The Devastator Index - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 1116Likes
post #1261 of 1622 Old 05-03-2020, 07:10 PM
johnson636's Avatar
Quoted: 1753 Post(s)
Liked: 1281
Originally Posted by Red Five View Post
Upgrading to a 21" in this scenario will not even take an afternoon.
If the cutout is for a 21 and use a reducer for the PA460, 20 minutes tops to change out the 18 for the 21
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #1262 of 1622 Old 05-03-2020, 07:39 PM
Audiophile75's Avatar
Quoted: 280 Post(s)
Liked: 277
Originally Posted by jujuman200 View Post
This build is NOT harder... it just takes longer.... just take your time and you will be fine. Since you were planing to get 2 PA460, if you have the space build 2 DEVS and upgrade later to 18TWB100 for even more kick... yes it is worth it and your amp is just fine to power these...
Juju
@Mocs123
This is good advice. It is far better to have the boxes for upgrade purposes into the better 18 and / or the 21 if you can. The 460 is a great budget driver but only an okay driver for full sub duty, by doing the upgraded driver you would be doing a substantial upgrade. If you do the VBSS’s then an upgrade is both a new driver and a new box..... again.
I have two mini narrows with 460s, you will want two boxes but you will not be disappointed even with the 460.
Audiophile75 is offline
post #1263 of 1622 Old 05-03-2020, 07:54 PM
Quoted: 12 Post(s)
Liked: 9
The Mini Devastator 21 version 4 would work well with a PA460 short term, just use a removable manifold. You could drop a SAN 214.50 in there later and it would literally be Germany vs France at the start of WWII for that SAN vs the PA... Considering you have a 3000 that would push enough power into the SAN to reach 118db ish at 20Hz. If I were choosing a path it would be that one up there. It always starts with the one great DIY sub, but eventually the desire for more clean bass will make you upgrade things. Upgrading to a 21" in this scenario will not even take an afternoon.
So, this is exactly the path I've been considering for my first DIY sub build(s). The PA460s are just so darn cheap to get started with. I saw another poster use what they called a removable "reducer" to fit an 18" but it could be removed and a 21" could be dropped in later. Is that what you mean by a removable manifold? Also, I've read someone recommend the bigger 6000 amp for DEVs and the 3000 for ones like the v.b.s.s. I know it has a lot to do with the drivers and the person above has a 3000 already, but for this particular path would getting a 6000 make sense so there's some head room or for future upgradability? Or, if you were to do 2 DEVs this way to start would a 6000 be required no matter what to power both of them even with the PA460s?
Ha, I must be slow to post. Some of this is already addressed right above my post.
Crantastic is offline
post #1264 of 1622 Old 05-03-2020, 08:14 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 429
Originally Posted by Crantastic View Post
[snip]..., if you were to do 2 DEVs this way to start would a 6000 be required no matter what to power both of them even with the PA460s?
That all depends on how loud you listen and how big your room is...and the Devs are very efficient.... so the 3000 is plenty to wreck your hearing. I have 2 DEVS and 2 Full Martys running on my 3000 just fine. Yes I watch movies at ref.... is a 6000 good to have....yes.... is it necessary?
Not at all...
Juju
johnson636 and Crantastic like this.
Sub List: 1- Red Five Mini V1 Devastator 18" w/PA460, 1- Red Five Devastator LFE 21", 1- Red Five Devastator 21" Finalizer V2 DF , 1- BOSS platform [The Hideaway Theater], 2- 18" "Full Marty" tuned to 17Hz w/RSS460HO
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #1265 of 1622 Old 05-03-2020, 08:39 PM
Quoted: 280 Post(s)
Liked: 277
With all this 460 talk and 3000 vs 6000 just remember that the 460 only has 11mm of travel (not a lot) so the power limits are very small. For my mini 460s I think 350w each is all they can handle before they smoke AND they are 8 ohm drivers so once you do do two at 4ohms you should still only be needing less than 1000 watts at 4 ohms = efficient for a lot of SPL.
jujuman200 and Red Five like this.
post #1266 of 1622 Old 05-04-2020, 06:48 AM
radchad3's Avatar
Quoted: 53 Post(s)
Liked: 26
Hello all. I am currently building 2 21" Dev version 6's. Things are going well so far. How long do you wait for the PL premium to dry and unclamp? I am using birch ply and have been able to use pockets screws for most places until now. Thank you!
