The Devastator Index - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 117Likes
post #181 of 240 Old 01-08-2020, 02:46 PM
Quoted: 1900 Post(s)
Liked: 1507
Originally Posted by femi View Post
I don't know if this will help because i used plywood on my built and i got my tip from @hd0823 and i used what he recommend which was https://www.homedepot.com/p/SPAX-1-4...0507/202041031 for the screws and added wood blocks behind the mounting holes to have more for it to bite into.
Femi
I’ll ask Red if it’s okay to have blocks protruding from the front, but I’ve used these spax screws before and liked them.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #182 of 240 Old 01-08-2020, 02:57 PM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
A few chunks of 2x4 will not hurt anything. If you look at my Mini build thread you will see them in the front.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is offline
post #183 of 240 Old 01-08-2020, 02:59 PM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Originally Posted by jujuman200 View Post
Are you really going to make me figure out how to make my already built LFE front chamber shallower for a better low end? LOL..
Juju
Maybe I had a plan for a clear plastic retro fit, this could be doable...
jujuman200 likes this.
Red Five is offline
post #184 of 240 Old 01-08-2020, 03:54 PM
a77cj7's Avatar
Quoted: 429 Post(s)
Liked: 365
Juju
If you can have a deeper cabinet, you could build a spacer to replace the hatch panel to increase rear chamber volume. It could be full cabinet height.
It will lower your port tune also.
Chris
a77cj7 is online now
post #185 of 240 Old 01-08-2020, 08:41 PM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
@jujuman200 looking at some quick calculator math, the LFE with the shallow front has 21.8cuft gross to work with. I wonder what the NSW would do in that with some tweaking? 123db maybe a little more might be possible at 2/3 gap. If I can get enough vent area with 130Hz + first port resonance or see how low it can go and still hit 120db. There is not a current Devastator that can do 16Hz at 120db and kick your chest in with mid bass. 120 might be a little ambitious, but I can always try
jujuman200, femi and Nalleh like this.
Red Five is offline
post #186 of 240 Old 01-09-2020, 04:51 AM
Nalleh's Avatar
Quoted: 2838 Post(s)
Liked: 3924
^^ Or what about a BMD LFE HCR ??
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE Dual TR Sleds- 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XB1X - ATV4K - Vertex2 - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
>>>>Nalleh’s HT<<<<
Nalleh is online now
post #187 of 240 Old 01-09-2020, 07:06 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Making it taller and slimmer might be desirable. The rear chamber is already at 400+ liters, that is a big chamber!
Name:	BMD tweaking.jpg
Nalleh likes this.
Red Five is offline
post #188 of 240 Old 01-09-2020, 08:11 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
@Nalleh , this is the one you have been wanting to see. I have a couple comparisons. The 1 cuft sealed and then a bass reflex with the same specs as the Nano. The box would have to get taller for bringing the resonate point down more.
Name:	Nan Dev vs sealed 1cuft.jpg
ID:	2667056   Click image for larger version
Name:	Nano vs BR same rear.jpg
ID:	2667058   Click image for larger version
Name:	Nano Dev side open.jpg
ID:	2667060   Click image for larger version
Name:	Nano front shot.jpg
Nalleh likes this.
Red Five is offline
post #189 of 240 Old 01-09-2020, 08:25 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
I would start with this filter and then measure near field, see if it looks pretty flat or needs more tweaking. 300 watts, with a 20Hz 2nd order HPF keeps things in check, about 15.2mm is the estimate on the sim.
Name:	Nano reference filter.jpg
Nalleh likes this.
Red Five is offline
post #190 of 240 Old 01-09-2020, 08:49 AM
Rcris's Avatar
Quoted: 121 Post(s)
Liked: 148
Originally Posted by Red Five View Post
Two ports plugged has a tune around 34Hz on the Micro MBM, maybe a little lower in reality. Response looks like this.
could you please indicate which two ports
Rcris is offline
post #191 of 240 Old 01-09-2020, 08:52 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Two of the lower ports, the math is assuming they are all equal distance, 5 inches between each board. If you are building port covers the outside two would be the easiest.
