The Devastator Index - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 549Likes
post #781 of 880 Old 03-24-2020, 10:07 AM
Quoted: 156 Post(s)
Liked: 70
Wow thanks gang, that was quick and complete response! I think I will employ a two way LFE Sub stage here. For live music content I can run the Devs only full range with a 25Hz HP brick wall. For movie content, that’s where I will employ the two way profile. I’ll need to clearly sweep both and see where the best cover point will be and then extract the most efficient spectrum from each cabinet. I’m confident I’ll be able to get the xover regime flat. I’m currently running very strong LCR with robust midbass to 40hz. They are a quad three way DIYSG Custom Mag12/BMS Coaxial Horn scratch built design and I am currently using them in the LFE mix via the 7705 settings.
I have 9 18” SP1804 Buyout 18s in storage (picked them up when they were 75$ each at PE) They are equivalent and a little more efficient than a PA460 in the MB arena, so originally I was gong to put 6 of them in GSG 18” MB ported box’s, but building Devs and investing in 21s looks more attractive. I’ve had JTR Growlers years ago, and I absolutely love Horn sources midbass, it has just a better and more impactful tone than ported.
Currently running two 24s and multiple sealed SI18s, two more HS24s in the finish and driver loading stages.
Anyone have the acoustic output curves for the GSG Dev with various drivers? I’ll probably go LaVoce in them.
Thanks gang. Please be safe. Luckily, sheltering in the HT is kind of refreshing for those of us who have invested so much time and resources and never have time to enjoy it, I am.
Sent from my iPad using Tapatalk Pro
FOHTech is offline
post #782 of 880 Old 03-24-2020, 10:09 AM
johnson636's Avatar
Quoted: 1532 Post(s)
Liked: 1026
Originally Posted by a77cj7 View Post
Mini dev has 20hz port tune.
Sealed:
10hz 8th order BW HPF
120hz 8th order BW LPF
Mini dev:
20hz 2nd order BW HPF
(Current setup)
11hz ported:
11hz 8th order BW HPF
80hz 6th order BW LPF
Mini Dev:
16hz ported:
15hz 4th order BW HPF
80hz 4th order BW LPF
Mini Dev:
20hz ported:
18hz 2nd order BW HPF
Mini Dev:
(Was a touch of cancellation on the top end of this one. I didn’t like the low end result in my room, so never refined further)
You can find rew graphs on all of these in my build threads.
As you can see, the more separation in port tune, the more interesting the integration.
I have not found a successful way to model phase interaction, this was all done with trial and error, lots of changes and measurements.
Next I will be integrating an Alpha dev (should be easy) and a Submax v3
(Could be interesting) into the 11hz version I run now.
Chris
That's a lot of time and effort you put in. My ported and devs are within a 1-2Hz so I didn't have much to worry about. Good thing you have a lot of patience
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #783 of 880 Old 03-24-2020, 10:13 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
I will go fire up my laptop and post the v1 lavoce response. Apparently don’t have it on my phone. 21ds is identical, nsw is a bit heavier low end, not worth the cost for your use. Any other drivers?
EDIT: Lavoce driver on 1000w
20hz, 2nd order HPF
12mm excursion
22m/s port velocity.
Not sure how much power you want to send, I can model higher.
Gsg dev should be very close or identical to the v1. Dimensions are very close.
Chris
a77cj7 is online now
post #784 of 880 Old 03-24-2020, 12:34 PM - Thread Starter
Red Five's Avatar
Quoted: 1160 Post(s)
Liked: 1042
Two new build threads have been added to the OP of the Index!
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is offline
post #785 of 880 Old 03-24-2020, 03:23 PM
Quoted: 156 Post(s)
Liked: 70
20hz, 2nd order HPF
12mm excursion
Chris
Thanks Chris! The LaVoce will be perfect. Each will have a couple thousand honest watts available. FP22k clone, 1 per channel but highly attenuated down from clipping for the amps longevity. Ill just add 3db or so to the curve for a doubling of power, although I dont intend to push it that hard. Its amazing how much of a peak from 50hz to 90 hz there is. Ive got mad cabin gain at 40hz so that should work out. I think a pair should hit the 140db mark around 80hz at 1kw per cab, agree?
FOHTech is offline
post #786 of 880 Old 03-24-2020, 03:32 PM
tk123's Avatar
Quoted: 184 Post(s)
Liked: 141
20hz, 2nd order HPF
12mm excursion
Chris
Which LaVoce driver and enclosure is this ? I must have missed the details although I read all the posts again.
tk123 is offline
post #787 of 880 Old 03-24-2020, 03:43 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
The original v1 dev, which GSG sells a flatpack for.
Driver is the LaVoce San214.50, the best budget 21” driver currently. Probably the best performing 21” driver in most Devastator variants as well, the NSW causes port velocity to go very high.
