The Devastator Index - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 1121Likes
post #1291 of 1639 Old 05-05-2020, 07:52 AM
dvdfantastic's Avatar
Quoted: 49 Post(s)
Liked: 40
Originally Posted by a77cj7 View Post
You can use a forstner bit in a drill. Depth control will require a delicate touch.
Chris
Ok thanks. Will look into it. Any recommendations on the glue situation
dvdfantastic is offline
post #1292 of 1639 Old 05-05-2020, 07:54 AM
a77cj7's Avatar
Quoted: 1016 Post(s)
Liked: 1069
Pl3x works great on Devastators. Does a good job of sealing seams. I recommend wearing gloves, it bonds very well to hands.
Has a 24hr cure time.
Chris
a77cj7 is online now
post #1293 of 1639 Old 05-05-2020, 07:59 AM - Thread Starter
Red Five's Avatar
Quoted: 1326 Post(s)
Liked: 1245
Chris
+1 it also has a longer working time than Titebond. I would say you have half hour or so depending on humidity and temperature for panel adjustments before it starts to get gummy.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | CTS 2000 | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #1294 of 1639 Old 05-05-2020, 08:06 AM
Quoted: 49 Post(s)
Liked: 40
Thanks John. I am using it to build my DEV but I wanted to know if there was a way to safely remove dried up excess glue without damaging plywood. I believe it dries hard and removing excess from baffle rail seems might be a difficult task.
post #1295 of 1639 Old 05-05-2020, 08:07 AM
Quoted: 49 Post(s)
Liked: 40
Chris
Thanks a77cj7. PL3 is what I am using. How to remove dried up excess glue from tight spaces without damaging plywood is my concern.
post #1296 of 1639 Old 05-05-2020, 08:08 AM - Thread Starter
Red Five's Avatar
Liked: 1245
With PL3 you wait for it to harden for about 24 hours and then you cut it. Sanding it is not a good option.
This is the way...
post #1297 of 1639 Old 05-05-2020, 08:08 AM
a77cj7's Avatar
Liked: 1069
Wipe when wet or scrape when dry. I would only bother in visible areas, leaving the extra helps to seal the seams.
Chris
post #1298 of 1639 Old 05-05-2020, 08:13 AM
Quoted: 49 Post(s)
Liked: 40
Chris
Thanks Chris and @Red Five
post #1299 of 1639 Old 05-05-2020, 11:28 AM - Thread Starter
Red Five's Avatar
Liked: 1245
@Nalleh what do you think?
Name:	QUAD JBL V2.jpg
Nalleh likes this.
This is the way...
post #1300 of 1639 Old 05-05-2020, 12:16 PM - Thread Starter
Red Five's Avatar
Liked: 1245
Shallow BMD DF is tight, but it should work from the looks of it. That is roughly the size of the SAN214.50 in there.
Name:	Shallow BMD early concept.jpg
jujuman200, Bnaan and Jan3 like this.
This is the way...
post #1301 of 1639 Old 05-05-2020, 02:57 PM
Nalleh's Avatar
Quoted: 3281 Post(s)
Liked: 5098
Me like
Should be a very cool stacking option
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 6x Crowsons - 4xBK-LFE - 2x12"BB - 2x "4DX" fans- 6xNU6K - Minidsp 10x10HD-Vertex2-Oppo UDP203-XB1X-ATV4K-JVC RS600-Dreamscreen V2 120"-Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is online now
post #1302 of 1639 Old 05-05-2020, 04:58 PM
BP1Fanatic's Avatar
Quoted: 428 Post(s)
Liked: 406
Thumbs up
Chris
That pretty @$$ sub deserve to be seen...Baby got back!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is online now
post #1303 of 1639 Old 05-05-2020, 05:02 PM
a77cj7's Avatar
Liked: 1069
That one is hidden, only visible from the front.
Its twin, however:
Chris
BP1Fanatic and Crantastic like this.
post #1304 of 1639 Old 05-05-2020, 05:06 PM
BP1Fanatic's Avatar
Quoted: 428 Post(s)
Liked: 406
Question
Why not have the peak around 80-90hz?
post #1305 of 1639 Old 05-05-2020, 05:20 PM - Thread Starter
Red Five's Avatar
Liked: 1245
The woofers are not the best for a 6th order bandpass as you can see from the peak. The peak will have 2nd and 3rd order distortion attached to it when a signal hits that frequency. This round I am trying to push it a little out of the main passband, the LPF should be taking the signal down some by then if content hits the peak the distortion will be less. Subjective tests the Quad does not sound as good as one of the more expensive pro woofers. I am trying to make it sound a little better.
This is the way...
post #1306 of 1639 Old 05-06-2020, 09:03 AM
Quoted: 158 Post(s)
Liked: 198
The building begins 2x Mini Dev 21s 3xHT12s
Mocs123, BP1Fanatic, Jan3 and 2 others like this.
monty6400 is online now
post #1307 of 1639 Old 05-06-2020, 12:08 PM
Quoted: 164 Post(s)
Liked: 79
Question about the Nano 12" dev, for music listening:
What if ported to 30Hz and using LAVOCE SSF122.50L (120usd) or LAVOCE WAF124.01 (190usd)? Wouldn't give that some serious midbass output or would port velocity become too high?
Or even a smaller Pico dev with Lavoce SSF102.50L (100usd)
I know, just thinking for the living room...
