The Devastator Index - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 1109Likes
post #811 of 1587 Old 03-29-2020, 07:39 PM
a77cj7's Avatar
Quoted: 1006 Post(s)
Liked: 1064
Couple more teaser shots of my windowed Alpha. Ready for paint.
Chris
BP1Fanatic likes this.
a77cj7 is online now
post #812 of 1587 Old 03-29-2020, 07:46 PM
krholmberg's Avatar
Quoted: 224 Post(s)
Liked: 106
That second pic is messing with my head
Sent from my Pixel 2 XL using Tapatalk
Krister
krholmberg is offline
post #813 of 1587 Old 03-29-2020, 08:11 PM
a77cj7's Avatar
Liked: 1064
Its the new open-baffle Devastator.
Chris
krholmberg likes this.
post #814 of 1587 Old 03-30-2020, 09:53 AM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
Originally Posted by Red Five View Post
I happy to announce there is another shallow option in the Devastator family! The simulation was conducted with a NSW pushing 2500 watts with an active BW 17Hz 3rd order high pass filter active. This is the limit for the box, velocity sits around 34m/s at that point. The native tune of the enclosure is 19Hz.
Comparing this shallow version to the V4, the shallow version appears to have greater output from 60Hz down. Outside of the V4 form factor possibly fitting on top of my current ported subs, is there a reason to even build the V4 now? If the height is available, it seems like the shallow BMD would be stronger on the low end. I would be using the B&C 21DS115 if it matters.
Jedi940 is offline
post #815 of 1587 Old 03-30-2020, 10:02 AM - Thread Starter
Red Five's Avatar
Quoted: 1311 Post(s)
Liked: 1241
The shallow boxes are running 19Hz tunes, that is an advantage at 20Hz since the V4 Mini which is tuned to 17Hz. That 17Hz tune pushes excursion more and drops output a couple db. It depends a lot on what you have for space available to, under my AT screen would not be good for BMDs, but Minis work great.
Edit: here is the 1w1m comparison with the 21 V4 and the BMD shallow 21. Most of the left side boost is the higher tune. The simulation is with the 21DS115.
Name:	BMD shallow vs V4 21s.jpg
jujuman200, Jedi940 and BP1Fanatic like this.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | CTS 2000 | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #816 of 1587 Old 03-30-2020, 10:02 AM
a77cj7's Avatar
Liked: 1064
The v4 is more of a full range sub, the BMD is stronger low end, but falls off earlier.
As a single sub solution, the v4 is more rounded.
Chris
post #817 of 1587 Old 03-30-2020, 10:22 AM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
Thanks for adding the graph. Makes it much easier than going back an forth between images If I can figure out where I'm gonna put it, I think the BMD would work better for me. Not sure I really have room for either but I'm trying.
Red Five likes this.
Jedi940 is offline
post #818 of 1587 Old 03-30-2020, 10:24 AM
a77cj7's Avatar
Liked: 1064
You can do it!
Chris
Jedi940 and Red Five like this.
post #819 of 1587 Old 03-30-2020, 10:27 AM
a77cj7's Avatar
Liked: 1064
Alpha and v3 painted, will be in the theater and running tomorrow.
Don’t be afraid to post a few pics of current and/or completed builds here. John @Red Five and I love to see them. I’m sure other people do as well.
Chris
post #820 of 1587 Old 03-30-2020, 10:31 AM
MTBDOC's Avatar
Quoted: 162 Post(s)
Liked: 109
BEASTLY!!! Nice work, Chris (as usual!). And bonus points for spraying which would indicate you have a good cartridge mask. They are actually far better than what we docs use in hospitals. Now the portable positve air units are nice, but really pricey. I have a box of masks & gloves, but if I went somewhere with high suspicion, I'd use the P100 + organic vapor mask.vv
MTBDOC is offline
post #821 of 1587 Old 03-30-2020, 10:35 AM
a77cj7's Avatar
Liked: 1064
Sadly, no. I decided to buy a good cartridge mask about the time they became unobtanium. I’m just running the standard rubber band masks.
Luckily duratex is a water-based coating with almost no fumes. Very friendly to use.
Chris
post #822 of 1587 Old 03-30-2020, 10:37 AM
MTBDOC's Avatar
Quoted: 162 Post(s)
Liked: 109
I suspect that most of us would struggle to even identify one vs the other if blindly auditioned! It gets back to my previous remarks about numbers chasing.
SO: how goes the baby-growing? I have a close friend whose wife is about to pop, but kid is breech and they don't want to do C-sect... watching to see if she will turn. Hospitals are getting to be less safe, but that mostly will be the ER & ICU. Maternity units are going to be kept WELL CLEAR of Coronaland. Just stay out of ERs and ICUs.