I believe the SAN looks pretty good in a v1 up to 2000w, port velocity gets higher of course.
Chris
post #788 of 880 Old 03-24-2020, 03:49 PM
tk123's Avatar
Quoted: 184 Post(s)
Liked: 141
Chris
What differences are there between the LaVoce series drivers in general ( San, Saf, Waf, etc ) ? Thanks again. Just trying to determine what makes one driver better than another for a certain enclosure.
tk123 is offline
post #789 of 880 Old 03-24-2020, 03:53 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Model them and find out. It is very hard to guess response from the specs, thats why everyone models.
The san214 is the only 21” driver they make.
If you’re looking for an 18”, the SAF184.03 generally models the best for Devastators and low tuned ported boxes.
First letter: S = subwoofer, W = woofer.
Third letter: F = ferrite motor, N = neodymium motor
None of that tells you much about performance.
Chris
post #790 of 880 Old 03-24-2020, 04:30 PM
tk123's Avatar
Quoted: 184 Post(s)
Liked: 141
Chris
Ok. I figured out the F & N part, but didn't know the S & W parts.
Thanks for the tip on the SAF. I'll check that one out.
Todd
tk123 is offline
post #791 of 880 Old 03-25-2020, 12:05 PM
tarponater's Avatar
Quoted: 213 Post(s)
Liked: 764
I'm currently working on a few projects for someone so the Devastator MBM is in a holding pattern. I'm not sure what your time frame is on this, but I'm hoping to get started in April. I'll start a build thread once I get started.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii 11cuft sealed, Behringer NU-12000, Crown XLS-2502, MINIDSP 2X4
tarponater is offline
post #792 of 880 Old 03-25-2020, 01:02 PM - Thread Starter
Red Five's Avatar
Liked: 1042
I started experimenting on a shallow version of the BMD with a 19Hz tune. The sim is based on 2500 watts going into an NSW, port velocity sits around 34m/s, that is pushing it to the max I want to see in a design. The box shaves off 6 inches on the Alpha depth. It could make it more accessible to some. Output is not at all shabby...
Name:	Shallow BMD concept NSW.png
johnson636 likes this.
This is the way...
Red Five is offline
post #793 of 880 Old 03-25-2020, 01:51 PM
johnson636's Avatar
Liked: 1026
Sir, you are relentless.
Red Five likes this.
post #794 of 880 Old 03-25-2020, 02:18 PM - Thread Starter
Red Five's Avatar
Liked: 1042
There will not be an excuse for a Devastator not fitting a space that is reasonable.
johnson636 and Jedi940 like this.
This is the way...
Red Five is offline
post #795 of 880 Old 03-25-2020, 02:22 PM
johnson636's Avatar
Liked: 1026
^^^Just gave Red his 1000th "Like"
post #796 of 880 Old 03-25-2020, 03:32 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Heres a teaser pic of my current dev build.
BMD Alpha, with window.
Just finished the glue-up, finishing starts tomorrow.
Chris
post #797 of 880 Old 03-25-2020, 03:55 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Here’s a fun size-comparison:
BMD Alpha Devastator vs Submaximus v3
Output comparison:
Eminence NSW6021 on 2500w.
Alpha is black, v3 is gray.
No HPF
Please excuse the messy shop, I should work on that too.
Chris
post #798 of 880 Old 03-25-2020, 04:03 PM
Nalleh's Avatar
Quoted: 3047 Post(s)
Liked: 4401
^^^ WOW, that is A LOT less box, for pretty much the same output !!
Build thread on this one ?
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XB1X - ATV4K - JVC RS600 Dreamscreen V2 120"- Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #799 of 880 Old 03-25-2020, 04:18 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Yeah, I’m very curious about the sound signature of both. The v3 models with higher extension, but the Alpha matches it from 70hz down.
V3 is 43 cu ft external, Alpha is 27 cu ft.
Each will get their own build threads once completed. I like to post it up all at once instead of a making a drawn-out thread.
Chris
BP1Fanatic and Nalleh like this.
post #800 of 880 Old 03-25-2020, 04:54 PM
BP1Fanatic's Avatar
Quoted: 365 Post(s)
Liked: 339
Can't to see those build threads!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #801 of 880 Old 03-25-2020, 05:07 PM - Thread Starter
Red Five's Avatar
Liked: 1042
Chris
The mouths on the vent and QW look ridiculous on this beast
BP1Fanatic likes this.
This is the way...
