The Devastator Index - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 1120Likes
post #1321 of 1626 Old 05-06-2020, 03:00 PM
Quoted: 164 Post(s)
Liked: 79
Originally Posted by Red Five View Post
I am done with sims and stuff for the day. The Dual 12 is as narrow as I can go if I remember correctly. I will into tweaking something in the upcoming days.
Your contribution is very much appreciated.
I hadn't even noticed that the dual is 0.5 inch narrower, I think the single driver Nano is best to start with when using the Kappalite driver.
Horn based subs are new to me, I made several ported ones which are quite easy. I thought getting the tuning higher will simply make the box smaller, but it seems things are more complicated there
NAD T758v3, 2x 21DS115 ported, QSC 1150 LCR, QSC SR-1020 surrounds, moving by the end of the year to a new 15Wx18Lx10.8 concrete basement.
Ncore 252MP, Behringer A800, Crown XLS1502
Soon JBL 4722n LCR with updated 2453SL CD
Jan3 is offline
post #1322 of 1626 Old 05-06-2020, 03:04 PM
Quoted: 158 Post(s)
Liked: 198
2mm should be pretty close to the margin off error on the cutouts. Worst case scenario is some hand sanding. I had to do that on my DS cabinet, the outer baffle was just a little too tight to fit the woofer on the inside.
How will I know once the cab has been assembled as I won’t be able to see the driver face only the rear?
monty6400 is online now
post #1323 of 1626 Old 05-06-2020, 03:12 PM
johnson636's Avatar
Quoted: 1753 Post(s)
Liked: 1281
Guys, let's not forget to remind Red Five that we appreciate all his efforts. Although he has worked like a robot, he's very much human...I think
muzz, monty6400, Jan3 and 3 others like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #1324 of 1626 Old 05-06-2020, 03:16 PM - Thread Starter
Red Five's Avatar
Quoted: 1320 Post(s)
Liked: 1245
2mm is .0787in, I am definitely not that close with any of my tools, you should be okay there.
Mark an X going straight through the center of your cutout. Then from the outside edge of the cutout mark 27mm or so on those lines, just so there is some space past the outside diameter of the sub. You can then tell if you are close to centered or not by how much space is open on each line inside the markings.
monty6400 likes this.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | CTS 2000 | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #1325 of 1626 Old 05-06-2020, 05:00 PM
Quoted: 164 Post(s)
Liked: 79
I know there are different 12" JBL models out there. The CX1200 is not available here, and the prices of all others are more or less the same.
It seems the JBL Stadium 1224 is the most powerful; which one has been used here?
It can be bought for half the price of the Eminence Kappalite 3012LF. The current Dual Nano gives already much more output:
http://www.4me2.com/jbl/
(need to show link, seems i cant insert images here)
Jan3 is offline
post #1326 of 1626 Old 05-06-2020, 05:05 PM
Niavlys's Avatar
Quoted: 31 Post(s)
Liked: 79
Made some sawdust today for 2 Devastator Shallow w/ Pa460
I used Cutlist Optimizer to optimize the cutting patterns. It was a first for me. It's free and i found it easy to use.
It took 4 sheets of MDF for the 2 Devs. Thanks to @redfive for providing the cutlists to all of us.
The build will begin tomorrow
Name:	IMG_0521 - Copy (2).JPG
ID:	2722220   Click image for larger version
Name:	IMG_0531 - Copy (3).JPG
Living room, Anthem MRX-300 | Sherbourn PA 5-200 | Aperion VGT + VGC | DefTech DI 5,5R back | DI 5.5Bps side | SB-13 Ultra
Home theater, Anthem MRX 720 | 1099 LCR | Polk dipole FXi A4 side | FXi A6 back | 4 DIY sealed UXL-18 | 2 DIY Devastator Shallow w/ PA460 | Ep 4000 | Nu6000 | Nx6000 | DIY Spandex 140’’ / 2:39 screen | Epson 4010 | Panasonic DP-UB820
Niavlys is online now
post #1327 of 1626 Old 05-06-2020, 05:24 PM
BP1Fanatic's Avatar
Quoted: 426 Post(s)
Liked: 406
Yeah you did!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #1328 of 1626 Old 05-06-2020, 07:16 PM - Thread Starter
Red Five's Avatar
Liked: 1245
Have you peeked at the HR tutorial? You could sim the different woofers in the Dual 12"!