Chad
radchad3 is offline
post #1267 of 1622 Old 05-04-2020, 06:58 AM
pyrobuilder's Avatar
Quoted: 49 Post(s)
Liked: 170
Chad
For the PL that I used, I re-enforced it with screws, which also minimized the number of clamps I needed to use. I found that overnight seamed to still leave the PL a bit squishy, I'd probably say a full 24 hours, or until you can't make much of a divot with your fingernail pushing into the glue. Or put some screws in to hold the rest of the time, but that makes a lot more bondo and finish work.
radchad3 likes this.
pyrobuilder is offline
post #1268 of 1622 Old 05-04-2020, 08:12 AM
a77cj7's Avatar
Quoted: 1013 Post(s)
Liked: 1066
Yup, 24hr before stressing joints.
Chris
a77cj7 is offline
post #1269 of 1622 Old 05-04-2020, 10:08 AM - Thread Starter
Red Five's Avatar
Quoted: 1318 Post(s)
Liked: 1244
For reference this is the PA460 chugging along at 300 watts with a BW 20Hz 2nd order high pass filter active in the Devastator Mini 21" version 4. Excursion is just over 10mm. It is definitely the ultimate in having an upgrade path... Edit: I updated the MD21V4 with the PA460 graph. You can look at the post to compare the SPL levels between it and the SAN.
Name:	Mini 21 version 4 PA460 300 watts 20Hz2ndOHPF.jpg
jujuman200 likes this.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | CTS 2000 | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is offline
post #1270 of 1622 Old 05-04-2020, 11:59 AM - Thread Starter
Red Five's Avatar
Liked: 1244
Devastator 21" Finalizer Version 2 DF (down firing)
This is a new Devastator variant! The orientation of the woofer is now down firing and they are also handy for stacking, (3db for added cone area and another 3db for doubling the power). I like this more than two woofers in the same box. This variant is close to the Finalizer it will be the Version 2 DF (down firing). I am including the assembly order in the pictures for this type of cabinet. Simulation is the SAN214.50 chugging along with 1000 watts, BW 16Hz 3rd order high pass filter active. The box features a shorter horn at 36 inches, that gives it more mid bass and saves on volume displaced. The port is a little shorter than the Finalizer, that pushes velocity up about 1.5m/s or so, but rear chamber volume is very close. Tune should be close to 16Hz. The way the baffle overlaps the horn cap, the woofer center is 12.75" from the top of the panel.
