The Devastator Index - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 1107Likes
post #1381 of 1585 Old 05-11-2020, 04:18 PM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 408
Originally Posted by Jk7.2 View Post
So I’ll tell ya, I started a thread years ago asking this question. I had 8 18” drivers, each with a dedicated Inuke 3000dsp bridged, and buttkickers. Also, no mini dsp, because my amps had dsp built in. So I used splitter after splitter after splitter and so on until I had enough outputs. I was able to easily drive each amp to clip. So you’ll be fine.
Fast forward to today, I have a MiniDSP 10x10, 3 20k clone amps, one 10k, and I love it. The dsp, especially with the wi-dg adapter for wireless control is so convenient. I used to have to connect a laptop one by one to each amp, and that took forever, and I always questioned if I got it right in each amp. Now it’s all on one screen, and I don’t have to get up and leave my beer! (Or bourbon)
Holy Cow that's a lot of iNukes (and heat and power)!!!!! Now you have 70K of power - I bet pressurize a room enough to make your head explode!
Jk7.2 likes this.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #1382 of 1585 Old 05-11-2020, 10:48 PM
Liked: 3
Sort of like that scene in Scanners, but more enjoyable!
Robert Heidt is offline
post #1383 of 1585 Old 05-11-2020, 10:55 PM
Liked: 3
Okay, I officially admit defeat! That's one impressive audio cabinet. I'm still in awe of the fact that you used to daisy chain the splitters together and it worked! I would have figured signal attenuation would have been rearing it's ugly head somewhere after the 4th splitter.
I've been busy today calling my local hardwood supplier getting pricing on 3/4" and 1" MDF, as well as 3/4" Baltic Birch. The pricing is not as bad as I anticipated. I'm also waiting for a response back from Sinbosen on the price and availability of the FP20000Q amp.
Jk7.2 likes this.
post #1384 of 1585 Old 05-12-2020, 06:41 AM
radchad3's Avatar
Quoted: 53 Post(s)
Liked: 26
I am looking to finish my Devs. I would like to spray them but I have not an expert by any means. I have a few questions:
1. How many coats of primer should I use, how many coats of paint?
2. I am thinking of using the GSG Audio formulation that they have on their site. Any other recs for black paint?
3. How do I finish the edges of the wood? I am using baltic birch ply. Can I use drywall compound?
4. I have some beads of glue at the seems of the bottom ports etc, do you just chisel them out and sand?
Thank you all for your time!
Chad
radchad3 is offline
post #1385 of 1585 Old 05-12-2020, 06:57 AM - Thread Starter
Red Five's Avatar
Quoted: 1310 Post(s)
Liked: 1241
Chad
Two coats of primer should do. Once you have those down sand them with a medium grit paper. You can use a brush and lay it down thick, since you are sanding it anyways.
Do you have Menards in your area? This stuff works great - https://www.menards.com/main/paint/i...295-c-8017.htm
I am not the finishing expert with edges, I know a lot of guys use round overs.
Yes, use a knife or chisel to get the majority of the glue off. I am assuming it is PL? It does not sand well, so remove as much as you can without damaging the wood, then hit it with sandpaper.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | CTS 2000 | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #1386 of 1585 Old 05-12-2020, 07:21 AM
radchad3's Avatar
Quoted: 53 Post(s)
Liked: 26
Thanks John! So even though the paint says paint and primer in one, I should still do the primer first correct?
I may look at doing a round over but I will have to research that.
Thanks!!
radchad3 is offline
post #1387 of 1585 Old 05-12-2020, 07:26 AM - Thread Starter
Red Five's Avatar
Liked: 1241
Thanks!!
It does not build the greatest, the primer will do better filing little imperfections. Zinnser has a cheap drywall primer, I think @hd0823 used that and said it worked fine. The GSG recommendation is the Triple Thick Zinnser primer. MDF really soaked that up, not sure how much the Birch will soak up.