Red Five is offline
post #802 of 880 Old 03-25-2020, 05:10 PM
hd0823's Avatar
Quoted: 932 Post(s)
Liked: 1756
Chris
Cant wait to see the results
Sent from my SM-N975U using Tapatalk
hd0823 is offline
post #803 of 880 Old 03-25-2020, 05:58 PM
Audiophile75's Avatar
Quoted: 209 Post(s)
Liked: 130
Me too. I have mini versions of both (F20s and mini Devs, kinda) and I do love the smoothness of the F20s, but the Dev has a more IN YOUR FACE feel. Now if I could just lower the tune to tame some of that on the Dev.
BTW is there a car in that garage? I can’t see anything behind them boxes.
Audiophile75 is offline
post #804 of 880 Old 03-25-2020, 06:56 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
You can lower the tune on the mini devs by plugging a port, but will make the in-your-face part worse. Or do you mean the qw tune?
Lol, these (mostly the v3) look huge in the shop, and that scares me. The quad dev looked reasonable out there, got way bigger in the theater.
Chris
post #805 of 880 Old 03-25-2020, 07:15 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Thanks Jeremy,
I got the idea for the angled mouth bracing on the v3 from your build and @Waterboy77 . I adjusted it for even spacing and less recess depth.
Chris
post #806 of 880 Old 03-26-2020, 12:02 PM - Thread Starter
Red Five's Avatar
Liked: 1042
21" bmd shallow hcr
I happy to announce there is another shallow option in the Devastator family! The simulation was conducted with a NSW pushing 2500 watts with an active BW 17Hz 3rd order high pass filter active. This is the limit for the box, velocity sits around 34m/s at that point. The native tune of the enclosure is 19Hz.
SAN214.50 1000 watts
NSW 2500 watts
Name:	BMD shallow input.jpg
ID:	2701940   Click image for larger version
Name:	Shallow BMD cutlist.jpg
ID:	2701942   Click image for larger version
Name:	Shallow BMD side shot open.jpg
ID:	2701944   Click image for larger version
Name:	Shallow BMD front shot.jpg
ID:	2701946   Click image for larger version
Name:	BMD shallow 2500 watts BW 17Hz3rdOHPF SPL.jpg
Name:	BMD shallow 2500 watts BW 17Hz3rdOHPF Vel.jpg
ID:	2701950   Click image for larger version
Name:	BMD shallow 2500 watts BW 17Hz3rdOHPF Ex.jpg
ID:	2701952   Click image for larger version
Name:	BMD shallow SAN 1000 watts SPL.jpg
This is the way...
Red Five is offline
post #807 of 880 Old 03-27-2020, 12:49 PM - Thread Starter
Red Five's Avatar
Liked: 1042
BMD Ultra Shallow 18"
This is the end of shallow for bigger subs (subs that are 18"+). The chamber depth is 10 inches, a 18TBW100 is 9.5 inches deep, we are cutting things close here! The rear access panel bracing is something to be mindful of, I did not see the size of the motor in the B&C spec sheet, the SAF184.03 lists the motor at 8.66 inches wide, I would image the B&C is close. The simulation is based on 1000 watts with a BW 20Hz 2nd order high pass filter active. The tune estimation is 19Hz. I ran the simulation with the 18TBW100-4. Excursion is looking good at 1000 watts, it might be able to handle another 200 watts or so.
Name:	BMD ultra shallow 1000 watts BW 20Hz 2ndOHPF Ex.jpg
ID:	2702414   Click image for larger version
Name:	BMD ultra shallow side shot open.jpg
ID:	2702416   Click image for larger version
Name:	BMD ultra shallow input.jpg
ID:	2702418   Click image for larger version
Name:	BMD ultra shallow front shot.jpg
ID:	2702420   Click image for larger version
Name:	BMD ultra shallow cut list.jpg
Name:	BMD ultra shallow 1000 watts BW 20Hz 2ndOHPF SPL.jpg
ID:	2702424   Click image for larger version
Name:	BMD ultra shallow 1000 watts BW 20Hz 2ndOHPF Velocity.jpg
This is the way...
Red Five is offline
post #808 of 880 Old 03-27-2020, 01:16 PM
johnson636's Avatar
Liked: 1026
Wow!
post #809 of 880 Old 03-29-2020, 05:50 AM
krholmberg's Avatar
Quoted: 214 Post(s)
Liked: 99
Silly question... If one is building upright Devastators, is it best to have the vents next to the floor or higher? I want to build the 15" MBM. If the vents are at the floor, there won't be floor bounce which should decrease midbass suck out. But, if the vents are up they blow right into your face.
Sent from my Pixel 2 XL using Tapatalk
Krister
krholmberg is offline
post #810 of 880 Old 03-29-2020, 05:56 AM - Thread Starter
Red Five's Avatar
Liked: 1042
Even at 80Hz the wavelength is a little over 14 feet. If you have a measurement mic I would try it both ways.
krholmberg likes this.
This is the way...
Red Five is offline
devastator