NAD T758v3, 2x 21DS115 ported, QSC 1150 LCR, QSC SR-1020 surrounds, moving by the end of the year to a new 15Wx18Lx10.8 concrete basement.
Ncore 252MP, Behringer A800, Crown XLS1502
Soon JBL 4722n LCR with updated 2453SL CD
Jan3 is online now
post #1308 of 1639 Old 05-06-2020, 12:57 PM - Thread Starter
Red Five's Avatar
Liked: 1245
I did not look at the 10", but I did look at the two 12"s. The first one is okay, the suspension and motor are not the greatest for a Devastator. The second 12" has all the issues of the 18DS115, the motor is very strong and so is the suspension. It actually gets pretty peaky and velocity is just out of hand. I went through the Lavoce list, not seeing anything with a Fs around 30-35Hz and a Qts around .3. Does B&C have something?
This is the way...
post #1309 of 1639 Old 05-06-2020, 01:33 PM
a77cj7's Avatar
Liked: 1069
Costs more, but maybe try the eminence kappalite lf.
https://www.parts-express.com/eminen...river--290-590
Chris
post #1310 of 1639 Old 05-06-2020, 01:45 PM - Thread Starter
Red Five's Avatar
Liked: 1245
Chris
This is 200 watts into it with a 70 liter rear chamber and a 36in front QW tuned to 30Hz roughly. It is pretty flat. Power is pushing rated Xmax.
Name:	200 watts Kappalite 3012LF.jpg
Jan3 likes this.
This is the way...
post #1311 of 1639 Old 05-06-2020, 02:08 PM
a77cj7's Avatar
Liked: 1069
Wow, that’s pretty. Just doesn’t have the displacement for more power.
Might be the good living room Devastator he was looking for though.
Chris
Jan3 likes this.
post #1312 of 1639 Old 05-06-2020, 02:14 PM
Quoted: 164 Post(s)
Liked: 79
...Does B&C have something?
B&C 12" don't go below fs 42Hz.
I can search for other models, but maybe you can guide me first with the following preferences:
- Narrowness of box is most important (want to put between sofa and the window behind. Nano 40"x16.5"x20": 16.5" is absolute max, narrower is even better. (I'll but the dev on it's back)
- Second is midbass output (40-90Hz). I plan to xover them to bookshelf speakers around 90. I'm ready to tune up to 40Hz if that can make the box <16.5 shallow or wide.
- 10/12" doesnt matter
- Generally speaking, here in Europe the cheapest drivers i can get are Lavoce. Then B&C, Faital pro and Eminence etc about 20% more expensive.
How important is Xmax if we keep tune high enough?
Eminence BETA-12A (Fs 47Hz and 98db sensitivity, QTS 0.46) is only $10 more expensive here as the JBL (dont have JBL's Thiele parameters). What if the Nano is just tuned much higher?
Jan3 is online now
post #1313 of 1639 Old 05-06-2020, 02:20 PM
Quoted: 164 Post(s)
Liked: 79
Chris
It's really expensive here. Best I can find is Eminence DELTALITE II 2512 for $170
Edit: found the Kappalite 3012LF for $255. hm...
Jan3 is online now
post #1314 of 1639 Old 05-06-2020, 02:25 PM
Quoted: 164 Post(s)
Liked: 79
Wow, output is perfect. Just thinking if there could be a cheaper driver than this $255 one. But very good.
Jan3 is online now
post #1315 of 1639 Old 05-06-2020, 02:29 PM
a77cj7's Avatar
Liked: 1069
Ahh yes, Europe prices.
@Red Five , try the LaVoce wan123.00.
https://www.parts-express.com/lavoce...8-ohm--293-719
Or the mentioned deltalite:
https://www.parts-express.com/eminen...river--290-593
Neither will be as good as the kappalite, but much cheaper.
Chris
post #1316 of 1639 Old 05-06-2020, 02:33 PM
Quoted: 164 Post(s)
Liked: 79
great, could find the Kappalite 3012LF for $215, I won't search further, seems to be great price quality.
Do you think the box can still be made 2 inches more narrow or is 16.5 the limit? Length can be > 40".
Jan3 is online now
post #1317 of 1639 Old 05-06-2020, 02:38 PM
Quoted: 164 Post(s)
Liked: 79
LaVoce WAN123.00 = 170usd
Kappalite 3012 LF = 215usd
Deltalite II 2512 = 200usd (previously didnt see shipping was not included)
Seems the Kappalite will be best
Red Five and a77cj7 like this.
Jan3 is online now
post #1318 of 1639 Old 05-06-2020, 02:47 PM
Quoted: 158 Post(s)
Liked: 198
The b&c driver cut out for the 21 is 508mm, my cutout is approx 506mm, is this likely to cause any issues, drivers won’t be here for a few weeks so can’t check, but also want to get building? Cheers
post #1319 of 1639 Old 05-06-2020, 02:51 PM - Thread Starter
Red Five's Avatar
Liked: 1245
I am done with sims and stuff for the day. The Dual 12 is as narrow as I can go if I remember correctly. I will into tweaking something in the upcoming days.
This is the way...
post #1320 of 1639 Old 05-06-2020, 02:52 PM - Thread Starter
Red Five's Avatar
Liked: 1245
2mm should be pretty close to the margin off error on the cutouts. Worst case scenario is some hand sanding. I had to do that on my DS cabinet, the outer baffle was just a little too tight to fit the woofer on the inside.
monty6400 likes this.
This is the way...
devastator