This is the way...
post #1329 of 1626 Old 05-07-2020, 12:53 AM
Quoted: 164 Post(s)
Liked: 79
I did, 2 months ago I downloaded Hornresp. It seemed really hard for me but I'll give it a try again. For sure it looks much harder than Winisd.
Jan3 is offline
post #1330 of 1626 Old 05-07-2020, 06:18 AM - Thread Starter
Red Five's Avatar
Liked: 1245
I can probably run a sim or two later on the JBLs.
Jan3 likes this.
This is the way...
post #1331 of 1626 Old 05-07-2020, 07:20 AM
Quoted: 77 Post(s)
Has anyone made a list of all the types of boxes with a build/cut sheet?
Great work here and countless hours from you guys. We all very much appreciate your time and efforts
hessc50 is online now
post #1332 of 1626 Old 05-07-2020, 07:33 AM
johnson636's Avatar
Liked: 1281
Check the first post of this thread.
post #1333 of 1626 Old 05-07-2020, 07:57 AM
Quoted: 77 Post(s)
Thank you
post #1334 of 1626 Old 05-07-2020, 09:46 AM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
I just finished my first sanity check on the 4000. Should be coming out with a 16Hz tune on the first try The straight ports have a little less friction, she might come out slightly higher than that. 4000 watts 18Hz 2nd order HPF active, velocity sits at 30m/s.
Did this design ever get finalized? I was wondering what drivers you used for the sim. Also, would it be possible to have the box stand up and the ports fire out the front rather than up in the air?
Jedi940 is online now
post #1335 of 1626 Old 05-07-2020, 10:00 AM - Thread Starter
Red Five's Avatar
Liked: 1245
Standing on its side they are front firing. I did not finish it up, I would recommended to smaller boxes before doing this. It is the SAN214.50.
This is the way...
post #1336 of 1626 Old 05-07-2020, 10:12 AM
Quoted: 164 Post(s)
Liked: 79
I really appreciate, thank you so much. It's easy for me to input Thiele parameters, but TBH even with your excellent Hornresp manual (I tried it again) it's not easy for me, and I don't feel confident. Maybe I can use your hornresp file and change Thiele properties from the CS1214 to the JBL Stadium 1224, I suppose all other variables would remain the same.
I only noticed now that you based your design on dual CS1214's, which are almost the same price here as the more powerful Stadium 1224
The 2 JBL variants for sale here are the Stage 1210 (60 euro) and Stadium 1224 (99 euro). Their parameters: http://www.4me2.com/jbl/jbl12.jpg
Last question: why did you limit the Kappalite 3012LF to 200 watts? Port velocity? The SPL output looks nice, but it's not more than the CS1214 used in the Nano.
Jan3 is offline
post #1337 of 1626 Old 05-07-2020, 10:23 AM - Thread Starter
Red Five's Avatar
Liked: 1245
I forgot if you said you could fit the Dual, the Dual looks good with the Stadium. That is 500 watts going into them. Velocity should not be an issue for this case or the Kappalite.
Name:	Stadium 4 Ohm Dual .jpg
BP1Fanatic likes this.
This is the way...
post #1338 of 1626 Old 05-07-2020, 11:36 AM
Quoted: 164 Post(s)
Liked: 79
[QUOTE=Red Five;59608380]I forgot if you said you could fit the Dual, the Dual looks good with the Stadium. That is 500 watts going into them. Velocity should not be an issue for this case or the Kappalite.
Great! I'm surprised though your Nano dual with lower spec dual CS1214 delivers 3db more output at 30Hz (600W) than the $$ dual Stadium @500 W.