Red Five is offline
post #192 of 240 Old 01-09-2020, 09:13 AM
Nalleh's Avatar
Liked: 3924
@Red Five : awsome work, thanks so much Is this still about 154 liters ?
And is this with the latest HCR improvents?
Would it be possible to plug ports on this too, to lower tuning?
General Q: is there any point plugging the resonator ports?
>>>>Nalleh’s HT<<<<
post #193 of 240 Old 01-09-2020, 09:43 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
External volume is 7.64 cuft or 216.3 liters rear chamber volume is 111.6 liters. It is a nice rear chamber volume for pushing the driver to what would be considered safe max on power and excursion. Yes, the front chamber is 283.06 cm2, that is a 1.95:1 compression ratio. Plugging ports is an easy way to drop the tune without modifying a box, native tune is 19Hz on the Nano. One port plugged (on the HH resonator, we do not want to mess with the QW/horn) should push tune down somewhere in the mid teens. You add port velocity and lose efficiency when doing that. Since it is a 12" it is not pushing the laws of physics as much as some other things so velocity is not as bad.
Nalleh likes this.
Red Five is offline
post #194 of 240 Old 01-09-2020, 09:47 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Speaking of pushing the laws of physics, Dev MAX LFE for the NSW looks very promising, at least in the sim, only pushing 35m/s on port velocity. 15Hz tune, 2200 watts, 22.5mm of excursion.
Name:	Concept Dev MAX LFE.jpg
Nalleh and Rcris like this.
Red Five is offline
post #195 of 240 Old 01-09-2020, 11:01 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Not even sure what to name this one, Mini 21" NSW LFE MAX HCR - it basically is everything in one box. Tune is estimated at 15.5Hz, there is some extension on this one. Any of the 21"s would work, but that left corner number might not be as high. Pushing around 23mm of excursion with a 15Hz 3rd order HPF.
SAN214.50 getting 91 volts still looks very respectable.
Name:	DEV MINI LFE MAX concept shot.jpg
ID:	2667152   Click image for larger version
Name:	SAN Mini LFE HCR SPL.jpg
jujuman200 and Nalleh like this.
Red Five is offline
post #196 of 240 Old 01-12-2020, 08:05 PM
Nalleh's Avatar
Liked: 3924
With EQ that actually looks very similar to the ported version?
Could you post the max SPL of Nano and ported?
>>>>Nalleh’s HT<<<<
post #197 of 240 Old 01-13-2020, 08:12 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Both are pushing 33 volts or 300 watts with 15mm excursion limit enabled. The Devastator can do more if it gains displacement from lengthening the horn. I attached a BMD version that is getting worked on as an example of what would happen with the horn section.
Name:	Nano 33 volts MAX.jpg
ID:	2669234   Click image for larger version
Name:	BR Nano Rear chamber MAX .jpg
ID:	2669236   Click image for larger version
Name:	BMD Short version.jpg
Nalleh likes this.
Red Five is offline
post #198 of 240 Old 01-13-2020, 11:01 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Devastator 21" Version 2 HCR
This is the Devastator Version 2 HCR! A slight tweak to the original design adding more rear chamber volume and taking down the midbass response with the smaller front horn section. External dimensions are kept the same as the original along with the 19Hz tune. The sim is 91 volts into a SAN214.50 with a 19Hz 2nd order HPF active.
Name:	DEV v2 HCR input.jpg
ID:	2669336   Click image for larger version
Name:	Dev v2 HCR cutlist.jpg
ID:	2669338   Click image for larger version
Name:	Devastator v2 HCR front shot.jpg
ID:	2669340   Click image for larger version
Name:	Devastator v2 HCR side shot open.jpg
ID:	2669342   Click image for larger version
Name:	Devastator v2 HCR SPL 91 volts 19Hz2ndOHPF.jpg
Name:	Devastator v2 HCR EX 91 volts 19Hz2ndOHPF.jpg
ID:	2669346   Click image for larger version
Name:	Devastator v2 HCR Velocity 91 volts 19Hz2ndOHPF.jpg
Red Five is offline
post #199 of 240 Old 01-13-2020, 04:51 PM
Nalleh's Avatar
Liked: 3924
Uhh, that BMD model(third attm) isn’t for the 12" ?!?