Look at some of @eng-399 builds for inspiration
radchad3 likes this.
This is the way...
post #1388 of 1585 Old 05-12-2020, 08:53 AM
hd0823's Avatar
Quoted: 945 Post(s)
Liked: 1796
Yeah the cheap stuff worked fine for me but remember I was on plywood also.
Sent from my SM-N975U using Tapatalk
Red Five likes this.
hd0823 is offline
post #1389 of 1585 Old 05-12-2020, 10:09 AM
radchad3's Avatar
Quoted: 53 Post(s)
Liked: 26
Did you use anything for the plywood edges? Just sand and primer or did you use any drywall compound?
radchad3 is offline
post #1390 of 1585 Old 05-12-2020, 11:19 AM
hd0823's Avatar
Quoted: 945 Post(s)
Liked: 1796
I actually came up with a idea to trim them out and save on some of the finishing work I did do drywall compound on alot of the seams and plywood edges plus alot of sanding
hd0823 is offline
post #1391 of 1585 Old 05-12-2020, 03:40 PM
radchad3's Avatar
Quoted: 53 Post(s)
Liked: 26
That looks great!
hd0823 likes this.
radchad3 is offline
post #1392 of 1585 Old 05-12-2020, 05:22 PM
muzz's Avatar
Quoted: 933 Post(s)
Liked: 647
After all these years, I think I've decided on a design that will work, and it's one of these... well, 2 of these...now I just need to figure out which one to build.
Gonna be 2 devs, 21" in each, and not 8ohm drivers. I have a 3K and a 6k, 6k is driving 2 Micros with PA460, so the Devs will make those redundant, and at the same time, fill in the bottom so I can get away from the idea of building 2 Full Marty's (with HT18's I've had forever) and having to run a new circuit.
Great thread Red, I've been following along.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #1393 of 1585 Old 05-13-2020, 01:46 AM
Liked: 0
I have been searching the forum for thickness of the sheets for the devastator with no luck.
Anyone can help me out here?
Hamsjael83 is offline
post #1394 of 1585 Old 05-13-2020, 05:03 AM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 408
Off topic question about your iNukes. I see you have channel A gain at about 50% and channel B gain at 0%. I was under the impression that the gain should be set at 100%. I'm assuming you're bridged and not using channel B but why is channel A at 50% - Should I not have mine at 100%?
Mocs123 is offline
post #1395 of 1585 Old 05-13-2020, 05:52 AM
muzz's Avatar
Quoted: 933 Post(s)
Liked: 647
They are Bridged, so 1 attenuator control.
muzz is offline
post #1396 of 1585 Old 05-13-2020, 06:04 AM
a77cj7's Avatar
Quoted: 1006 Post(s)
Liked: 1064
They are all 3/4” material.
Chris
a77cj7 is offline
post #1397 of 1585 Old 05-13-2020, 06:05 AM
Jk7.2's Avatar
Quoted: 1847 Post(s)
Liked: 3381
I didn’t have a MiniDSP to crank the gain way down in if my attenuator was all the way up. So I was at about 5/8” gain on the knob. That landed my lfe output at -8 or so.
I could’ve used the software in the amps dsp, now that I recall. But I just did it the other way.
Mocs123 likes this.
Jk7.2 is online now
post #1398 of 1585 Old 05-13-2020, 12:47 PM
Liked: 0
Chris
post #1399 of 1585 Old 05-15-2020, 04:07 PM - Thread Starter
Red Five's Avatar
Liked: 1241
Baby number two is here! Devastator will be awhile...
muzz, DigiWega, Mocs123 and 12 others like this.
This is the way...
post #1400 of 1585 Old 05-15-2020, 11:41 PM
Quoted: 245 Post(s)
Liked: 208
Congratulations on the baby. Have a well deserved rest with the new one.
femi, BP1Fanatic and Red Five like this.
