo, either the 18-20hz tune or the mbm will work. The mbm will be a much smaller, simpler enclosure.
The 18-20hz will probably need to be the hybrid box John and I were talking about earlier.
Since you don’t plan to run both full-range, the mbm will be a much simpler solution. You will end up with a bigger version of what jared, @Jk7.2 was running. In his case, he was using 15” dev mbm’s with ported hst18’s.
The only two reasons to go with the 18-20hz tune would be to add output from 30hz up, or to or to make the dev’s more useful as a stand-alone sub, expecting future system changes.
The mbm config will have higher output near crossover frequency due to the port tune, upper end will be the same on both with the same length QW.
Chris
Jk7.2 and tarponater like this.
post #620 of 1650 Old 02-28-2020, 03:54 PM
tarponater's Avatar
Quoted: 227 Post(s)
Liked: 795
Chris
It sounds like the MBM is the right option for what I'm looking to achieve. Although the 24s are excellent in the mid bass range, I know they can't compare to the PA21s. Is post 595 the MBM design you are referring to?
post #621 of 1650 Old 02-28-2020, 04:02 PM
a77cj7's Avatar
Liked: 1070
The 10hz-off-tune principle should still apply. So you won’t have to shut the 24’s down early if you don’t want to. I believe Jared was still running his nearfield and rear subs full-range with the mbms.
EDIT: Yes, thats the MBM concept.
Chris
post #622 of 1650 Old 02-28-2020, 04:09 PM - Thread Starter
Red Five's Avatar
Liked: 1245
The 21" MBM is 40x25.5x24. I used the sheet to math it out. @hd0823 what did you think of the MBMs in Jared's setup?
a77cj7 likes this.
This is the way...
post #623 of 1650 Old 02-28-2020, 04:35 PM
a77cj7's Avatar
Liked: 1070
Oops, missed that one. Looks good.
Chris
post #624 of 1650 Old 02-28-2020, 05:00 PM
Jk7.2's Avatar
Quoted: 1848 Post(s)
Liked: 3382
Ya know, I still need to do another honest evaluation of my system. But I ended up setting the recommended high and low pass on the micro devs, and front subs, but raising the low pass on the front hst’s until I got all the way up to 75hz. So that’s where the front 4 subs are set at. The rest of the settings I’d have to look at again. I forgot where they landed, but I am still super happy with what the mbm devs added to my system. Even with the nsw’s, the mbms still add to the experience.
Edit: I checked the settings on the other subs. Rears and near field are low passed at 70hz in the dsp. The pre/pro crossover is at 80, so I’m not sure how those settings interact. But I measured all of my tweaks, trying different slopes and frequencies, and this looked the best.
Jk7.2 is online now
post #625 of 1650 Old 02-29-2020, 08:55 AM
carlobenavidesahavia's Avatar
Quoted: 96 Post(s)
Howmuch estimated would the materials cost for the BMD max?
This is the BMD MAX! The sub is built to handle the wrath of the Eminence NSW6021-6. Not too much has changed from the base BMD model. HPF 19Hz 2nd order should keep things in check. 95 volts = roughly 2.38 kw with 3.8 Ohms of load. The main goal of the design was keeping port velocity under 25m/s.
carlobenavidesahavia is offline
post #626 of 1650 Old 02-29-2020, 10:01 AM
mhutchins's Avatar
Quoted: 365 Post(s)
Liked: 347
Without spending any time trying to figure it out I would guess 4-6 sheets of plywood per box. At HD that would be $120-180, plus glue, brads or screws and SpeakONs, so figure ~$200 before tax.
Mike
mhutchins is offline
post #627 of 1650 Old 02-29-2020, 11:32 AM
Kothoga's Avatar
Quoted: 189 Post(s)
Liked: 257
Originally Posted by MTBDOC View Post
Look up an actual plywood dealer or supplier in your local area. As I noted above, the Baltic Birch is very reasonable in cost now, comparable to hardwood ply @ the big box stores per sq ft and FAR better quality. Everything you buy at HD or Lowes will have voids, you just may not cut into one and so you don't see it. Use BB once, and you will understand. The cost issue was surprising to me this time (cheaper!).
Started to make a list of the places I've found locally that carry it, only one was open today and they quoted me $80 a sheet for 5x5, of which I'll need 9!
Theater: JVC RS540U, 2.35:1 142" screen, Onkyo RZ1100, Panasonic UB820, Outlaw Audio M2200 Monoblock x3, Klipsch RF7II, RC64II, RS62II, 5800CII x4 Atmos, PSA V3611 Subwoofer x2.
2 Channel: Parasound P6, Parasound A23+, Rega Planar 6 with Ortofon 2M Bronze, Klispch La Scala II.
Kothoga is offline
post #628 of 1650 Old 02-29-2020, 11:34 AM
Kothoga's Avatar
Quoted: 189 Post(s)
Liked: 257
https://www.cutlistoptimizer.com/
Type in the sizes and find out. Figure ~$30 a sheet of 4x8 plywood from HD.
Kothoga is offline
post #629 of 1650 Old 03-02-2020, 09:11 AM - Thread Starter
Red Five's Avatar
Liked: 1245
Devastator Dual JBL 12"
As requested I have designed a box for dual JBLs! The box should be wired in parallel, resistance should be around 1.8 Ohms. Power handling is around 600 watts, that should push 15mm of excursion with a BW 19Hz 2nd order high pass filter active. Tune comes in a 17Hz, it should have a fair amount of extension, more than fair for 12"s...
Name:	Dual JBL input.jpg
ID:	2692546   Click image for larger version
Name:	Dual JBL side shot.jpg
ID:	2692548   Click image for larger version
Name:	Dual JBL back shot.jpg
ID:	2692550   Click image for larger version
Name:	Dual JBL front shot.jpg
ID:	2692552   Click image for larger version
Name:	Dual JBL 600 watts BW 19Hz 2nd OHPF SPL.jpg
Name:	Dual JBL 600 watts BW 19Hz 2nd OHPF Ex.jpg
ID:	2692558   Click image for larger version
Name:	Dual JBL 600 watts BW 19Hz 2nd OHPF Velocity.jpg
ID:	2692560   Click image for larger version
Name:	Dual JBL cutlist.PNG
This is the way...
post #630 of 1650 Old 03-02-2020, 10:24 AM
a77cj7's Avatar
Liked: 1070
Ouch. My supplier here is around that price for 4x8, but 5x5’s are $35.
Chris
devastator
