The Devastator Index - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 105Likes
post #61 of 219 Old 12-11-2019, 09:13 AM
a77cj7's Avatar
Quoted: 423 Post(s)
Liked: 355
@Red Five , @hd0823 , @tarponater
I just talked to nick while discussing some things for my 18’s.
The already-built 24’s use the surround clamps instead of glue. Removing the clamps will destroy the subwoofer. This warning comes with them:
For 24’s ordered during the sale, or future orders, he can glue them while building. You will need to contact him on a case-by-case basis.
Chris
a77cj7 is online now
post #62 of 219 Old 12-11-2019, 09:22 AM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Spoiler!
It looks like two variants of the box are required then. One for the per-existing 24"s and one if you had the sub made for front mounting, since that will take away some box complexity and weight.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #63 of 219 Old 12-11-2019, 09:24 AM
a77cj7's Avatar
Quoted: 423 Post(s)
Liked: 355
Is the slight volume change actually going to affect any other dimensions,
Chris
post #64 of 219 Old 12-11-2019, 09:35 AM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Chris
External box dimensions should remain the same, from the spacer to the back of the box is 15.5", that is some breathing space if the subs depth is based from the back of the motor to the back of the flange. The center of the sub is down another 1.5" from the top of the manifold, so a slight change in the upper response is expected. Displacement lost might be around 10 to 20 liters, that is not much on a 500 liter chamber so the tune should still be under 17Hz.
post #65 of 219 Old 12-11-2019, 09:40 AM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
This is what the box currently looks like. It is still 27" deep.
Name:	Current Look BMD Omega v2.jpg
post #66 of 219 Old 12-11-2019, 09:46 AM
Quoted: 66 Post(s)
Liked: 30
I'm very much looking to build 2x Mini 21".
1. I don't think anyone has built that one yet, right ?
2. I will be using 18mm MDF, which is 1mm smaller than 3/4" MDF. Is there an automated way to re-calculate the cut sheet ? I can't figure this out manually, so I would have to calculate and then cut every sheet on the fly while building, which doesn't seem optimal. Any tips ?
jorisdriesen is offline
post #67 of 219 Old 12-11-2019, 09:55 AM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Unless @johnson636 has made progress without posting it to a thread, no one has built one yet. You can use Excel and just copy what @superkyle did on his BMDs. I can also send you the CAD file if you want to adjust that. Set the units of measure to mm in the preferences and then make the pieces 18mm. FreeCAD is not too hard to learn after watching a few videos. Everything was done using the Parts bench.
post #68 of 219 Old 12-11-2019, 09:59 AM
Quoted: 66 Post(s)
Liked: 30
OK would love to get the CAD file, that will be easiest I assume. Will pm you my email address.
post #69 of 219 Old 12-11-2019, 10:13 AM
johnson636's Avatar
Quoted: 1347 Post(s)
Liked: 831
I haven't started my build yet. I have to build new ported cabs for my 24s first
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #70 of 219 Old 12-11-2019, 12:35 PM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Chris
It is just dawning on me with the removable manifold you can easily switch between different subs of different sizes. Should I model the HST18MKIII later?
post #71 of 219 Old 12-11-2019, 12:38 PM
Jk7.2's Avatar
Quoted: 1674 Post(s)
Liked: 3016
Yes
Jk7.2 is online now
post #72 of 219 Old 12-11-2019, 12:41 PM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Originally Posted by Jk7.2 View Post
Yes
Do you have the MKIIs? I can run that too later provided I have the TS parameters
post #73 of 219 Old 12-11-2019, 12:43 PM
Jk7.2's Avatar
Liked: 3016
Yes I do. I’ll dig them up
Jk7.2 is online now
post #74 of 219 Old 12-11-2019, 01:11 PM
a77cj7's Avatar
Quoted: 423 Post(s)
Liked: 355
I really doubt I’ll build them, but it might help someone else. I believe the specs on the website haven’t been updated yet. Here’s the test data posted on Facebook. Sorry it’s hard to read.
I assume its way bigger than necessary for the 18” anyways.
Now if you can design one in a 20”x36” footprint, firing out the 20” side, I’m interested.
Chris
post #75 of 219 Old 12-11-2019, 02:37 PM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Chris
Sadly 21" is needed to fit the driver inside the cabinet. Ported is the best bet for that!
post #76 of 219 Old 12-11-2019, 02:40 PM
tarponater's Avatar
Quoted: 168 Post(s)
Liked: 675
Chris
It's funny, the first four things on that list are the things I want to do the most. He takes all the fun out of it.
jujuman200 and a77cj7 like this.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii 11cuft sealed, Behringer NU-12000, Crown XLS-2502, MINIDSP 2X4
tarponater is online now
post #77 of 219 Old 12-11-2019, 02:40 PM
a77cj7's Avatar
Quoted: 423 Post(s)
Liked: 355
Details, lol. If its doable at 21”, I can probably make it work.