Randy_J is offline
post #1401 of 1585 Old 05-16-2020, 08:07 AM
femi's Avatar
Quoted: 334 Post(s)
Liked: 432
I don't think he will get rest with a new one. Believe me i know. I have one who just turn one month today.
Love him to death but man i would love to get one good night sleep.
Femi
muzz, BP1Fanatic and Red Five like this.
(2)JTR Cap 4000's---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(3)JBL 4722n---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Sony UBP-X800---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---HDFURY Linker---Darbee Darblet DVP-5000---miniDSP Balanced 2x4---Harmony 1100 remote
femi is offline
post #1402 of 1585 Old 05-16-2020, 08:18 AM
hd0823's Avatar
Quoted: 945 Post(s)
Liked: 1796
Femi
Congrats to both of you guys . Yeah I got lucky and didn't ever have to go through that I'm a super super heavy sleeper and the wife said its more work getting me up than just getting up herself.
femi, BP1Fanatic, Jk7.2 and 1 others like this.
hd0823 is offline
post #1403 of 1585 Old 05-16-2020, 08:56 AM
Jk7.2's Avatar
Liked: 3381
^ lol Jeremy.
Congrats guys.
femi likes this.
Jk7.2 is online now
post #1404 of 1585 Old 05-16-2020, 12:11 PM
tk123's Avatar
Quoted: 243 Post(s)
Liked: 154
Congrats on the new one.
Praying for health and well being of you and your family
tk123 is online now
post #1405 of 1585 Old 05-16-2020, 02:51 PM
Quoted: 157 Post(s)
Liked: 196
Does this look ok for port clearance, not much I can do now though the braces are glued in doh
monty6400 is online now
post #1406 of 1585 Old 05-16-2020, 03:14 PM
Quoted: 157 Post(s)
Liked: 196
I’ve made a big mistake, the brace you see is 18mm to far back, hence Close to the port, so my access hatch brace that I have made that is supposed to rest on this brace is 18mm short. The options are, try and remove the brace, although not sure how without snapping it, add an extra 18mm to the access hatch panel piece, or add an extra perpendicular brace piece to the window so that it holds the access hatch.
post #1407 of 1585 Old 05-16-2020, 03:19 PM
Quoted: 157 Post(s)
Liked: 196
Removed the brace so will have to fashion a new one, Jesus wood glue is bloody strong, the mdf splir before the joint did!
post #1408 of 1585 Old 05-16-2020, 05:09 PM
jujuman200's Avatar
Quoted: 409 Post(s)
Liked: 429
Extending my congrats to the babymakers...... when my 21 year old was small, I didn't get a decent night of sleep until she was almost 3!!! Just so you know what IS possible....
Juju
BP1Fanatic, monty6400 and Red Five like this.
Sub List: 1- Red Five Mini V1 Devastator 18" w/PA460, 1- Red Five Devastator LFE 21", 1- Red Five Devastator 21" Finalizer V2 DF , 1- BOSS platform [The Hideaway Theater], 2- 18" "Full Marty" tuned to 17Hz w/RSS460HO
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #1409 of 1585 Old 05-16-2020, 06:35 PM
Nalleh's Avatar
Quoted: 3272 Post(s)
Liked: 5073
Oh, wow man! Congrats, take care and cherish these moments
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 6x Crowsons - 4xBK-LFE - 2x12"BB - 2x "4DX" fans- 6xNU6K - Minidsp 10x10HD-Vertex2-Oppo UDP203-XB1X-ATV4K-JVC RS600-Dreamscreen V2 120"-Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is online now
post #1410 of 1585 Old 05-16-2020, 07:20 PM - Thread Starter
Red Five's Avatar
Liked: 1241
My two year old is going to be three at the end of this summer and she is still not sleeping. I have had the night shift for the last several weeks, it really burns you out. Usually I would do the weekend and a night here or there.
jujuman200 and Jan3 like this.
This is the way...
devastator