Nevertheless clever lengthening of the horn part
>>>>Nalleh’s HT<<<<
post #200 of 240 Old 01-13-2020, 04:55 PM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
No, that is a SAN214.50 getting 1600 watts lol.
Nalleh likes this.
Red Five is offline
post #201 of 240 Old 01-17-2020, 10:46 AM
Rcris's Avatar
Quoted: 121 Post(s)
Liked: 148
I suppose this box is for Jbl CS1214, am I right.
Rcris is offline
post #202 of 240 Old 01-17-2020, 11:07 AM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Yes, that is geared for the JBLs. It will work with other 12"s though.
Red Five is offline
post #203 of 240 Old 01-22-2020, 12:35 PM
rfbrang's Avatar
Quoted: 299 Post(s)
Liked: 92
Are these directional?
Looking for a way to add subs to room columns under side surround and rear speakers in a dedicated room. Would the box for the JBL 12 work pointed towards the front or rear of the room?
rfbrang is offline
post #204 of 240 Old 01-22-2020, 02:19 PM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
The frequency range these play in is not all that directional. You can point it whatever you want for the most part, if a boundary is less than a foot away that could mess with it though. I will have to get the Nano finished up soon, I just have not had many opportunities for finishing the cut list etc as of late.
Red Five is offline
post #205 of 240 Old 01-22-2020, 02:44 PM
Rcris's Avatar
Quoted: 121 Post(s)
Liked: 148
Planning to build one once the cut list is ready to see how it does using jbl driver that I already have.
Rcris is offline
post #206 of 240 Old 01-22-2020, 02:51 PM
rfbrang's Avatar
Quoted: 299 Post(s)
Liked: 92
There would be a boundry. It looks like the ports could be cut on the 20" side instead of the 16.5". If port size is kept the same, does the placement matter?
Our Old Space
New House
PSN: brotj7
rfbrang is offline
post #207 of 240 Old 01-23-2020, 06:38 AM
Probably a stupid question but can the original adire tempest be used in any of these designs? I have two collecting dust that I want to use.
rykerjen is offline
post #208 of 240 Old 01-23-2020, 01:23 PM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
Nano Devastator 12"
Here is the Devastator Nano for the JBL 12"s that are common place now The design should work well with other 12 inch subs out there, this is just the most popular one at the moment. Sim is 300 watts with a 20Hz 2nd order HPF. Tune came out to 19Hz on this cabinet.
Name:	Nano Dev cut list.jpg
ID:	2674784   Click image for larger version
Name:	Nano Dev input.jpg
ID:	2674786   Click image for larger version
ID:	2674788   Click image for larger version
ID:	2674790   Click image for larger version
Name:	Nano Dev 33v 300 watts 20H2ndOHPF SPL.jpg
Name:	Nano Dev 33v 300 watts 20H2ndOHPF EX.jpg
ID:	2674794   Click image for larger version
Name:	Nano Dev 33v 300 watts 20H2ndOHPF Velocity.jpg
jujuman200, Nalleh, MW6006 and 1 others like this.
Red Five is offline
post #209 of 240 Old 01-23-2020, 01:45 PM
Nalleh's Avatar
Liked: 3924
^^^ Awsome work, man
I may not be the first to try this, but i will try it when it gets warmer up here
Red Five likes this.
>>>>Nalleh’s HT<<<<
post #210 of 240 Old 01-23-2020, 02:07 PM - Thread Starter
Red Five's Avatar
Quoted: 931 Post(s)
Liked: 740
If the box were to grow and I sort through some engineering challenges a BMD Nano could be doable. This would be a concept of that.
Name:	Nano BMD concept.jpg
Nalleh likes this.
Red Five is offline