Jan3 is offline
post #1339 of 1626 Old 05-07-2020, 11:52 AM - Thread Starter
Red Five's Avatar
Liked: 1245
[quote=Jan3;59608832]
Here is the Stage woofers running 500 watts. Excursion is higher on this woofer, it should still do the job.
Name:	Stage woofers JBL Dual.jpg
Jan3 likes this.
This is the way...
post #1340 of 1626 Old 05-07-2020, 12:01 PM - Thread Starter
Red Five's Avatar
Liked: 1245
There there is also this with 500 watts. Velocity is 20m/s with this configuration. The parallel load would be easier on an amp, 5.4Ohms/2 vs closer to 4 Ohms/2.
Jan3 likes this.
This is the way...
post #1341 of 1626 Old 05-07-2020, 12:46 PM
Quoted: 40 Post(s)
Liked: 3
Hi guys, just finished my build, does anyone know anything about connecting it to a computer?
jahowe6 is offline
post #1342 of 1626 Old 05-07-2020, 12:56 PM - Thread Starter
Red Five's Avatar
Liked: 1245
Connecting what exactly to a computer, the power amp?
This is the way...
post #1343 of 1626 Old 05-07-2020, 01:06 PM
Quoted: 164 Post(s)
Liked: 79
[QUOTE=Red Five;59608946][quote=Jan3;59608832]
Wow! Red Five, thank you so much, this makes my decision much easier. JBL Stage it will be. You seem to be confident it won't blow at 14mm displacement
I'll keep reading your many pages here and hope to make one in a few weeks.
If positive I will make shallow 21 dev's when my basement is ready. The only concern I have is can you put a Shallow 21" a few inches behind an AT screen, or would ported subs be better suited to prevent the screen moving.
Jan3 is offline
post #1344 of 1626 Old 05-07-2020, 01:09 PM
Quoted: 164 Post(s)
Liked: 79
[QUOTE=Red Five;59608996][quote=Jan3;59608832]
At almost double the price compared to JBL stage, it's not worth it. Thanks for showing!
Jan3 is offline
post #1345 of 1626 Old 05-07-2020, 01:11 PM - Thread Starter
Red Five's Avatar
Liked: 1245
[quote=Jan3;59609406][QUOTE=Red Five;59608996]
The stage at 14mm will probably start sounding distorted, that would be there upper limit more than likely.
Jan3 likes this.
This is the way...
post #1346 of 1626 Old 05-07-2020, 02:52 PM
Quoted: 129 Post(s)
The woofers are not the best for a 6th order bandpass as you can see from the peak. The peak will have 2nd and 3rd order distortion attached to it when a signal hits that frequency. This round I am trying to push it a little out of the main passband, the LPF should be taking the signal down some by then if content hits the peak the distortion will be less. Subjective tests the Quad does not sound as good as one of the more expensive pro woofers. I am trying to make it sound a little better.
I just want to say I have no idea what any of this means, but I can still appreciate this kind of talk between people who obviously know their stuff.
Bnaan is offline
post #1347 of 1626 Old 05-07-2020, 03:17 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 429
Your best bet would be one of the BMD variants....
Juju
Sub List: 1- Red Five Mini V1 Devastator 18" w/PA460, 1- Red Five Devastator LFE 21", 1- Red Five Devastator 21" Finalizer V2 DF , 1- BOSS platform [The Hideaway Theater], 2- 18" "Full Marty" tuned to 17Hz w/RSS460HO
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #1348 of 1626 Old 05-07-2020, 03:50 PM
Quoted: 40 Post(s)
Liked: 3
Yeah just wonderng if anyone here as done that? I kind of have it working but not really.
jahowe6 is offline
post #1349 of 1626 Old 05-07-2020, 04:08 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 429
That is how I have mine setup.... what do you want to know?
Juju
post #1350 of 1626 Old 05-07-2020, 04:41 PM
Quoted: 40 Post(s)
Liked: 3
Juju
Oh cool, so i have two left and right speakers connected to the greeen audio output and i have the powered amplifier connected in the orange output, it works when i set it up and test it but not when running applications as i dont think they use more than just stereo sound, wondering how you've overcome this
jahowe6 is offline
devastator