As an aside, all of the crisis about lack of ventilators neglects one chilling fact. Somewhere around 6 of 7 people going on a ventilator for this virus will never come off. And of the 1/7 survivors, some percentage will have permanent lung damage from directly inflammation from the virus, or from ventilator trauma. Take home message: don't get infect! Just be smart, WEAR A MASK (some good DIY stuff out there using HEPA or A/C filter material if you don't have something better), be mindful of EVERYTHING you touch...
MTBDOC is offline
post #823 of 1587 Old 03-30-2020, 10:49 AM
MTBDOC's Avatar
Quoted: 162 Post(s)
Liked: 109
Chris
Yeah, I have done Duratex in the house with a brush.
When the Ebola stuff was spooling up a few years ago and I learned what I could, I picked up Tyvex coveralls, plenty of gloves, masks, etc. Including full face double cartridge masks as well as a 'nose-mouth' cartridge mask. A couple of weeks ago picking up stuff at Lowes, I noticed they had a few 'nose-mouth' masks on the shelf! 3m, including P100 cartridges for $40. Resisted the impulse to buy them all, but picked up one which I gave to a female friend last week.
One easy thing to do is to keep a spray bottle in the car with diluted bleach (1c to 1gal H2O) and a few rags. Spray bleach onto the rag, use it at the gas pump. Use it to wipe your door handle 'just in case.' Easy enough. But do use a mask AND keep your distance. This is what many people have done for years and it clearly DOES help.
MTBDOC is offline
post #824 of 1587 Old 03-30-2020, 10:53 AM - Thread Starter
Red Five's Avatar
Liked: 1241
This baby is also sitting breach right now like her older sister was, we are hoping she turns around which did not happen with #1 . The hospital has strict rules about who gets in and out, OB is one of the few things open right now. No visitors are allowed and they are only allowing one person, which creates an issue since we did hire doula this round, that would count for the person during entirety of her stay. I am hoping that can get worked around.
Otherwise my wife is an RN in long term care, that facility has been on lock-down for at least 3 weeks, probably closer to 4 weeks. No positives in there yet, but they are taking a lot of admits and they do have a medicare wing for post procedures (I would think that wing has slowed down, no more hip procedures...), that sees a lot of turnover normally. We are due towards the end of May, hopefully that is the back end of the curve or it could be in the thick of it....
This is the way...
post #825 of 1587 Old 03-30-2020, 11:03 AM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
Perhaps. Numbers chasing can lead one down a rabbit hole, however, in this case, we are talking about a 3db increase in efficiency on the low end which would be the same as adding as second driver. 3db would be a noticeable difference. One of my opions (although it is my least favorite) is to take my current ported 21's and put them in a devastator so I am looking to maximize my gains as much as possible.
Jedi940 is offline
post #826 of 1587 Old 03-30-2020, 11:11 AM - Thread Starter
Red Five's Avatar
Liked: 1241
Here is where stuff gets really hard to discern. @Jedi940
V4 vs the V5
V5 vs the Finalizer
Now for fun this is the V1 vs the V5, remember it is the same size box...
Name:	V4 vs v5.jpg
ID:	2703530   Click image for larger version
Name:	V5 vs the Finalizer.jpg
ID:	2703532   Click image for larger version
Name:	V5 vs V1.jpg
This is the way...
post #827 of 1587 Old 03-30-2020, 11:29 AM - Thread Starter
Red Five's Avatar
Liked: 1241
Chris requested this... the 21DS115 was used on all cabinets but the Omega.
Alpha vs Shallow BMD (note the alpha was designed to deal with velocity for increased power handling)
Alpha vs Omega
Alpha vs the Finalizer
Name:	Shallow BMD vs Alpha .jpg
ID:	2703536   Click image for larger version
Name:	Alpha vs Omega .jpg
ID:	2703538   Click image for larger version
Name:	Alpha vs Finalizer.jpg
This is the way...
post #828 of 1587 Old 03-30-2020, 02:06 PM
a77cj7's Avatar
Liked: 1064
Not a Devastator, but John wanted me to put the pic up here anyway.
Submax v3 right after paint:
Chris
post #829 of 1587 Old 03-30-2020, 06:15 PM
BP1Fanatic's Avatar
Quoted: 425 Post(s)
Liked: 406
That bracing is killer!
a77cj7 likes this.
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is online now
post #830 of 1587 Old 03-30-2020, 07:06 PM - Thread Starter
Red Five's Avatar
Liked: 1241
Staring into the 1w1m comparisons gave me an idea. BMD with a Finalizer rear chamber. I will be working on that this week... The goal is a design optimized for room gain. -3db or -4db on the left corner from 30Hz and then +3db or more from 30Hz at the 80Hz point for headroom or hotter mid bass.