Name:	Finalizer Version 2 DF step 10.jpg
ID:	2720980   Click image for larger version
Name:	Finalizer Version 2 DF step 11.jpg
ID:	2720982   Click image for larger version
Name:	Finalizer Version 2 DF step 12.jpg
ID:	2720984   Click image for larger version
Name:	Finalizer Version 2 DF step 13.jpg
ID:	2720986   Click image for larger version
Name:	Finalizer version 2 DF input.jpg
Name:	Finalizer version 2 DF 1000 watts BW 16Hz 3rdOHPF SPL.jpg
ID:	2720990   Click image for larger version
Name:	Finalizer version 2 DF 1000 watts BW 16Hz 3rdOHPF Velocity.jpg
ID:	2720992   Click image for larger version
Name:	Finalizer Version 2 DF front shot.jpg
ID:	2720994   Click image for larger version
Name:	Finalizer Version 2 DF step 1.jpg
ID:	2720996   Click image for larger version
Name:	Finalizer Version 2 DF step 2.jpg
Name:	Finalizer Version 2 DF step 3.jpg
ID:	2721000   Click image for larger version
Name:	Finalizer Version 2 DF step 4.jpg
ID:	2721002   Click image for larger version
Name:	Finalizer Version 2 DF step 5.jpg
ID:	2721004   Click image for larger version
Name:	Finalizer Version 2 DF step 6.jpg
ID:	2721006   Click image for larger version
Name:	Finalizer Version 2 DF step 7.jpg
Name:	Finalizer Version 2 DF step 8.jpg
ID:	2721010   Click image for larger version
Name:	Finalizer Version 2 DF step 9.jpg
ID:	2721012   Click image for larger version
Name:	Finalizer version 2 DF 1000 watts BW 16Hz 3rdOHPF Excursion.jpg
ID:	2721014   Click image for larger version
Name:	Finalizer version 2 DF cut list.jpg
ID:	2721016   Click image for larger version
Name:	Finalizer Version 2 DF side open.jpg
This is the way...
Red Five is offline
post #1271 of 1622 Old 05-04-2020, 12:41 PM - Thread Starter
Red Five's Avatar
Liked: 1244
Just for fun, if two of the Finalizer V2s were stacked and given 4000 watts this would be their potential.
@jujuman200 , please build 4 stacks someday, just for science
Name:	2x Finalizer V2s.jpg
jujuman200, Nalleh and Jan3 like this.
This is the way...
Red Five is offline
post #1272 of 1622 Old 05-04-2020, 01:15 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 429
So is this guy the FINAL iteration of this box?
Juju
post #1273 of 1622 Old 05-04-2020, 01:27 PM - Thread Starter
Red Five's Avatar
Liked: 1244
Juju
Yes, this is the final for this box. The passband is cleaner up top in exchange for a little velocity. Unless you want to do some custom work...
johnson636 and jujuman200 like this.
This is the way...
Red Five is offline
post #1274 of 1622 Old 05-04-2020, 02:45 PM
Nalleh's Avatar
Quoted: 3277 Post(s)
Liked: 5094
Awsome work on the DF DEV
Kind of what i asked about earlier for the Quad 12" Dev
"Whats that: would i like to see a DF Quad 12" Dev?"
Yes i would!
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 6x Crowsons - 4xBK-LFE - 2x12"BB - 2x "4DX" fans- 6xNU6K - Minidsp 10x10HD-Vertex2-Oppo UDP203-XB1X-ATV4K-JVC RS600-Dreamscreen V2 120"-Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #1275 of 1622 Old 05-04-2020, 03:09 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 429
Yes i would!
Personally I would just cut the 4 holes in this design and call it good...lol... This box is a beast.
Juju
post #1276 of 1622 Old 05-04-2020, 03:14 PM - Thread Starter
Red Five's Avatar
Liked: 1244
Yes i would!
I made a spreadsheet calculator for the bottom firing orientation. I can look at a Quad revision easily enough. Maybe tweak the parameters a little...
johnson636, jujuman200 and Nalleh like this.
This is the way...
Red Five is offline
post #1277 of 1622 Old 05-04-2020, 03:31 PM
johnson636's Avatar
Liked: 1281
You know, I wouldn't be the least bit surprised if Red came up with a DEV that had wings, a rocket booster engine, and could fly to the moon
Red Five likes this.
post #1278 of 1622 Old 05-04-2020, 03:40 PM - Thread Starter
Red Five's Avatar
Liked: 1244
Galatic conquest is not a near term goal, although I am not ruling it out...
This is the way...