Chris
post #78 of 219 Old 12-11-2019, 03:45 PM
jujuman200's Avatar
Quoted: 202 Post(s)
Liked: 196
@jorisdriesen
Unless you already have the drivers... you may wish to consider the RSS460HO in a standard Mini..... [ the extra box size of the Mini XL does not change the response of the 460HO]
The 21" Mini is the black line, the 18" in a standard Mini is the grey.....
I have a Mini with the 460HO and it slams... on the MAX SPL charts... the 460HO gives up about 3Db @ 30Hz.... other that that, they are just about even..
https://i.imgur.com/Axpupe9.jpg
Just a thought...
Juju
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #79 of 219 Old 12-11-2019, 04:04 PM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Originally Posted by jujuman200 View Post
@jorisdriesen
Just a thought...
Juju
Juju, did you figure out how much power the 460HO can handle? Just curious.
post #80 of 219 Old 12-11-2019, 04:48 PM
jujuman200's Avatar
Quoted: 202 Post(s)
Liked: 196
Not yet... I have not been able to go to full war mode yet... but I will say that they are very efficient. The second light blinking on an iNuke 3K is pretty darn loud just playing the ONE Mini...
Cutting loose that LFE will just be crazy. With all the subs going, " Normal" listening levels don't even blink the first LEDs on the iNuke...lol. Remember, the bass section of my 3way mains are 31Hz VBSS boxes so getting loud is not an issue....
Juju
Red Five likes this.
post #81 of 219 Old 12-11-2019, 05:37 PM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Juju
Does the sound signature stay very similar to the 214.50 in the LFE?
post #82 of 219 Old 12-11-2019, 05:55 PM
jujuman200's Avatar
Quoted: 202 Post(s)
Liked: 196
Yes... they play well together, the sound is very full but not in an "in your face" kind of way. Having a "mixed bag" of subs[two Devs + two Martys] gives my soundstage a nice front to back dimension to the sound with the Devs being laid back in the mix but belting out their low growl when needed.
Don't get me wrong, the Devs are definitely loud and forceful but unlike how direct radiators that "can be" boomy or bloated sounding..... the Devs are just clean notes from top to bottom.
I really like my current setup after all the tweaking to get the Devs to play nice, they sound AWESOME in my space [regardless what the charts say...]. If anything, I MAY change out the 18" Marty for a Mini.... time will tell..
Juju
post #83 of 219 Old 12-11-2019, 11:31 PM
Quoted: 66 Post(s)
Liked: 30
@jorisdriesen
Just a thought...
Juju
How come the 18" is above the 21" basically on all frequencies ?
The RSS460HO is slightly more expensive here than a 21DS115. The SAN184.03 for example is almost half the price of the 21DS115.
post #84 of 219 Old 12-12-2019, 05:27 AM
a77cj7's Avatar
Quoted: 423 Post(s)
Liked: 355
@jorisdriesen
Just a thought...
Juju
Uhh juju, what are your input voltage/wattage for that graph? The 460HO voltage looks way high.
Chris
post #85 of 219 Old 12-12-2019, 06:51 AM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Chris
This is 900 watts, pushing a little over 14mm of excursion. Not sure what 2/3 gap is on this beast, I would imagine at least 17mm. 20Hz 2nd Order HPF.
Name:	460HO mini Dev 900 watts.jpg
post #86 of 219 Old 12-12-2019, 06:57 AM
a77cj7's Avatar
Quoted: 423 Post(s)
Liked: 355
That seems more believable. Still a good looking graph.
I don’t know that I’d put much more than rated to a dayton, I know quite a few people have smoked UM’s with around rated power.
Chris
post #87 of 219 Old 12-12-2019, 07:07 AM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
Chris
I wonder if the RMS power is most pro woofers program power. I see nothing about pink noise and AES...
post #88 of 219 Old 12-12-2019, 09:05 AM
jujuman200's Avatar
Quoted: 202 Post(s)
Liked: 196
Chris
87 Volts
Juju
post #89 of 219 Old 12-12-2019, 09:45 AM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
bmd omega v2 24"
BMD OMEGA V2!!! The key difference is the removable manifold for using an existing HS24 or if you like to change drivers later down the road. There is probably more info hidden in those darn attachments... Response is so close to the V1, no need to post it. HR input is in the attachments. Note - when attaching the manifold be careful where you place the screws.
Name:	BMDOV2 Input.jpg
ID:	2652926   Click image for larger version
Name:	BMDOV2 Cutlist .jpg
ID:	2652928   Click image for larger version
Name:	BMDOV2 Notes.jpg
ID:	2652930   Click image for larger version
Name:	BMDOV2 Upper shot side open.jpg
ID:	2652932   Click image for larger version
Name:	BMDOV2 Side open.jpg
Name:	BMDOV2 Back shot wireframe Orthographic.jpg
a77cj7 likes this.
post #90 of 219 Old 12-12-2019, 09:54 AM - Thread Starter
Red Five's Avatar
Quoted: 918 Post(s)
Liked: 720
@tarponater , the v2 is posted. You should be able to use an existing HS24 with this