Jk7.2 and a77cj7 like this.
This is the way...
post #831 of 1587 Old 03-30-2020, 08:19 PM
FriscoDTM's Avatar
Quoted: 443 Post(s)
Liked: 393
OT, but PAPR respirators should be supplied to all front line medical workers. I am a hazmat responder and work with highly toxic materials, and I mainly use SAR and SCBA because PAPR isn’t safe enough. In my job people wear cloth masks to avoid contaminating a product not providing any measure of respiratory protection. It’s been pretty difficult watching all the news about N95 masks because it seems that even N95 is insufficient. Everyone working in a hospital should be in sealed Tyvec suits with CBRN PAPRs and double gloves, plus full decon like a hazmat response.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #832 of 1587 Old 03-31-2020, 10:41 AM - Thread Starter
Red Five's Avatar
Liked: 1241
Here is a sneak peek, this will be the BMD Delta. It is a 16Hz tuned beast coming in at 25 cuft, slightly smaller than the Alpha lol. It is the hybrid of a BMD and a Finalizer. Sim is 2000 watts going into the NSW with a 16Hz 3rd order HPF. Velocity sits at 32m/s with 2000 watts and 22.7m/s at 1000 watts.
Name:	BMD Delta concept.jpg
Jan3 likes this.
This is the way...
post #833 of 1587 Old 03-31-2020, 10:48 AM - Thread Starter
Red Five's Avatar
Liked: 1241
Delta comparison sims:
Alpha vs Delta
Delta vs BMD Shallow
Delta vs Finalizer
Name:	Alpha vs Delta.jpg
ID:	2703902   Click image for larger version
Name:	Delta vs Shallow BMD.jpg
ID:	2703904   Click image for larger version
Name:	Delta vs Finalizer.jpg
Jedi940 likes this.
This is the way...
post #834 of 1587 Old 03-31-2020, 11:24 AM
a77cj7's Avatar
Liked: 1064
Alpha assembled and ready to test. Will post a close-mic shortly.
This is the second operational Alpha, lol. Jared @Jk7.2 got his put together a few HOURS earlier.
Social distancing builds ftw.
Chris
post #835 of 1587 Old 03-31-2020, 11:35 AM
hd0823's Avatar
Quoted: 945 Post(s)
Liked: 1796
Chris
Man cant wait to hear your opinion between the alpha and v3
Sent from my SM-N975U using Tapatalk
hd0823 is online now
post #836 of 1587 Old 03-31-2020, 11:42 AM
Jk7.2's Avatar
Quoted: 1847 Post(s)
Liked: 3382
I got mine fired up! No boring testing for me. I just turned up to reference and started running bass demos. By itself it sounded very clean and pretty loud, but adding back in the remaining 3 NSW’s from the front, two rear hst’s, and the nearfield, my jaw dropped. Then a smile that’s still there. I told Chris that this sub gave my concrete floor tactile feel. Lol. It’s not too far from the truth. This is by far the best my room has ever sounded.
femi, BP1Fanatic, hd0823 and 3 others like this.
Jk7.2 is online now
post #837 of 1587 Old 03-31-2020, 11:46 AM
a77cj7's Avatar
Liked: 1064
Sadly, I may have an issue. I may be short on gasket tape. I wonder how fast PE can ship, lol.
I should know tonight. I have to rearrange a bunch of furniture and remove a sliding door to get the #%*£ thing in the house.
Chris
post #838 of 1587 Old 03-31-2020, 11:52 AM
hd0823's Avatar
Quoted: 945 Post(s)
Liked: 1796
Chris
Lol yeah that is one of the hardest things is moving it into the house . The last 2 had to be taken up the basement stairs to the theater not a fun job. I've always used the window closed cell foam for my gasket tape from home depot works really well and cheap also.
post #839 of 1587 Old 03-31-2020, 11:56 AM
a77cj7's Avatar
Liked: 1064
Only thing i’ve got local is a hardware store. Might see if they have some black window foam in the right size. Kinda misses the stay-at-home part, but thats what hand sanitizer is for.
My hatch panel is lexan, so I have to be picky, lol.
Chris
post #840 of 1587 Old 03-31-2020, 12:03 PM
a77cj7's Avatar
Liked: 1064
Delta vs Finalizer
Not much reason to go Delta, by that model. Sure shows just how good finalizer is. Hows the port velocity between the two?
Big advantage to Delta seems to be 2-3db output 30-65hz.
Chris
devastator