Red Five is offline
post #1279 of 1622 Old 05-04-2020, 04:18 PM
johnson636's Avatar
Liked: 1281
Galatic conquest
I knew it
post #1280 of 1622 Old 05-05-2020, 04:02 AM
Quoted: 40 Post(s)
Liked: 3
Hello again, im about finished witht he mini v5, have yet to put the back and top on and speaker in, but first ive just seen about gasket tape, how important is that? and also about putting pillows inside?
jahowe6 is offline
post #1281 of 1622 Old 05-05-2020, 04:53 AM
johnson636's Avatar
Liked: 1281
If you're referring to gasket tape around the driver, then I don't believe you need it. The driver already has gasket tape that seems sufficient...at least for the 21ds115. I believe the gasket tape around the access panel is required to prevent air leaks. I recommend a pillow be placed in the enclosure even for a mini. Below is a close mic measurement of a Mini with and without a pillow
With a pillow
Without a pillow
BP1Fanatic, Jan3, Red Five and 1 others like this.
post #1282 of 1622 Old 05-05-2020, 04:57 AM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 429
Gasket tape is VERY important.... Pillows...Start with a king size pillow and attach it to a side wall then listen. if you still get a slight ringing add 1 more... enjoy your D...
Juju
post #1283 of 1622 Old 05-05-2020, 06:33 AM
Quoted: 40 Post(s)
Liked: 3
Juju
So just gasket tape or equlivent at the top port no where else? And as for pillows can i use insulation/other stuff?
Now shopping for handles as this thing will be moved fairly often (Few times a year) and its very heavy already
jahowe6 is offline
post #1284 of 1622 Old 05-05-2020, 06:41 AM - Thread Starter
Red Five's Avatar
Liked: 1244
The gasket tape or weather stripping goes around the outside edge of the access panel frame. I would turn off the lights in the room and check the seal on the sub by stick a flash light in each part of the front horn section. If you see light in the back by the sub, you have a seal issue. The cheapest pillows you can find at Walmart would great, tack one on each side panel, that will take out an rear chamber resonance. The goal is free moving air in the cabinet and not blocking the vent. If you have a couple chunks of insulation you could tack those on the side panels as well.
This is the way...
Red Five is offline
post #1285 of 1622 Old 05-05-2020, 06:45 AM - Thread Starter
Red Five's Avatar
Liked: 1244
This is the best shot I have of the gasket tape on my build. I had an air leak on the top left corner there, I had to double stack the tape and then put another piece behind my double stack section. I also added little pieces in the corners, again it looked like I had a small leak in the corners where seams met.
This is the way...
Red Five is offline
post #1286 of 1622 Old 05-05-2020, 06:48 AM
a77cj7's Avatar
Liked: 1066
Gasket tape:
I don’t use handles on mine, but a good selection can be found here:
https://www.parts-express.com/cat/handles/652
I would suggest a bar handle with no moving parts to avoid rattling.
Chris
BP1Fanatic and Crantastic like this.
a77cj7 is offline
post #1287 of 1622 Old 05-05-2020, 07:39 AM
dvdfantastic's Avatar
Quoted: 49 Post(s)
Liked: 40
How do you guys recess neurtrik adapter flush with the cabinet? Any tips will be highly appreciated including tools and tricks. Thanks all!
Also, what is the best way to remove excess PL3 glue like a thicker bead near the seams and baffle rails once it has dried?
dvdfantastic is offline
post #1288 of 1622 Old 05-05-2020, 07:45 AM
a77cj7's Avatar
Liked: 1066
I haven’t done a neutrik, but I do terminal cups with router jig. Same process applies.
Chris
a77cj7 is offline
post #1289 of 1622 Old 05-05-2020, 07:47 AM
Quoted: 49 Post(s)
Liked: 40
Chris
Thanks a77cj7. Unfortunately I do not have a router. Any alternates?
post #1290 of 1622 Old 05-05-2020, 07:50 AM
a77cj7's Avatar
Liked: 1066
You can use a forstner bit in a drill. Depth control will require a delicate touch.
Chris
Crantastic likes this.
a77cj7 is offline
devastator
